Realtek RTL8156 2.5G USB Ethernet for ROS7?
Thanks for your reply. I don’t expect anything from you. My message is simply about sharing my experience and suggesting what you can do if you really need this feature. This thread seems almost 4 years old, and I believe many people, including myself, would like this feature. The issue is that Mikrotik currently supports 100/1000 USB to Ethernet adapters (RTL8152/8153), but not 2500 (RTL8156)
:backhand_index_pointing_down:
and then :slight_smile:
  • where are more USB-C ports?
  • why USB interface changes it's name each time router reboots?
  • why that interface is so slow if I connect it to USB in my hAP lite with a converter?
  • why CPU is so saturated when I use USB interface?
  • why hardware off-loading does not work for that interface?
  • why switch ACL rules cannot be applied to that interface?
  • why bridge does not allow ..... if I use USB interface?
  • USB interrupts kill my router
  • which Mini PCI-e converter would allow me to use more USB interfaces?
  • how to connect both USB disk and network card to one port?
  • why USB port extender draws so much power?
  • why my XYZ branded very cheap card is not recognized but it works with my Windows/Mac?
here im back again on 7.22rc4…. and still nope. :frowning:
