Can you help me with that? This is the configuration of the hAP Lite:
add admin-mac=B8:69:F4:0E:74:D0 auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] advertise=
10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full
set [ find default-name=ether2 ] advertise=
set [ find default-name=ether3 ] advertise=
set [ find default-name=ether4 ] advertise=
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 keepalive-timeout=disabled name=
pppoe-out1 use-peer-dns=yes user=guest@adsl.gr
/interface pptp-server
add name=pptp-in1 user=ppp1
add comment=defconf name=WAN
add comment=defconf name=LAN
add authentication-types=wpa2-psk management-protection=allowed mode=dynamic-keys name=
profile1 supplicant-identity=MikroTik
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-Ce disabled=no
distance=indoors frequency=auto mode=ap-bridge security-profile=profile1 ssid=
HomeWifi wireless-protocol=802.11
add name=dhcp ranges=192.168.88.10-192.168.88.100
add name=dhcp_pool1 ranges=192.168.88.2-192.168.88.254
add name=VPNpool ranges=192.168.88.101-192.168.88.150
add address-pool=dhcp disabled=no interface=bridge name=defconf
/ppp profile
add bridge=bridge change-tcp-mss=yes dns-server=8.8.8.8,8.8.8.4 local-address=
192.168.88.1 name=VPMprofile remote-address=VPNpool
/interface detect-internet
set internet-interface-list=all
/interface pptp-server server
set default-profile=VPMprofile enabled=yes
add address=192.168.88.1/24 comment=defconf interface=ether2 network=192.168.88.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=ether1
set allow-remote-requests=yes servers=8.8.8.8
/ip dns static
add address=192.168.88.1 name=router.lan
add action=accept chain=input comment=“defconf: accept established,related,untracked”
add action=drop chain=input comment=“defconf: drop invalid” connection-state=invalid
add action=accept chain=input dst-port=1723 protocol=tcp
add action=accept chain=input comment=“defconf: accept ICMP” protocol=icmp
add action=drop chain=input comment=“defconf: drop all not coming from LAN”
in-interface-list=!LAN
add action=accept chain=forward comment=“defconf: accept in ipsec policy” ipsec-policy=
in,ipsec
add action=accept chain=forward comment=“defconf: accept out ipsec policy” ipsec-policy=
out,ipsec
add action=fasttrack-connection chain=forward comment=“defconf: fasttrack”
add action=accept chain=forward comment=“defconf: accept established,related, untracked”
add action=drop chain=forward comment=“defconf: drop invalid” connection-state=invalid
add action=drop chain=forward comment=“defconf: drop all from WAN not DSTNATed”
connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=masquerade chain=srcnat comment=“defconf: masquerade” ipsec-policy=out,none
out-interface=pppoe-out1
add action=dst-nat chain=dstnat disabled=yes dst-address=141.255.114.15 dst-port=1723
protocol=tcp to-addresses=192.168.88.13 to-ports=1723
add distance=1 dst-address=192.168.2.10/32 gateway=ether1
/ppp secret
add name=ppp1 profile=VPMprofile service=pptp
add name=ppp2 profile=VPMprofile service=pptp
/system clock
set time-zone-name=Europe/Athens
/system routerboard mode-button
set enabled=yes on-event=script1
/system script
add dont-require-permissions=no name=wlan_on_off owner=admin policy=
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source=“:if ([/interf
ace get wlan1 disabled ]=false) do={\r
\n\t/interface wireless disable wlan1} else={\r
\n\t/interface wireless enable wlan1}”
add dont-require-permissions=no name=WLAN_OFF owner=admin policy=
“/interface wireless disable wlan1”
add dont-require-permissions=no name=WLAN_ON owner=admin policy=
“/interface wireless enable wlan1”
/tool mac-server
/tool mac-server mac-winbox
And this is the configuration of the hAP Mini which is conencted to hAP Lite through wifi
add admin-mac=74:4D:28:84:DB:19 auto-mac=no comment=defconf name=bridge
/interface wireless
disabled=no frequency=auto mode=station-bridge ssid=HomeWifi
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk group-ciphers=
tkip,aes-ccm mode=dynamic-keys supplicant-identity=MikroTik
unicast-ciphers=tkip,aes-ccm
add authentication-types=wpa2-psk mode=dynamic-keys name=
wlan1-HomeWifi-repeater supplicant-identity=MikroTik
/interface wireless
add disabled=no keepalive-frames=disabled mac-address=76:4D:28:84:DB:1C
master-interface=wlan1 multicast-buffering=disabled name=wlan2
security-profile=wlan1-HomeWifi-repeater ssid=HomeWifi-guest
wds-cost-range=0 wds-default-cost=0 wps-mode=disabled
add name=dhcp ranges=192.168.88.10-192.168.88.254
add bridge=bridge interface=wlan2
add interface=wlan1 list=WAN
add interface=ether1 list=LAN
add interface=ether2 list=LAN
add interface=ether3 list=LAN
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=bridge
/ip dns static
“defconf: accept established,related,untracked” connection-state=
invalid
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
“defconf: accept established,related, untracked” connection-state=
invalid
“defconf: drop all from WAN not DSTNATed” connection-nat-state=!dstnat
out,none out-interface-list=WAN
/system clock
/tool mac-server
It is strange cause if i connect with cable to hAP mini I can see both in winbox. Ευχαριστώ για την βοήθεια btw.
