Replacement rack ear screws
Hello all,
It appears I misplaced the screws (K-48) for the rack ears of my CSS610 switch. I went to my local hardware store to try to replace them but they don’t care that size. Any idea where I can buy replacement screws, or anyone living in the US looking to sell me their 8 quantity of K-48 screws?
Can you check the measure of the hole and the thickness of the ear?
The screws should be either M4 8 mm length, or M3 6 mm, but if they are a couple mm longer it shouldn’t be an issue.
Or you can get a suitable kit on (say) Amazon, example:
https://www.amazon.com/SZHKM-480pcs-Assortment-Stainless-Assorted/dp/B08MJPGQKM?th=1
(the above are countersunk hex, but I am sure you can find Phillips heads as well)
A fellow forum user @arnd did measurements and posted results in this post. I strongly believe that all MT rack-mountable devices use same type of “ear mounting” screws…
But I don’t fully trust that piece of info because of this post (about the 4011 that has a different way to mount ears):
http://forum.mikrotik.com/t/4011igs-rack-mount-screws/145664/1
So we have at least two measures, M3x6 or M4x8.
Very likely the ones used are the M4x8, but it is easy to check, the threaded hole should be either 2.46 mm or 3.24 mm, that in the measures of our friends across the pond should be roughly 0.097" or 0.128".
K-48 are M3.
Some devices perhaps uses M4, I personally never had any.
