RouterOS v7 cannot activate IPv4 connected route over ipipv6 (DS-Lite / RFC6333)
This is a reproducible RouterOS v7 issue affecting IPv4 routing over ipipv6 interfaces.
Summary:
  • IPv6 connectivity is working (AFTR reachable, ICMPv6 OK)
  • ipipv6 interface is RUNNING
  • IPv4 address can be assigned to ipipv6 interface
  • RouterOS creates IPv4 connected route
  • However, the route remains DIc and never becomes ACTIVE
  • As a result, no IPv4 packets are generated
This occurs not only with DS-Lite (RFC6333) but also with a plain ipipv6 tunnel.
MikroTik support (SUP-209458) confirmed:
  • This is not a configuration issue
  • There is no user-configurable way to change this behavior
Impact:
This prevents RouterOS from functioning as a DS-Lite CPE on networks such as NTT FLET'S (Japan), where IPv4 connectivity depends entirely on IPv4-over-IPv6.
Required behavior:
RouterOS should allow IPv4 L3 routing over ipipv6 interfaces.
The IPv4 connected route should become ACTIVE when:
  • interface is RUNNING
  • IPv6 path is reachable
  • IPv4 address is assigned
Question to MikroTik developers:
Is this a known limitation, or a defect to be fixed?
