I installed this device, changed nothing, not even upgraded and simply checked the speeds. The upload is around 6 Mbps. (With cable to laptop testing)
When I attach the "internet" cable to my laptop, I get:
The default settings, after upgrading:
export.rsc (6.7 KB)
# 2026-05-17 09:10:57 by RouterOS 7.22.3
# software id = K317-RGX7
# model = E62iUGS-2axD5axT
# serial number = HM60BBJE0KC
add admin-mac=D0:EA:11:41:52:11 auto-mac=no comment=defconf name=bridge
/interface wifi
set [ find default-name=wifi1 ] channel.band=2ghz-ax .skip-dfs-channels=\
10min-cac .width=20/40mhz configuration.mode=ap .ssid=MikroTik-415216 \
disabled=no security.authentication-types=wpa2-psk,wpa3-psk .ft=yes \
.ft-over-ds=yes
set [ find default-name=wifi2 ] channel.band=5ghz-ax .skip-dfs-channels=\
10min-cac .width=20/40/80mhz configuration.mode=ap .ssid=MikroTik-415216 \
.ft-over-ds=yes
add comment=defconf name=WAN
add comment=defconf name=LAN
add address-pool=default-dhcp interface=bridge name=defconf
/disk settings
set auto-media-interface=bridge auto-media-sharing=yes auto-smb-sharing=yes
add bridge=bridge comment=defconf interface=sfp1
add bridge=bridge comment=defconf interface=wifi1
add bridge=bridge comment=defconf interface=wifi2
192.168.88.0
/ip dhcp-client
add comment=defconf interface=ether1 name=client1
192.168.88.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 comment=defconf name=router.lan type=A
established,related,untracked
invalid
"defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1 \
in-interface=lo src-address=127.0.0.1
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
in-interface-list=WAN
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" \
dst-port=33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
add action=fasttrack-connection chain=forward comment="defconf: fasttrack6" \
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/system clock
set time-zone-name=Europe/Amsterdam
/tool mac-server
/tool mac-server mac-winbox
Just to be sure, I checked before and after upgrading the firmware. The upload speed is always slow. Both when laptop is on cable or when connected to the wifi.
I cannot really imagine this thing would be DOA ?
Thanks!
