Some VLAN questions regarding small home network
Hi All,
After watching some videos, and reading some text, user manuals forums also this here: Using RouterOS to VLAN your network I have some basic questions to the experienced users regarding VLAN.
My HW setup looks like the following:
1 hex s 2025 as router
1 linksys unmanaged switch (part of the setup independently from the future CSS318!)
1 soon to be CSS318-16g-2s switch
2 cap AX (1 for each floor)
This is a 2 floor little house. All LAN cables are routed to the basement where the switch will sit, some end devices like TV, Pi, homeassistant, PC will have LAN connection, others like phones tables will use the cap AX wifi.
My SW setup so far on the hex s, looks like this:
I currently setup all devices under 192.168.2.xxx/24 this is enough for me. eth1 on hex s is WAN. I did my LAN segmentation by grouping different devices and sorting them out by IPs such as:
Mikrotik devices sitting under 192.168.2.1- 10
home assistant and all IoT is 192.168.2.200 - 250
home cinema is for example 192.168.2.100 - 130
every device currently which is connected to my network (cable or wifi) is having a fix IP given by the hex s DHCP via MAC. nothing is dynamically allocated.
hex s also having wireguard running under 192.168.10.x (finally I managed to set that up :smiley: )
Firewall rules, defconf copy mikrotik + a couple of test rules which I posted about in the past.
Now I would like to turn to the VLAN side of the setup, where I am in the planning phase (collecting IP ranges, grouping devices, creating rules on paper). In order to plan properly I have some questions regarding VLAN. Before the questions I would like to share the aim and reason for VLAN.
a) I have some devices which I would like to expose to Internet, but strictly not to LAN so like a DMZ.
b) I have IoT devices where I would like to disable Internet and LAN access so isolate them 100%, it is running good if I pull the WAN plug right now, so it should be :slight_smile: In case of SW/FW update I disable the firewall rule, do the update via OTA and then enable the rule again.
c) I have some 100% trusted devices which I consider as management devices, those should see everything no matter what
d) guest wifi, dynamic DHCP range, should be no LAN access, but internet
And the questions:
  1. Can I do a setup where I leave my core mikrotik devices in the range 192.168.2.1 - 10 and then create a VLAN with ID 30 for IoT but only for the range 192.168.2.200 - 250. ?
1a) Does it make sense to leave mikrotik devices out of the VLAN? or any other device? Or it would be preferred to add them to the management VLAN?
  1. executing the aim/rule (b) above I have some IoT devices like HomePod, whom I would like to keep the Internet connection, but if I apply any filter for the whole IoT range the homepods are in there... Is it possible to create a firewall rule to VLAN ID 30 but exclude 1 IP out of it? Does this make sense? :slight_smile:
  2. I read a lot about SAFE MODE and I can shut myself out, but if my understanding is correct, the hex S does not do anything VLANs until the firewall rules are not there. Is this correct? So in other words I can create bridge, VLANs (IoT, management, etc...) start tagging and until I not start to implement any firewall rule I am safe, or am I missing something?
  3. Reading this Forum guide (link on the top) I do not really want my mikrotik switch to act like this blue, green, red setup --> Switch with a separate router (RoaS) a, because I bundle myself to fix IPs, is then this is a right understanding that I need trunk port setup everywhere?
  4. cap AX both are managed via hex S (CAPSMAN) in this case, I see wifi-1-2-3-4 in the Interfaces of hexS, so when I talk wifi needed VLANs, then I need to do this over those wifi-1-2-3-4 right?
  5. Last but not least, Is there a simple way to do this? Do I overcomplicate it? I thought with the fix IP setup and the strict no dynamic DHCP allowed I would be half way in the winner side, seeing tutorials it looks also easy just add VLAN ID 10/20/30 with different IPs, firewall and job done, but then some setups / tutorials (like this tutorial here with the color coding) starts to talk about interface VLANs and this is really something which I cannot do.
Thank you for the answers from all of you in advance!
You may think that is segmentation because you are using different ip addresses, but it is only letting you know what the devices are based on their given ip address.
But there is no segmenation. All your devices are in the same broadcast domain and the same subnet.
And the firewall will have no ability to limit what "on LAN" conversations take place. The packets won't even get to the routing engine, the devices within the same subnet discover each other using ARP broadcasts, to learn the other device's MAC address, and then the communication between host in the same subnet are direct between the two hosts using the learned MAC addresses; the routing engine is not involved at all, the communication is at layer 2. (this is all covered in networking fundamentals)
You need to first understand what vlans are. Vlans can only do what you could do with extra switches, ethernet interfaces and wires. It is only a mechanism to "share resources", nothing more, nothing less.
Google query what vlans are and what they are not
This is what I recommend watching concerning vlans. If it doesn't sense, you need to go back to networking fundamentals.
This isn't intended to be a putdown; I just don't know how you are going to be able to make a good network plan without first understanding what vlans are.
Based on the above, one option would be to change your network mask from /24 to something like /26 or /27, which would then give you subnet blocks with either 64 or 32 addresses. Your address space would remain similar, but routing would move to L3, enabling what you want to do. It all depends on how much address space you want for each . . . . multiple full blocks would work as well, and identify the group by the 3rd octet (hecl, the VAN number could match the octet to make is simple to associate.
Yes, but he is still going to need to change his config. He is using dhcp, he just has static reserved addresses.
From https://www.calculator.net/ip-subnet-calculator.html?cclass=any&csubnet=26&cip=192.168.2.100&ctype=ipv4&x=Calculate
So the "home cinema" is going to be affected, as 192.168.2.100-192.168.2.130 won't fit into any of the possible /26 subnets.
And if he is going to need to redo his config, I see no advantage to using anything but /24. So what if it is more "address space than is needed?" He could still limit the ip addresses being served out with the pool settings.
I don't think he needs the extra complexity of non-octet aligned subnets. He has enough other things to learn and worry about (in my opinion).
But I am afraid that once he does segment the network, he will be back soon after asking how to get things to work that used to work (because before they were all in the same subnet), and things like dlna won't work across networks (at least cleanly).
Not putdown at all :slight_smile: i like when other people can share more training videos, tutorials because sometimes my search is limited therefore the information what i get in is also limited.
I really liked the Forum article here Using RouterOS to VLAN your network also later in the comment section there are tons of interesting discussion on firewall setups, and details. Obviously at the moment I might be able to understand 20% of it :smiley: but yeah... Mikrotik is a learning curve and I am just started it.
For example from: Using RouterOS to VLAN your network i figured out that on my hex S router probably I need trunk ports for all separate VLANs. (that is what i also wrote that I do not have enough switch or setups to do access ports how it is shown in the example pictures) Also I should have 1 single bridge and deal all VLANs under that. I also plan to leave for example eth4 out of the bridge and use it as management port (I need to check if I have enough physical ports left in my plan, but this is also one of the reasons I added that I have linksys unmannged switch(es) and I hope that will do not remove / modify the VLAN tags.)
You are right for sure on the current setup that there is no segmentation, that is because I just started to plan the different IPs / VLANs / rules what I kind of want. So in my mind take rule #b IoT devices currently running under 192.168.2.xxx assuming they get a tag of 20, then to be consistent with IP they become 192.168.20.xxx (all of them) and then apply firewall rule for VLANtag 20 no internet, no LAN access (inside their own subnet 192.168.20.xxx they can all communicate locally for sure) and then test it if works and that's it :slight_smile: :slight_smile: of course it is simple to write that down :smiley: from my point of view that is a segmentation. Same like rule #a the generic DMZ, those devices must go to Internet, zero access to LAN what so ever and also not able to communicate with each other (the last sentence here is not so important, but it would be cool if i could do it, however so far no clue how :smiley: )
I am going to check all articles and videos what you shared and thank you for that. I need time for this and I will get back here once I am done.
This is an interesting alternative solution if I understand right and I also checked the calculator.net link from @Buckeye below your post. I would not like to go as of right now this way, however I will keep it as a backup idea for sure :slight_smile:
Speaking out load... It might be a good solution where I asked if I can keep homeassistant at the far end of the 192.168.2.xxx section and still use Mikrotik in the beginning of that. Question 1) basically the top and bottom row from the table :slight_smile: and then this does not require VLAN, maybe i create an address list in the firewall, load the full IoT section there and create the firewall rules out of it :slight_smile:
So it won't solve all my issues, but some for sure, if I understand correctly...
I also need to think what to do with Siemens devices, which has a Siemens APP, so they are communicating and sending notifications via the APP, right now part of the homeassistant bucket, but I assume as soon as I cut the Internet for them, they won't work so question 2) will come into play here as well and on top for the homepods :slight_smile: As a rough idea i can create 2 IoT address list to separate those IPs out and allow Internet to them...
@Buckeye mentioned something about "dlna" and "how to get things to work that used to work" so that I need to think for sure. However as of now my homeassistant is really only using smart devices, no TV, no other home entertainment stuff... that is separate, which i assume will work together as they should be part of one VLAN. Tricky thing would be how to deal with management VLAN iphone if I would like to access home entertainment NAS via iphone VLC app using UPNP or SMB. So yes, plan, setup, test and if not working I am always asking google first or reading other articles/forums etc... :slight_smile: But I could also end up here again :smiley:
So after reading mildly into this: https://www.practicalnetworking.net/stand-alone/vlans/ and do some googling, I realised that I might be kneel down with my unmanaged Linksys switch. I always thought that a switch is a switch, but I am now under the impression that in VLAN articles and tutorials a switch is 100% a managed switch. So I either need to rethink a bit on the HW side what to do...
A managed switch is not so expensive, linksys LGS310C is like 30 EUR and to keep the brand mikrotik 260GS is like 34 EUR... Or I need to live with the limitation than an unmanaged switch will only work within 1 single VLAN (which might be handy for me to plug home cinema stuff on it Pi, TV, AVR + 1 port reserve)
Generally speaking unmanaged switches do switch traffic "transparently", i.e. they leave a packet tagged (say) VLAN200 go to the destination as tagged VLAN200, and a packet with no VLAN tag as not tagged.
So they can be normally used in VLAN managed network, knowing how they behave, unless there is the need of removing or adding the VLAN tag on a given port.
Well... where I tried to deploy the linksys LGS105 i planned to have VLAN20 and 30 for example. Now I solved this problem by physically removing the VLAN30 device (because this is a single device :slight_smile: ) from the LGS105 and keep only VLAN20 stuff in there (TV, AVR and PI) and if my understanding and googling is correct, then VLAN20 with tag will remain from mikrotik hex s through LGS105 to end-device. This is why I consider myself lucky, i am only in the planning phase, I have rules, I have end devices, i kind of know what I would like to see and how, but when it comes such limitiations I need to quickly readopt everything :slight_smile:
Generally the problem around the switch choice is that unmanaged and managed switches are very different animals.
It is absolutely true that unmanaged switches (at least the ones I've seen) pass vlan tagged traffic as-is. It's kind of obvious that they can't be configured to tag/untag.
But the differences are deeper: vlan-aware switches do something called independent vlan learning (IVL) which means that their CAM stores the vlan id together with the MAC. Unmanaged switches don't do this. This doesn't usually cause problems, just something to be aware of.
Then there's the problem of link-local MACs, which carry LLDP (which is kind of critical for ip phones) and STP. Some switches forward these blindly, some discard these. Both behaviors can become uncomfortable.
Just to make this even harder, there is the question of "smart" switches. A vlan aware switch can easily become a security boundary, such as isolating your DMZ, etc. The security of these smart switches is abysmal. Proper managed switches can cost quite a bit more.
Honestly, if you don't need a lot of ports (or a weird combination), often the best switch replacement is another cheap Mikrotik. Even the cheaper devices have full switch functionality, and despite the attitude on this forum, Mikrotik actually cares about security. For many of the usual players (tp-link, dlink, etc.) there are known vulnerabilities that simply aren't fixed.
As to your network segmentation problem: vlans isolate networks (or if you will, broadcast domains,) and very much of the confusion around them comes from not understanding and accepting this. Once you isolate these networks they will only be able to communicate through routing and will interact with its firewall (which is the goal.) So regardless of how the IP addressing is done they will not be able to communicate directly. This is so even if a /26 is used. I would recommend for your own sanity to go with the more usual /24.
Hi, first of all thank you for the deeper explanation on the switch vs switch section. As you mentioned and I also checked a simple managed mikrotik switch with 5 ports is 34eur in my country. I spent already a couple hundred to create a fully mikrotik branded setup. Exactly the similar reasons what you mentioned vs other vendors. So another 34 eur is not hurting if needed. But I like to experience and for sure I will try first with my linksys HW line. If I see no issues there I keep it, but if i have problems i will just simply replace it.
On this quoted section, this is really my plan to have separate VLANs, and the hexS via firewall will enable or disable what is needed. I just really need to wrap my head around the different setups because first :slight_smile:
I'm not a fan of Mikrotik's smaller non-Marvell switches. I'd much rather use a hEX. The old one has 5 switched ports, the Refresh has only 4.
The CSS106-5G-1S (aka RB260GS) is the only Mikrotik "switch" I own. I also have an RB760iGS.
I really like the CSS106-5G-1S as a network tap. It is a lot more flexible than for example a Netgear GSx05E. With port isolation you can use the same switch to tap the in and out ports of a device, so you can see effect of tagging or NAT on traffic going through the "device under test".
SwOS has a much simpler interface than ROS, but also a lot more limited (in general). If you already have an understanding of ROS, then using a hEX as a 5 port switch makes more sense, because then you only have one "language" to learn.
What were your reasons for preferring hEX over CSS106-5G-1S? (ROS vs SwOS or something else)?
First you need to decide how many ip networks you need. Each network will have a non-overlapping ip address range (and I would recommend using /24 for each one, whether you have 2 devices or 200 in the network).
Whan you say you have some devices you want to expose to the internet "like a DMZ", what exactly do you mean? Do you have a web server or something you want to be able to access from the internet without any vpn involved? If you do decide to do this, be aware that it has a much higher risk than accessing the internet from the inside.
There are relatively easy ways to be able to access your home assistant without needing general access. e.g. tailscale home assistant
With your existing hex s 2025 will allow you to connect your 2 cAP ax with trunk ports to allow having mulitple wifi networks (SSIDs) corresponding to your home assistant devices, trusted devices, and guest devices.
But it seems you want your home cinema to be kept separate from trusted devices and your home assistant network.
You also said that for some of your devices, you did not want them to be able to connect to the internet (at least not without special permission that you would enable and disable). As long as these devices are on their own network, it it relatively easy to block internet (either exit interface, by source "network", or by source address list, or by individual source ip address.
These are the possible separate networks I see:
  1. trusted home devices and management.
  2. guest (probably only wifi needed, but you can also provide an access port for testing)
  3. home assistant - I assume by home assistant you mean home control, not devices like "Google Home or Amazon Echo)
  4. iot that need internet - this could include your home cinema, amazon echo, google home, etc.
  5. devices you don't want to have internet access.
  6. DMZ
You can continue to use unmanaged switches, but I would recommend doing it only as a way to "replicate" ports for a single subnet.
I would recommend using the config generator to create a config for multiple vlans. It does the "heavy lifting" of configuring the vlans and firewall.
Unfortunately you don't have another mikrotik router you can play with, because it's much less stressful when what you do won't affect all other devices in your network. And when the cost of trying things is low (you may need to reset it), you are much more likely to actually play and learn, than when a mistake may cause the home to loose internet access.
If you did get another hEX S 2025, it could be use as a learning device while still acting as a spare in case you had problems with the existing hEX S 2025. Or you could use it as a 4 port "managed" switch in case you had a single wire going to a room and you wanted to connect wired devices to different vlans.
"Unfortuneately you don't have another mikrotik router you can play with,"
@Buckeye VMWare workstation is free, just launch a vm with mikrotik in trial mode, then he can play arround all he wants :slight_smile:
You're not far from guessing my reason. I don't really like SwOS (or any of the other implementations of the same type) because when I choose a Mikrotik device I expect flexibility. SwOS with its really basic and custom networking stack and lack of things like any way to connect to it securely is anything but. I expect ssh, winbox, and I really like to use wireguard for management.
It really doesn't help that there is the weird switch rule based configuration for vlans. I suspect that there is a hardware reason for that.
According to the official pricing, the difference between the rb260 and the hEX is USD 40 vs 60. For me it's worth the plus 20 to have a device that can do bridge offloading in the normal way.
Here are several disadvantages of the RB760iGS as a switch compared to the CSS-106-5G-1S
If you are using jumbo frames > ~2K size the MT7621 won't work. If you don't use jumbo frames this makes no difference.
On the RB760iGS the SFP is handled by the CPU.
The CSS106-5G-1S uses the Qualcomm Atheros QCA8337 switch chip, a 7 port GB switch (one port dedicated to internal management CPU (Taifatech TF470) according to https://cdn.mikrotik.com/web-assets/product_files/RB260GS-140417124849_140449.pdf or STM32F107 RBT6 according to this (https://saturn.ffzg.hr/rot13/index.cgi/mikrotik_rb260gs.pdf?action=pdf_export;page_selected=mikrotik_rb260gs) The CPU as far as I know is only for the web interface and management functions), no NAT or routing functions. So if using the SFP port, the performance may be better with the CSS106-5G-1S.
Of couse the CSS106-5G-1S has all the disadvantages of SwOS (only http, not https or ssh), no CLI. All the things that @tangent discusses in his why you should use ROS on your MikroTik switch page. edit: include link Run RouterOS on Your Switch
Yes, true and I also would like to (plan) go with the /24 setup.
It is easy right now: one XBOX on wired connection and one work laptop on wired and wireless connection. The PHYSICAL LOCATION is the tricky one, let me tell you why:
Xbox is in the living room in the ground floor sitting in the same cupboard next to AVR, TV, Pi(Kodi). In this cupboard sits the hex S and the main WAN Router. Cupboard is quite full :slight_smile: all connection is wired!
For those 4 devices (XBOX, TV, AVR, Pi) I thought I will use my linksys unmanaged switch, now I learned this is won't work, so I said I will keep the linksys for (TV, AVR, Pi) as they planned to be the same VLAN and simply I take the XBOX wired connection and plug it in to the WAN Router. So XBOX is 100% exposed to Internet, and now I need to look for a solution to block all incoming traffic from XBOX to hex S (all my devices have fixed IP, so I plan to block it in the hex S firewall on MAC or IP. Reason behind, I want XBOX out open as possible (xbox gaming services sometimes have troubles with double NAT, firewall etc... it is a mess... so I want the XBOX status on OPEN NAT, whatever this means to microsoft :D) and in the mean time if somebody screws up my xbox from the outside, at least I want to protect my inner LAN so that the colleague cannot penetrate further... WAN Router has some telekom based firewall pre installed, I use it in the past 12 years, never had problem, now I will add a little bit of more security with the hex S LAN setup, therefore I consider myself on the safe side still. Might be not the safest, but OKish :slight_smile:
For me DMZ = exposed to internet 100%, NO ACCESS to my main LAN or any other VLAN whatsoever. I have no webserver, not planning either, maybe 10 years later when kids start to learn programming, I had my own webserver when i was a kid it was enough :smiley: :smiley: :smiley:
In this case I do not understand your comment: "much higher risk", I do not see this as a risk if I drop all incoming request in the hex S from WAN side when source IP or source MAC is XBOX... Or am i missing something basic thing ? :slight_smile:
The working laptop is also easy, it is not my laptop and I am using VPN on it, so I want the laptop outside to the Internet as much as possible. It is well protected by the company, I do not need to think here :slight_smile: However my workstation is located at the basement, there I will have one capAX for wireless, and 1 wired connection, but I am already inside the LAN, so I need some sort of DMZ VLAN i assume. Right now I am watching this tutorial: https://www.youtube.com/watch?v=Vt3MnPARjfs And figuring out if this is something what I am looking for or not.
I need to check this, this is new to me :slight_smile: MANY THANKS! I have WireGuard setup and working and I tested it I can connect from the outside world into my "local area", I am also planning to build on that setup in the future :slight_smile: I never used WireGuard in my life, so it was a great challenge and learning curve to set it up.
Currently I am using 2 wifi SSIDs (1 for 5G and 1 for 2,4G) The future setup will be 1 cap AX in the living room, 1 cap AX is the basement (so 2 floors are covered) I wanted to keep the SSIDs (might not be possible, still planning phase) and yes what I learned so far it will be a TRUNK port and wifi needs to handle smarthome / home assistant devices (fridge, SMLIGHT zigbee, custom ESP32 868Mhz antenna, homepod, etc...) the main homeassistant server running on a Pi will be wired in the basement. Then I have my own laptop, phones, tablets etc... those can be in the TRUSTED MGMT vlan as you said.
I saw in a tutorial there is multipasspharse setup as well, this I like sooo much, but I am not sure if it is good for me especially when it comes to wifi encription, so for GUEST VLAN = 100% wifi and either multipasspharse or I just create a new SSID -GUEST and that's it. GUEST easy, only Internet is allowed nothing else.
1 is 100% correct
2 correct only wifi planned now
3 is something which I want to connect with 5 BUT (in my mind homepod and fridge is part of homeassistant, so if I remove the internet from them, it might be tricky) maybe there is way to expose those by address list etc... also group 3 should not see any other VLAN or LAN whatsoever, so if there is a breach via any stupid smart device at least the breach must be contained and kept inside the "smarthome" world :slight_smile:
4 also correct for TV, AVR, Pi etc... If needed I can eliminate this and move them to group 1 or I can rethink this group as smarthomeWITHINTERNET :slight_smile: so all from group 3 who needs it constantly will sit here. and then allow VLAN group 3 and 4 to talk to each other.
6 yes correct, pure Internet, zero local network.
Reading more on hex S setup and VLANs, if my understanding is correct, BY DEFAULT the layer 3 routing hex S is allowing connection between VLANs so basically it still does not matter what VLANs i create they are going to see each other UNTIL THAT MOMENT when I start to create firewall rules and starting to block certain accesses/ ports/ etc... Is that correct?
Will do and this is currently the plan.
I need to check this, this is new to me as well :slight_smile: Thank you!
True, i go with safe mode + as mikrotik first time users guide says, backup after each major step. During my initial config when I just setup my WAN - hexS + DHCP I made like 6 backups and managed to do something stupid so full reset was done like 2-3 times :smiley: it is what it is :slight_smile:
This is also a good idea, + as you wrote i can use it is a managed switch later. Currently in my HW line up I have a CSS318-16g-2s switch This will go to the basement, and it has SwitchOS, so I need to learn that as well. I will make it :slight_smile: (maybe a CRS326-24G-2S+IN would be better as first choice, but I have my CSS318 so I go with that ) if needed the CSS106-5G-1S is also not sooo expensive then comparing to hex S as @lurker888 said another 20 bucks. You detailed out some pro/con between the 2. So if i need to buy an extra one, i will consider those thoughts !
Full details are in the article @Buckeye referenced but did not link: Run RouterOS on Your Switch
After today's learning curve, tutorials and reading, i might narrow down my final VLAN groups simply these:
.10.xxx - mgmt (currently .10.xxx wireguard is running here, but maybe it is good to have wireguard also couple with VLAN 10, anyhow this is a small home, i am the only one using wireguard :slight_smile: ) + mikrotik router, switch, my main laptop, etc...
.20.xxx - TRUST, all my current trusted devices, TV, NAS, Pi, home PCs, laptops, etc... (I really do not have untrusted... Toniebox, and kids learning tablet, i will shovel it to DMZ :slight_smile: )
.30.xxx - HOMEASSISTANT, all smart home related items, i will put fridge, homepod all into this, set the rule NO INTERNET, NO LAN so it is fully isolated, then I check if based on fix IP, I am able to enable internet for fridge. Firewall rules going in order, so I am planning to allow Internet to fridge IP, the DROP ALL should work :slight_smile: will see.
.50.xxx - DMZ / GUEST / zero LAN access what so ever, just internet
Where I am currently thinking: what happens if I merge MGMT and TRUST, and just go with 3 groups? Then Mikrotik devices, will sit on the same VLAN as my TV. So in a very unlucky situation if somebody hacks my tv, has also "access" to the mikrotik device (or at least can reach it :smiley: ) sounds not so secure, but probability is.... If I keep them separate, then no issue, if TV is hacked, it is still stucked within VLAN where nothing important sitting.
So
