If I had not seen it with my own eyes, I would never have believed that disabling the LCD had any effect. But it did!
With disabled LCD I got ~500Mbit at my first speedtest. Unfortunately it looks like this was a one-time shot. I was not able to reproduce it (even with some JDownloader download tests).
But anyhow I do get more then before. Around ~400 - 450MBit. Maybe there is still something to “tune”.
I also
Here is my whole config for reference. I’ve deleted my firewall adress lists (because the firewall was deleted / disabled at this point (I left only the fasttrack rules in place because without them speed dropped to 140MBit)), dhcp-leases and obfuscated my domain-things for privacy reasons.
# dec/11/2021 16:44:04 by RouterOS 7.1
# software id = LVGI-H82J
# model = RouterBOARD 3011UiAS
# serial number = B8950BD1D59A
/interface bridge add name=BR_LAN priority=0xF000 vlan-filtering=yes
/interface ethernet set [ find default-name=ether1 ] loop-protect=off name="ether1 - switch-sz"
/interface ethernet set [ find default-name=ether2 ] name="ether2 - switch-wz"
/interface ethernet set [ find default-name=ether3 ] name="ether3 - switch-kg"
/interface ethernet set [ find default-name=ether9 ] name="ether9 - UPC"
/interface ethernet set [ find default-name=ether10 ] name="ether10 - AP-Wohnzimmer"
/interface ethernet set [ find default-name=sfp1 ] name="sfp1 - switch-sk"
/interface vlan add interface=BR_LAN name=VLAN_MGMT vlan-id=10
/interface vrrp add authentication=simple interface=VLAN_MGMT name=VRRP_PIHOLE_DNS on-backup="/ip dns set allow-remote-requests=no\r\
\n/ip dns set servers=192.168.100.246" on-master="/ip dns set allow-remote-requests=yes\r\
\n/ip dns set servers=1.1.1.1,9.9.9.9" version=2 vrid=2
/caps-man security add authentication-types=wpa2-psk encryption=aes-ccm group-encryption=aes-ccm name=wifi
/interface list add name=LIST_WAN
/interface list add name=LIST_LAN
/interface lte apn set [ find default=yes ] ip-type=ipv4
/interface wireless security-profiles set [ find default=yes ] supplicant-identity=MikroTik
/ip ipsec mode-config add name=l2tp-vpn-mode-config static-dns=192.168.100.246 system-dns=no
/ip ipsec profile add dh-group=modp1024 enc-algorithm=aes-256,3des name=l2tp-vpn-peer-profile
/ip ipsec proposal add enc-algorithms=aes-256-cbc,3des name=l2tp-vpn-proposal pfs-group=none
/ip kid-control add fri=6h-20h mon=6h-20h name=Sandro sat=6h-20h sun=6h-20h thu=6h-20h tue=6h-20h wed=6h-20h
/ip pool add comment="Network: 192.168.100.0/27" name=dhcp-lan ranges=192.168.100.1-192.168.100.30
/ip dhcp-server add add-arp=yes address-pool=dhcp-lan interface=VLAN_MGMT name=DHCP-LAN
/port set 0 name=serial0
/routing bgp template set default as=65530 disabled=no name=default output.network=bgp-networks
/routing table add fib name=""
/snmp community add addresses=192.168.100.210/32 encryption-protocol=AES name=phpipam write-access=yes
/system logging action add name=synology remote=192.168.100.251 remote-port=5014 src-address=192.168.100.254 target=remote
/user group set full policy=local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,password,web,sniff,sensitive,api,romon,dude,tikapp,rest-api
/user group add name=prometheus policy=read,winbox,api,!local,!telnet,!ssh,!ftp,!reboot,!write,!policy,!test,!password,!web,!sniff,!sensitive,!romon,!dude,!tikapp,!rest-api
/user group add name=homeassistant policy=read,api,!local,!telnet,!ssh,!ftp,!reboot,!write,!policy,!test,!winbox,!password,!web,!sniff,!sensitive,!romon,!dude,!tikapp,!rest-api
/interface bridge port add bridge=BR_LAN frame-types=admit-only-vlan-tagged ingress-filtering=no interface="sfp1 - switch-sk"
/interface bridge port add bridge=BR_LAN frame-types=admit-only-vlan-tagged interface="ether1 - switch-sz" pvid=10
/interface bridge port add bridge=BR_LAN frame-types=admit-only-untagged-and-priority-tagged interface="ether2 - switch-wz" pvid=10
/interface bridge port add bridge=BR_LAN frame-types=admit-only-untagged-and-priority-tagged interface="ether3 - switch-kg" pvid=10
/interface bridge port add bridge=BR_LAN frame-types=admit-only-untagged-and-priority-tagged interface=ether4 pvid=10
/interface bridge port add bridge=BR_LAN frame-types=admit-only-untagged-and-priority-tagged interface=ether5 pvid=10
/interface bridge port add bridge=BR_LAN frame-types=admit-only-untagged-and-priority-tagged interface=ether6 pvid=10
/interface bridge port add bridge=BR_LAN frame-types=admit-only-untagged-and-priority-tagged interface=ether8 pvid=10
/interface bridge port add bridge=BR_LAN frame-types=admit-only-untagged-and-priority-tagged interface=ether7 pvid=10
/interface bridge port add bridge=BR_LAN frame-types=admit-only-untagged-and-priority-tagged interface="ether10 - AP-Wohnzimmer" pvid=10
/ip neighbor discovery-settings set discover-interface-list=all
/ip settings set max-neighbor-entries=8192 rp-filter=loose
/ipv6 settings set disable-ipv6=yes max-neighbor-entries=8192
/interface bridge vlan add bridge=BR_LAN tagged="BR_LAN,sfp1 - switch-sk,ether1 - switch-sz" vlan-ids=10
/interface bridge vlan add bridge=BR_LAN tagged="BR_LAN,sfp1 - switch-sk,ether1 - switch-sz,ether2 - switch-wz" vlan-ids=100
/interface bridge vlan add bridge=BR_LAN tagged="BR_LAN,sfp1 - switch-sk,ether1 - switch-sz,ether2 - switch-wz" vlan-ids=20
/interface bridge vlan add bridge=BR_LAN tagged=BR_LAN,ether8 vlan-ids=30
/interface l2tp-server server set allow-fast-path=yes authentication=mschap2 default-profile=l2tp-vpn-profile enabled=yes max-mru=1460 max-mtu=1460 one-session-per-host=yes use-ipsec=yes
/interface list member add interface="ether9 - UPC" list=LIST_WAN
/interface list member add interface=BR_LAN list=LIST_LAN
/interface list member add interface=VLAN_MGMT list=LIST_LAN
/interface ovpn-server server set auth=sha1 certificate="VPN Server" cipher=aes256 default-profile=ovpn-vpn-profile port=80
/interface sstp-server server set authentication=mschap2 max-mru=1600 max-mtu=1600 mrru=1600 pfs=yes port=55555 tls-version=only-1.2
/ip address add address=192.168.100.254/24 interface=VLAN_MGMT network=192.168.100.0
/ip address add address=192.168.100.246/24 interface=VRRP_PIHOLE_DNS network=192.168.100.0
/ip cloud set ddns-enabled=yes update-time=no
/ip dhcp-client add interface="ether9 - UPC" use-peer-dns=no use-peer-ntp=no
/ip dhcp-server network add address=192.168.100.0/24 dns-server=192.168.100.246 domain=acme.lan gateway=192.168.100.254 netmask=24 ntp-server=192.168.100.210
/ip dhcp-server network add address=192.168.101.0/24 dns-server=192.168.100.246 domain=iot.acme.lan gateway=192.168.101.254 netmask=24 ntp-server=192.168.100.210
/ip dns set allow-remote-requests=no servers=1.1.1.1,9.9.9.9
/ip dns static add address=192.168.100.251 name=home.acme.com ttl=1m
/ip dns static add address=192.168.100.253 name=poseidon.acme.lan ttl=1m
/ip dns static add address=192.168.100.246 name=pihole.acme.lan ttl=1m
/ip dns static add address=192.168.100.252 name=apollon.acme.lan ttl=1m
/ip dns static add address=192.168.100.210 name=ntp.acme.lan
add action=fasttrack-connection chain=forward comment=fasttrack connection-state=established,related hw-offload=yes
add action=accept chain=forward comment="accept established,related, untracked" connection-state=established,related,untracked
/ip firewall nat add action=dst-nat chain=dstnat comment="SSH to zeus 22" dst-port=8080 in-interface-list=LIST_WAN protocol=tcp to-addresses=192.168.100.211 to-ports=22
/ip firewall nat add action=dst-nat chain=dstnat comment=wireguard dst-port=51820 in-interface-list=LIST_WAN protocol=udp to-addresses=192.168.100.210 to-ports=51820
/ip firewall nat add action=dst-nat chain=dstnat dst-port=443 in-interface-list=LIST_WAN protocol=tcp to-addresses=192.168.100.210 to-ports=443
/ip firewall nat add action=dst-nat chain=dstnat comment=temp_rule_for_letsencrypt_do_not_change dst-port=80 in-interface-list=LIST_WAN protocol=tcp to-addresses=192.168.100.210 to-ports=80
/ip firewall nat add action=masquerade chain=srcnat comment="lan --> internet" out-interface-list=LIST_WAN src-address=192.168.100.0/24
/ip firewall service-port set ftp disabled=yes
/ip firewall service-port set tftp disabled=yes
/ip firewall service-port set irc disabled=yes
/ip firewall service-port set h323 disabled=yes
/ip firewall service-port set sip disabled=yes
/ip firewall service-port set pptp disabled=yes
/ip firewall service-port set udplite disabled=yes
/ip firewall service-port set dccp disabled=yes
/ip firewall service-port set sctp disabled=yes
/ip kid-control device add mac-address=7A:E8:FB:1A:E6:0B name="iPad Sandro" user=Sandro
/ip kid-control device add mac-address=40:A2:DB:B4:18:2D name="Sandro FireTV Stick" user=Sandro
/ip proxy set anonymous=yes port=3128
/ip proxy access add src-address=192.168.100.0/24
/ip service set telnet address=192.168.100.0/24 disabled=yes
/ip service set ftp address=192.168.100.0/24 disabled=yes
/ip service set www address=192.168.100.0/24 disabled=yes
/ip service set ssh address=192.168.100.0/24
/ip service set www-ssl address=192.168.100.0/24 certificate=wildcard.acme.lan disabled=no tls-version=only-1.2
/ip service set api address=192.168.100.0/24
/ip service set winbox address=192.168.100.0/24
/ip service set api-ssl address=192.168.100.0/24 certificate=wildcard.acme.lan tls-version=only-1.2
/ip ssh set always-allow-password-login=yes forwarding-enabled=both strong-crypto=yes
/ip traffic-flow set cache-entries=8k
/ip upnp set enabled=yes
/ip upnp interfaces add interface="ether9 - UPC" type=external
/ip upnp interfaces add interface=VLAN_MGMT type=internal
/lcd set backlight-timeout=never default-screen=stats enabled=no read-only-mode=yes time-interval=daily touch-screen=disabled
/lcd interface set "ether1 - switch-sz" disabled=yes
/lcd interface set "ether2 - switch-wz" disabled=yes
/lcd interface set "ether3 - switch-kg" disabled=yes
/lcd interface set ether4 disabled=yes
/lcd interface set ether5 disabled=yes
/lcd interface set "sfp1 - switch-sk" disabled=yes
/lcd interface set ether6 disabled=yes
/lcd interface set ether7 disabled=yes
/lcd interface set ether8 disabled=yes
/lcd interface set "ether10 - AP-Wohnzimmer" disabled=yes
/lcd interface pages set 0 interfaces="ether9 - UPC"
/lcd screen set 1 disabled=yes
/lcd screen set 2 disabled=yes
/lcd screen set 3 disabled=yes
/lcd screen set 4 disabled=yes
/lcd screen set 5 disabled=yes
/ppp profile add change-tcp-mss=yes dns-server=192.168.100.246 local-address=192.168.102.254 name=l2tp-vpn-profile remote-address=*3 use-encryption=required use-mpls=yes
/ppp profile add change-tcp-mss=yes dns-server=192.168.100.246 idle-timeout=30m local-address=192.168.102.254 name=ovpn-vpn-profile only-one=yes remote-address=*3 session-timeout=6h use-compression=no use-encryption=required use-mpls=yes
/ppp secret add name=florian.doe profile=l2tp-vpn-profile
/ppp secret add name=martina.doe profile=l2tp-vpn-profile service=l2tp
/ppp secret add name=florian.doe.ovpn profile=ovpn-vpn-profile service=ovpn
/snmp set contact="Florian Doe" enabled=yes location="Dream Lane 25"
/system clock set time-zone-name=Europe/Vienna
/system clock manual set dst-delta=+01:00 dst-end="oct/27/2019 03:00:00" dst-start="mar/31/2019 02:00:00"
/system identity set name=router-main
/system logging set 0 disabled=yes
/system logging set 1 disabled=yes
/system logging set 2 disabled=yes
/system logging add action=synology topics=interface
/system logging add action=synology topics=error
/system logging add action=synology topics=critical
/system logging add action=synology topics=info
/system ntp client set enabled=yes
/system ntp client servers add address=ntp.acme.lan
/system scheduler add interval=1d name="99_Daily Backup" on-event="Daily Backup" policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon start-date=aug/28/2014 start-time=04:00:00
/system scheduler add comment="Download spamnaus list" interval=3d name=DownloadSpamhausList on-event=DownloadSpamhaus policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon start-date=jan/01/1970 start-time=16:38:01
/system scheduler add comment="Apply spamnaus List" interval=3d name=InstallSpamhausList on-event=ReplaceSpamhaus policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon start-date=jan/01/1970 start-time=16:43:01
/system scheduler add comment="Download dshield list" interval=3d name=DownloadDShieldList on-event=Download_dshield policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon start-date=jan/01/1970 start-time=16:48:01
/system scheduler add comment="Apply dshield List" interval=3d name=InstallDShieldList on-event=Replace_dshield policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon start-date=jan/01/1970 start-time=16:53:01
/system scheduler add comment="Download malc0de list" interval=3d name=Downloadmalc0deList on-event=Download_malc0de policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon start-date=jan/01/1970 start-time=16:48:01
/system scheduler add comment="Apply malc0de List" interval=3d name=Installmalc0deList on-event=Replace_malc0de policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon start-date=jan/01/1970 start-time=16:53:01
/system scheduler add comment="Download voip-bl list" interval=3d name=Refresh_voip-bl on-event=Download_voip-bl policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon start-date=jan/01/1970 start-time=16:48:01
/system scheduler add comment="Apply voip-bl List" interval=3d name=Update_voip-bl on-event=Replace_voip-bl policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon start-date=jan/01/1970 start-time=16:53:01
/system script add dont-require-permissions=no name="Daily Backup" owner=admin policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="/file remove [find type=script]\r\
\n:log info \"backup beginning now\"\r\
\n:global backupfile ([/system identity get name] . \"-\" . [/system clock get time])\r\
\n/export terse file=\$backupfile\r\
\n:delay 5s\r\
\n/system backup save name=daily_backup\r\
\n:log info \"backup pausing for 10s\"\r\
\n:delay 10s\r\
\n:log info \"backup being emailed\"\r\
\n/tool e-mail send to=\"florian@acme.com\" subject=([/system identity get name] . \\\r\
\n\" Backup\") from=void@acme.com file=\$backupfile body=(\"This is an automated e-mail! Date is \" .\\ ([/system clock get date]).\\ \" time \".\\ ([/system clock get time]))\r\
\n:log info \"backup finished\""
/system script add dont-require-permissions=no name=DownloadSpamhaus owner=admin policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="\
\n/tool fetch url=\"http://joshaven.com/spamhaus.rsc\" mode=http;\
\n:log info \"Downloaded spamhaus.rsc from Joshaven.com\";\
\n"
/system script add dont-require-permissions=no name=ReplaceSpamhaus owner=admin policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="\
\n/ip firewall address-list remove [find where comment=\"SpamHaus\"]\
\n/import file-name=spamhaus.rsc;\
\n:log info \"Removed old Spamhaus records and imported new list\";\
\n"
/system script add dont-require-permissions=no name=Download_dshield owner=admin policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="\
\n/tool fetch url=\"http://joshaven.com/dshield.rsc\" mode=http;\
\n:log info \"Downloaded dshield.rsc from Joshaven.com\";\
\n"
/system script add dont-require-permissions=no name=Replace_dshield owner=admin policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="\
\n/ip firewall address-list remove [find where comment=\"DShield\"]\
\n/import file-name=dshield.rsc;\
\n:log info \"Removed old dshield records and imported new list\";\
\n"
/system script add dont-require-permissions=no name=Download_malc0de owner=admin policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="\
\n/tool fetch url=\"http://joshaven.com/malc0de.rsc\" mode=http;\
\n:log info \"Downloaded malc0de.rsc from Joshaven.com\";\
\n"
/system script add dont-require-permissions=no name=Replace_malc0de owner=admin policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="\
\n/ip firewall address-list remove [find where comment=\"malc0de\"]\
\n/import file-name=malc0de.rsc;\
\n:log info \"Removed old malc0de records and imported new list\";\
\n"
/system script add dont-require-permissions=no name=Download_voip-bl owner=admin policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="\
\n/tool fetch url=\"http://joshaven.com/voip-bl.rsc\" mode=http;\
\n:log info \"Downloaded voip-bl.rsc from Joshaven.com\";\
\n"
/system script add dont-require-permissions=no name=Replace_voip-bl owner=admin policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="\
\n/ip firewall address-list remove [find where comment=\"VoIP BL\"]\
\n/import file-name=voip-bl.rsc;\
\n:log info \"Removed old voip-bl records and imported new list\";\
\n"
/tool bandwidth-server set authenticate=no
/tool e-mail set address=192.168.100.210 from=void@acme.com
/tool graphing interface add
/tool romon set enabled=yes
/tool sniffer set filter-interface=*12 streaming-enabled=no streaming-server=192.168.100.242
/tool traffic-generator packet-template add data=random header-stack="" name=packet-template1
/tool traffic-generator stream add mbps=200 name=str1 packet-size=1500 tx-template=packet-template1
Cheers
Florian
