SXT AC best settings
wpa2 turns your link slower, use acl instead
/interface wireless
set [ find default-name=wlan1 ] band=5ghz-a/n
Perhaps setting wireless mode to 5GHz-onlyac or 5ghz-a/n/ac might also help (on both ends) ?
My bench testing with registration signal of -50dB is giving 450-500 Mbps UDP - but only 120Mbps TCP on 802.11 80Mhz Ceee WPA2-PSK
I’ll be testing other protocols and settings and post anything if it improves.
Note - radio’s are in bridge->station-bridge mode. I’m not using WDS as this can limit performance. See http://forum.mikrotik.com/t/what-is-wds-limitaiton-with-wireless-n/30429/1
what would be the recommended tx-power for a 150m length connection?
Can you post the test results and with what settings.
