SXT LTE6 KIT Beginner problems
I just got a SXT LTE6 (SXTR&FG621-EA) to connect a remote site to the Internet. I inserted a Telekom SIM, contected it with ethernet to my PC and switched it on.
Instant success. I opened the Website 192.168.188.1 and changed the password. LTE had a good connection. Then I started a firmware update. The SXT rebooted and I could connect to the Website again.
Unfortunately I had no internet connection more. Check for firmware updates failed.
Signal looks good on LTE, Pin is not necessary.
Adding a DNS Server did not help either. I used the APN internet and internet.telekom. The PC still connects on ethernet 1 to 192.168.188.1 but not further.
Where do I look next?
Best Regards Oli
I’am still trying to find my problem. I included the config below.
There is an IPv6 adress on the lte interface, not on the IPv4
The log shows that there is a DNS provided via lte:
It seems to me, lte is IPv6 only ? Any ideas?
Best regards Oli
mt.txt.rsc (5.8 KB)
Try disabling IPv6
/ipv6/settings/set disable-ipv6=yes
/system/reboot
Hello jaclaz,
thank you for your answer. I tryed it an it did not help. Still no Internet connection, even the internal-update does not work.
After I reactivated IPv6 I tryed to set the DNS to a IPv6, did not help either.
Best regards Oli
Post your complete configuration, follow these insteructions:
http://forum.mikrotik.com/t/forum-rules/173010/1
here is the config. The unit was new from the box.
Best regards oli
# 1970-01-02 00:42:25 by RouterOS 7.15.3
# software id = 4xxxxxxxx
# model = SXTR
# serial number = xxxxxxx
add admin-mac=Fxxxxxxxxx auto-mac=no comment=defconf name=bridge
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
add apn=internet.telekom use-network-apn=yes
/interface lte
set [ find default-name=lte1 ] allow-roaming=yes apn-profiles=\
    internet.telekom band="" sms-read=no
add name=default-dhcp ranges=192.168.188.10-192.168.188.254
add address-pool=default-dhcp interface=bridge name=defconf
/queue type
add fq-codel-ecn=no kind=fq-codel name=fq-codel-ethernet-default
/queue interface
set ether1 queue=fq-codel-ethernet-default
set ether2 queue=fq-codel-ethernet-default
/interface detect-internet
set detect-interface-list=WAN
add comment=defconf interface=lte1 list=WAN
add address=192.168.188.1/24 comment=defconf interface=bridge network=\
    192.168.188.0
add address=192.168.188.0/24 comment=defconf dns-server=192.168.188.1 \
    gateway=192.168.188.1
set allow-remote-requests=yes servers=8.8.8.8
/ip dns static
add address=192.168.188.1 comment=defconf name=router.lan
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    established,related,untracked
    connection-state=invalid
add action=accept chain=input connection-state=established
add action=accept chain=input connection-state=related
add action=drop chain=input in-interface-list=!LAN
/ip hotspot profile
/ipv6 firewall address-list
/ipv6 firewall filter
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" \
    dst-port=33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    500,4500 protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
/system note
set show-at-login=no
/tool mac-server
/tool mac-server mac-winbox
This:
/interface lte apn
May be the issue, you should edit the entry setting use-network-apn=no
See:
http://forum.mikrotik.com/t/lte-apn-with-fix-ip/139907/1
See also, it should be possible to disable it via GUI too:
https://blog.linitx.com/mikrotik-lte-how-to-configure-apn-settings-part-2-use-network-apn-issues/
Hello again,
thank you very much. “use-network-apn=no” did the trick. Now I have good connection and Internet is working.
I use the APN internet.telekom for my prepaid Telekom SIM
Best regards
Oli
Good. :slight_smile:
I wonder why in the late what? 4 years or so :open_mouth: , no Mikrotik developer thought to add a check-box for “use-network-apn” on the main Quick Set page (the one you posted screenshots of), given that the default is “yes” and this makes the manually entered apn not used (without any sign that it is not used, at the very least the textbox font colour should be gray and NOT black, like it was enabled).
Yet another sign of what I would call poor attention towards customer common problems, particularly for new users.
Maybe it is item #3147 in their low-priority to-do list. :question:
Even better and less confusing will be that use-network-apn config doesn’t even exists, if apn is set then it will be used, if not, network provided one will be used.
Yep, even better if there was a drop down list with an item “Automatic ISP APN” (or similar) fixed/not removable to which you can add your APN and then you are free to select either.
In CLI, an “auto” option could be added to
/interface lte apn
add apn=auto
That would allow the complete removal of use-network-apn.
It is more or less the same (IMHO illogical) logic behind the way you have to configure the auto-mac on bridge:
admin-mac (MAC address; Default: none) Static MAC address of the bridge. This property only has effect when auto-mac is set to no.
auto-mac (yes | no; Default: yes) Automatically select one MAC address of bridge ports as a bridge MAC address.
they could get rid of auto-mac adding a admin-mac=auto option.
Or they could at least rename the setting to use-network-apn-and-disable-the-one-you-typed-in :wink: :laughing:
I was thinking in a way how DNS Server has, there are config properties servers and dynamic-servers (read only), when servers is not set, dynamic-servers is used. But this with auto value is not bad idea (unless some MNO wants to name his apn to auto :slight_smile:). There are ways how to make it simple because this current way of setup is confusing at least.
