The Dude 7.21 cannot speak to my switch
I have a quite old switch, the ssh cannot be upgraded anymore.
when I connect my switch from the dude server it work:
[admin@MikroTik] > /system ssh 192.168.1.80 user=admin port=22
password:
* Copyright (c) 2010-2023 Hewlett Packard Enterprise Development LP          *
* Without the owner's prior written consent,                                 *
* no decompiling or reverse-engineering shall be allowed.                    *
<5130-1>
so it is OK, it uses the old less secure cipher and this fine.
but on the logs of my switch, I have this error all 12ish seconds:
Time2026-06-25 20:44:26
GroupSSHS
Level6
DigestSSHS_VERSION_MISMATCH
DescriptionSSH client 192.168.1.7 failed to log in because of version mismatch.
Is there a specific configuration on The Dude app for the ssh version ?
Regards,
Benoit.
The Dude is "abandonware", simply disable SSH probe.
Ok, it works.
but is there somethind to replace it ?
free, light, open source?
which can be able to listen the snmp of the switch and routers, and can be able to draw my network based on the mac addresses ?
Regards,
Benoit.
Check this:
