UDP OpenVPN Client Connects but no route
Hi, I am using a Mikrotik router so as to connect to my remote network through OpenVpn UDP protocol, I used RouterOS 7 beta, it connects but there is no route to Internet, can someone check my configs to see if there is any problem ?
I can’t use TCP protocol, so do you think isntalling OpenWRT on the router could be a better solution ?
