Under flood attack, how resolve this ?
On Italy "The ox says to the donkey: Horned! (cuckold) "
(Il bue dice all’asino “cornuto!”)
(BartoszP thanks for the IP)
It takes two donkeys to dance LOL. I just haven’t figured out which one to pay for the entertainment, let alone who is leading and who is following …
Now kiss and make up!!
Anav … PLEASE … try to avoid such comments .. they are TOTALLY UNNECESSARY direct personal attacks.
I will not moderate it as I shouldn’t do it being part of such abuse but they are REALLY against forum rules and netiquette and you deserve at last public warning: PLEASE STOP lowering discussion style to such stupid level as you presented.
If you write comments just for writing, increasing post counter and LOLing yourself then start your own one-man-show forum or just separate topic.
What do socks have to do with UDP flooding which is low as $5 from so-called “stressors”? DDoS for hire? @BartoszP
@tefots
The DDoS rules found here: https://help.mikrotik.com/docs/pages/viewpage.action?pageId=28606504
It can work for UDP as well, your rule order makes no sense
It should be like:
/ip firewall address-list
add list=ddos-attackers
add list=ddos-target
add action=jump chain=forward comment="Jump to DDoS detection" connection-state=new in-interface-list=WAN jump-target=detect-ddos
add action=return chain=detect-ddos dst-limit=50,50,src-and-dst-addresses/10s
add action=return chain=detect-ddos dst-limit=50,50,src-and-dst-addresses/10s protocol=tcp tcp-flags=syn,ack
add action=add-dst-to-address-list address-list=ddos-targets address-list-timeout=10m chain=detect-ddos
add action=add-src-to-address-list address-list=ddos-attackers address-list-timeout=10m chain=detect-ddos
#And finally RAW drop#
ip/firewall/raw/add chain=prerouting action=drop src-address-list=ddos-attackers dst-address-list=dddos-targets
But you’re missing out all crucial firewall files such as accept established/related on input and forward among other things.
I think it is time that you stop reacting the way you did in this topic and in many others.
It is not contributing in any way to this forum. Being Italian is no excuse for that.
Now back to the original topic:
You must first determine if the flood of UDP packets is filling your entire line capacity, or if it is only overwhelming your server or router.
When it is filling your line, there is nothing you can do! You will have to solve the problem at the other end of the line, i.e. at the ISP, and it is unlikely you can do that.
The issue starts with “i have a game server (hosted in my home)” and unfortunately you are not the only one with that problem.
The gaming community has many childish elements, that seem to like to destroy other people’s fun or -work.
When you want to be part of that community, it seems you need to have a thick skin and/or invest heavily e.g. in a server in a datacenter instead of at home, and with proper link capacity to withstand such childish behavior.
That is not something you can fix with a firewall rule here or there, because these people will make sure that the DDoS traffic is not easily separated from the real traffic.
(when the game uses another port number than 8807 you could simply drop all traffic to 8807, but I assume 8807 is the port used by the game as well)
Suggest you get real, get a sense of humour (aka stop taking yourself too seriously) and do your job and prevent viagra posts and stop intimidating and threatening others.
Sure you can block my posts or ban me from the forums, go ahead, I will have tons of free time to do other work.
So let off the hook and focus on these activities. Nonobvious sense of humor is not an excuse of savoir vivre.
Get rid of any complicated anti DDoS rules, you want your router to forward the packets as fast as possible to your much more powerful PC that ignores them. Sounds like the real DoS condition is your router CPU being overwhelmed by too many rules, or it’s a simple bandwidth exhaustion attack (in which case you can do nothing - traffic already entered your network and hit saturation).
Probably with other powerful router can catch the problem?. i’m going to buya mikroTik RB4011iGS, do you think that it’s enough ?, any recomendation ?
The attaker continues, using udp flood, and tcp flood, in 10 secons, 200.000 tcp conections fron diferent sources, router hang, and restart., he scan all my opened ports, and it’s attacking all ports.
this time, i captured with router sniffer some ud packets to see the content, and try to block it with the content, all packets have ‘pizzaseo.com’ inside…, another intereseant data it’s source port 53.
can block all from port 53 from wan?
another..
it’s changing ports.., type of attack.. , pack size.. etc.
Get the RB4011, and maybe you can add a firewall rule in the Raw section that just blocks all UDP except for DNS and QUIC.
Or just block all TCP/UDP/53 incoming from WAN from now, except from 8.8.8.8 and 1.1.1.1 and temporary use Google/Cloudflare for upstream resolving?
This looks like some DNS amplification attack.
If you line is saturated you cannot “fix” it yourself and need to call “upstream” help. If its only your router crashing/running out of resources you might try indeed to block and see what happens.
A. Temporary solution: In tracking do shorten the TCP session Timout to let a router close connections after e.g. 3 hours not 24.
B. Longterm solution: Call your ISP and change public IP of your router.
I did quick scan of hes ip seams all is already closed up properly, so doing extra rule wont help much i guess, maybe if he drops incoming 53 on wan side in RAW filter it may release some CPU load? But it wont help much in general.
I don’t think that will be a longterm solution. As soon as the boys that want to shutdown his gaming server discover that the address has changed, they will change the target address of their attacks.
A longterm solution would be to stop the gaming server. That is what they want him to do.
Of course it can be questioned whether giving in to such pressure is a good thing, but at least it solves the problem.
All this is perfectly useless,
for a very simple reason:
On a >>>game server hosted in my home<<<. if you can’t distinguish between real and fake traffic, and your bandwidth is limited,
you lose:
GAME OVER
If you can switch your DNS to DoT (TCP/853) or DoH (TCP/443) you can close all traffic incoming with source port 53 (TCP/UDP).
Then if that working for you then you could ask upstream to temporary block all traffic with source port 53 because you swichted the protocol for DNS.
General remark. As with VOIP you can use alternative ports if your ISP block the usual ports. An DNS server answers with source port 53. When the an DNS server is listening on a wide range of ports and always answer on the dst port used bij the client you have a working DNS. Oeps, that will work counter productive.
Putting your DNS requests in a VPN allows you also close traffic with sourceport 53 on the input or earlier in RAW on prerouting.
useless, you do not read from start
