Under flood attack, how resolve this ?
How will closing already closed DNS port help with anything when hes getting TCP attacks on other port?
Strike the general remark on about different port because that would make it worse.
You are writing about the destination port and that are many here. I am talking about the source port and that is one port (TCP/UDP)
BTW an ISP won’t like it when you open Port 53 to the internet because of the DNS amplification danger. My providers will cut you off, often without an warning if you open port 53 to the internet.
again: useless, you do not read from start
@msatter edit your previous post and remove useless quotes, please
@msatter Please remove all quotes from your previous post and use “post reply” instead of using “quote” button if just reply to last post.
Is not an ISP if for default do not close port 53 from CPE to Internet…
it’s attaking in diferent ways.., sending udp flood, tcp flood, tcp syn.. etc..
yes i can block souce dns port 53, but continues attacking.
Current router can’t handle it, just goes iressponsive, unable to connect in my local lan with my server., i expect get today a more powerfull router.
only my the first raw rule it’s blocking all atack tcp or udp traffic , but router goes irresponsive..
this is tcp attack., im blocking all packets in range ports widh specific packet size., but sometimes the attacker change the packet size and then hang the router.., im’ fucked
Is there a common thing that the attacker have except for the targetted port?
I have a longtime problem with rented servers, scanning by router to look for attack vectors. Multiple severs but often in the same multiple /24 range.
So the router adds any source IP that scan on a inacctive dst port. A second script looks at the collected IP addresses and when three collected addresses are from the same /24 range they then get blocked.
Eac collected addresses has a lifetime of a few hours so scans have to be in a limited timeframe. The list grows and grows and sometimes I can’t reach a website that is hosted in blocked range. Then I add that server to the DO-NOT-BLOCK address list and I now visit that specific site.
There are many blocklists available but not one covers all and you have geographical differences. That why do it myself also.
My way … set your own port list and watch if it helps or not
add name=WAN_LIST
add interface=ETH1 list=WAN_LIST
/ip firewall raw
add action=accept chain=prerouting src-address=9.9.9.9
add action=accept chain=prerouting src-address=1.1.1.1
add action=accept chain=prerouting src-address=8.8.8.8
add action=drop chain=prerouting in-interface-list=WAN_LIST log-prefix=RAWATTACK src-address-list=RAWATTACK
add action=add-src-to-address-list address-list=RAWATTACK address-list-timeout=1h7m chain=prerouting dst-port=\
    22,23,2000,7547,11211,135,137-139,548,80,8080,81,37215 in-interface-list=WAN_LIST protocol=tcp
    22,23,2000,7547,11211,135,137-139,548,80,8080,81,37215 in-interface-list=WAN_LIST protocol=udp
I suggest to remove any form of logging (log-prefix=RAWATTACK).
When under attack, only increase CPU load…
I’m writing on general, not only on this script where log-prefix is only a residue of when the log option are enabled.
thanks for that rules.
now, attacking with udp., diferent paket sizes, ip’s and source ports.
only way handle it it’s blocking que port..
Did you get the RB4011?
I post here my current perm24Blocklist and I you use first try it with a pass-through and watch if the counter is increasing fast or not. If not my list does not catch your attackers.
You should save the file “perm24Block.rsc” and in the top of the script you can read how you can import it. Save it in files on the router that experiences the attacks.
Then point a new line in RAW with the mention pass-trough as action and put this line at high up in RAW to see if it works for you. It is not a big list but it’s covers a huge range of addresses and I think that there are some ranges in the list that is larger than /16. It covers much and there could be false positives in there because I just block ranges.
list removed by me
The line RAW I use to block them:
add action=drop chain=prerouting comment="perm24Block /24+ range blocker" in-interface-list=WAN src-address-list=perm24Block
no… again on-hOrror…
do={ ...
       } on-error={:log warning "IP already exists: $1"}}
Maybe these could help finding/preparing list of addresses to apply to block rules
http://forum.mikrotik.com/t/importing-ip-list-from-file/143071/6
http://forum.mikrotik.com/t/how-to-opitimize-list-of-ip4-addresses/129916/1
https://tehnoblog.org/ip-tools/ip-address-aggregator/
Sweet tool, but for the price of a couple of cups of coffee I recommend the OP try this service if looking for WORRY FREE already integrated list blocking!
What I am suggesting is give the 10 day FREE trial, a go to see if it does the job!!
If not, nothing lost.
https://itexpertoncall.com/additional_info/moabpre.html
https://itexpertoncall.com/promotional/moab.html#prime
If was not already using this service also has a free trial (business expense write-off) I would be using mOAB which is 4x cheaper!
https://mum.mikrotik.com/presentations/NZ18/presentation_5526_1526964806.pdf
Suppose you block EVERYTHING coming in (in RAW chain to consume least amount of resources) => Does your router remain responsive ?? If not then all of this is simply waste of time and you should look for a somewhat more capable/powerful router to start with…or none of this will do any good.
Again, TO ALL:
All this is perfectly useless,
for a very simple reason:
if the game server is hosted in his house, is impossible to distinguish between real and fake traffic, and the bandwidth is limited,
you lose:
GAME OVER
Use this as start to emprove the script:
/ip firewall address-list
remove [find where list=perm24Block]
:local i do={ :local xparse ([[:parse ":return $1"]])
              :if ([:typeof $xparse] ~ "ip") do={
                  :if ([:len [find where address=$xparse and list="perm24Block"]] = 0) do={
                      add address=$xparse list="perm24Block"
$i 1.12.0.0/14
$i 2.57.122.0/24
$i 5.63.151.0/24
$i 5.178.86.0/24
$i 5.181.80.0/24
$i 5.188.119.0/24
$i 5.188.158.0/24
$i 5.188.206.0/24
$i 8.128.0.0/11
$i 23.90.145.0/24
$i 23.90.160.0/24
$i 23.148.145.0/24
$i 23.173.112.0/24
$i 23.251.102.0/24
$i 27.71.84.0/24
$i 27.115.124.0/24
$i 27.222.42.0/24
$i 31.133.0.0/24
$i 31.210.20.0/23
$i 34.77.162.0/24
$i 34.86.35.0/24
$i 34.96.130.0/24
$i 36.155.117.0/24
$i 37.49.224.0/21
$i 38.94.109.0/24
$i 39.129.96.0/24
$i 42.192.83.0/24
$i 42.192.91.0/24
$i 42.192.104.0/24
$i 42.192.146.0/24
$i 42.192.161.0/24
$i 42.192.229.0/24
$i 42.192.249.0/24
$i 42.224.0.0/12
$i 43.226.48.0/22
$i 45.33.0.0/17
$i 45.55.0.0/16
$i 45.79.0.0/16
$i 45.83.64.0/22
$i 45.85.90.0/24
$i 45.89.27.0/24
$i 45.93.201.0/24
$i 45.123.119.0/24
$i 45.133.1.0/24
$i 45.134.144.0/24
$i 45.134.225.0/24
$i 45.138.208.0/24
$i 45.143.200.0/24
$i 45.143.203.0/24
$i 45.144.225.0/24
$i 45.146.164.0/23
$i 45.148.10.0/24
$i 45.155.205.0/24
$i 45.177.244.0/24
$i 45.179.165.0/24
$i 45.186.145.0/24
$i 45.195.14.0/24
$i 45.229.54.0/23
$i 45.248.0.0/22
$i 45.248.20.0/23
$i 45.248.156.0/23
$i 45.248.160.0/24
$i 45.248.163.0/24
$i 46.101.0.0/17
$i 46.105.132.0/24
$i 46.148.233.0/24
$i 46.174.191.0/24
$i 46.249.32.0/24
$i 47.100.0.0/14
$i 49.51.0.0/16
$i 49.232.151.0/24
$i 51.15.0.0/16
$i 51.83.177.0/24
$i 51.89.39.0/24
$i 51.89.52.0/24
$i 51.159.7.0/24
$i 51.159.57.0/24
$i 51.159.78.0/24
$i 51.159.80.0/24
$i 51.161.41.0/24
$i 51.195.166.0/24
$i 51.222.199.0/24
$i 54.39.194.0/24
$i 60.2.87.0/24
$i 62.4.22.0/24
$i 62.210.128.0/17
$i 64.23.128.0/17
$i 64.62.197.0/24
$i 64.225.0.0/17
$i 64.226.64.0/18
$i 64.227.0.0/17
$i 64.227.128.0/18
$i 65.49.20.0/24
$i 66.240.192.0/24
$i 66.240.205.0/24
$i 66.240.219.0/24
$i 66.240.236.0/24
$i 67.205.128.0/18
$i 67.207.64.0/19
$i 68.183.0.0/16
$i 71.6.128.0/17
$i 72.217.158.0/24
$i 72.221.232.0/24
$i 72.241.3.0/24
$i 72.241.16.0/24
$i 72.241.90.0/24
$i 72.241.172.0/24
$i 72.241.203.0/24
$i 72.241.223.0/24
$i 74.82.47.0/24
$i 74.120.14.0/24
$i 74.201.28.0/24
$i 77.247.108.0/24
$i 78.108.177.0/24
$i 78.128.113.0/24
$i 79.124.59.0/24
$i 79.124.62.0/24
$i 80.82.77.0/24
$i 80.94.93.0/24
$i 80.240.128.0/20
$i 80.246.81.0/24
$i 81.70.40.0/24
$i 81.70.163.0/24
$i 81.70.176.0/24
$i 81.70.211.0/24
$i 81.71.138.0/24
$i 81.91.190.0/24
$i 81.161.63.0/24
$i 82.196.0.0/20
$i 84.53.198.0/24
$i 85.119.151.0/24
$i 87.251.70.0/24
$i 88.202.190.0/24
$i 88.214.24.0/24
$i 89.190.156.0/24
$i 89.248.165.0/24
$i 89.248.168.0/23
$i 89.248.172.0/24
$i 89.248.174.0/24
$i 91.132.58.0/24
$i 91.151.89.0/24
$i 91.191.209.0/24
$i 92.55.66.0/24
$i 92.63.196.0/23
$i 92.118.160.0/23
$i 94.102.49.0/24
$i 94.232.45.0/24
$i 94.232.46.0/24
$i 95.85.0.0/18
$i 101.200.72.0/24
$i 101.200.82.0/24
$i 101.200.90.0/24
$i 101.200.170.0/24
$i 101.200.177.0/24
$i 101.200.183.0/24
$i 101.200.221.0/24
$i 103.52.217.0/24
$i 103.66.78.0/24
$i 103.77.37.0/24
$i 103.114.104.0/24
$i 103.145.13.0/24
$i 103.198.10.0/24
$i 103.203.57.0/24
$i 103.219.152.0/24
$i 103.232.53.0/24
$i 104.131.0.0/16
$i 104.140.0.0/16
$i 104.206.128.0/24
$i 104.236.0.0/16
$i 104.248.0.0/16
$i 106.0.0.0/10
$i 106.75.0.0/16
$i 106.112.153.0/24
$i 107.151.182.0/24
$i 107.170.0.0/16
$i 107.189.29.0/24
$i 107.189.30.0/23
$i 109.123.117.0/24
$i 109.234.153.0/24
$i 110.80.136.0/24
$i 111.7.96.0/24
$i 111.206.170.0/24
$i 111.229.35.0/24
$i 111.229.63.0/24
$i 111.229.92.0/24
$i 111.229.109.0/24
$i 111.229.122.0/24
$i 111.229.211.0/24
$i 111.229.231.0/24
$i 112.46.87.0/24
$i 112.49.47.0/24
$i 112.121.189.0/24
$i 115.231.83.0/24
$i 116.62.0.0/16
$i 117.50.23.0/24
$i 117.50.63.0/24
$i 117.50.65.0/24
$i 117.50.100.0/23
$i 117.50.104.0/24
$i 118.193.31.0/24
$i 119.28.61.0/24
$i 119.29.52.0/24
$i 119.29.81.0/24
$i 119.29.155.0/24
$i 119.29.168.0/24
$i 119.188.125.0/24
$i 120.70.100.0/24
$i 120.85.238.0/24
$i 120.92.109.0/24
$i 120.131.6.0/24
$i 120.222.197.0/24
$i 121.4.80.0/24
$i 121.4.82.0/24
$i 121.4.88.0/24
$i 121.4.164.0/24
$i 121.4.168.0/24
$i 121.4.182.0/24
$i 121.5.3.0/24
$i 121.5.107.0/24
$i 121.5.155.0/24
$i 121.5.188.0/24
$i 121.5.237.0/24
$i 121.5.243.0/24
$i 121.5.250.0/23
$i 121.136.234.0/24
$i 121.196.0.0/14
$i 122.254.100.0/24
$i 123.56.24.0/24
$i 123.56.62.0/24
$i 123.56.64.0/24
$i 123.56.85.0/24
$i 123.56.93.0/24
$i 123.56.100.0/24
$i 123.56.147.0/24
$i 123.56.158.0/24
$i 123.56.239.0/24
$i 123.160.221.0/24
$i 124.88.69.0/24
$i 124.156.50.0/23
$i 124.156.54.0/23
$i 124.156.62.0/24
$i 124.156.200.0/24
$i 124.156.210.0/24
$i 124.156.245.0/24
$i 125.64.94.0/24
$i 128.1.91.0/24
$i 128.1.248.0/24
$i 128.14.128.0/24
$i 128.14.137.0/24
$i 128.14.141.0/24
$i 128.14.152.0/24
$i 128.14.209.0/24
$i 128.14.211.0/24
$i 128.199.0.0/16
$i 129.227.129.0/24
$i 134.122.0.0/17
$i 134.209.0.0/16
$i 134.228.0.0/16
$i 136.144.41.0/24
$i 137.184.0.0/16
$i 138.68.0.0/16
$i 138.197.0.0/16
$i 139.59.0.0/16
$i 139.60.162.0/24
$i 139.162.0.0/16
$i 139.177.193.0/24
$i 141.98.10.0/24
$i 141.212.123.0/24
$i 142.93.0.0/16
$i 143.110.128.0/17
$i 143.198.0.0/16
$i 143.244.128.0/17
$i 144.126.192.0/18
$i 146.185.25.0/24
$i 147.182.128.0/17
$i 150.109.160.0/19
$i 151.106.35.0/24
$i 151.106.41.0/24
$i 152.42.128.0/17
$i 152.136.22.0/24
$i 152.136.34.0/24
$i 152.136.96.0/24
$i 152.136.100.0/24
$i 152.136.129.0/24
$i 152.136.237.0/24
$i 156.96.155.0/24
$i 157.230.0.0/16
$i 157.245.0.0/16
$i 159.65.0.0/16
$i 159.89.0.0/16
$i 159.203.0.0/16
$i 159.223.0.0/16
$i 161.35.0.0/16
$i 162.62.26.0/24
$i 162.142.125.0/24
$i 162.221.192.0/24
$i 162.243.0.0/16
$i 163.172.16.0/24
$i 164.52.24.0/24
$i 164.90.128.0/17
$i 164.92.64.0/18
$i 164.92.128.0/17
$i 165.22.0.0/16
$i 165.227.0.0/16
$i 165.232.32.0/19
$i 165.232.64.0/18
$i 165.232.128.0/18
$i 167.71.0.0/16
$i 167.99.0.0/16
$i 167.172.0.0/16
$i 167.248.133.0/24
$i 168.144.0.0/16
$i 170.130.187.0/24
$i 172.104.0.0/15
$i 173.0.59.0/24
$i 174.138.0.0/17
$i 175.6.158.0/24
$i 175.24.125.0/24
$i 178.18.242.0/24
$i 178.62.0.0/17
$i 178.72.68.0/22
$i 178.72.75.0/24
$i 178.72.76.0/23
$i 178.72.78.0/24
$i 178.128.0.0/16
$i 178.175.0.0/18
$i 179.43.157.0/24
$i 179.43.175.0/24
$i 179.43.176.0/24
$i 179.43.187.0/24
$i 180.76.0.0/16
$i 180.149.126.0/24
$i 180.163.220.0/24
$i 180.182.245.0/24
$i 183.80.89.0/24
$i 183.89.0.0/16
$i 183.136.225.0/24
$i 184.105.139.0/24
$i 184.105.247.0/24
$i 184.179.216.0/24
$i 185.14.184.0/23
$i 185.14.186.0/24
$i 185.36.81.0/24
$i 185.53.90.0/24
$i 185.56.80.0/24
$i 185.101.107.0/24
$i 185.142.53.0/24
$i 185.142.236.0/24
$i 185.142.239.0/24
$i 185.153.196.0/24
$i 185.153.198.0/23
$i 185.156.73.0/24
$i 185.167.97.0/24
$i 185.173.35.0/24
$i 185.180.143.0/24
$i 185.191.34.0/24
$i 185.200.118.0/24
$i 185.216.140.0/24
$i 185.220.205.0/24
$i 185.236.11.0/24
$i 186.33.107.0/24
$i 186.33.110.0/24
$i 186.33.127.0/24
$i 186.179.100.0/24
$i 188.68.204.0/24
$i 188.124.36.0/24
$i 188.124.54.0/24
$i 188.166.0.0/17
$i 188.166.240.0/20
$i 190.180.154.0/24
$i 191.102.120.0/24
$i 192.34.56.0/21
$i 192.35.168.0/24
$i 192.81.208.0/20
$i 192.241.128.0/17
$i 193.3.53.0/24
$i 193.27.228.0/23
$i 193.46.255.0/24
$i 193.107.216.0/24
$i 193.118.51.0/24
$i 193.118.53.0/24
$i 193.118.55.0/24
$i 193.142.146.0/24
$i 193.163.125.0/24
$i 193.169.255.0/24
$i 193.242.145.0/24
$i 194.61.25.0/24
$i 194.62.6.0/24
$i 194.147.140.0/24
$i 194.165.16.0/24
$i 195.24.207.0/24
$i 195.133.40.0/24
$i 195.230.103.0/24
$i 196.189.91.0/24
$i 198.16.43.0/24
$i 198.98.48.0/24
$i 198.98.51.0/24
$i 198.98.54.0/23
$i 198.98.59.0/24
$i 198.98.62.0/24
$i 198.199.64.0/18
$i 198.211.96.0/19
$i 198.232.147.0/24
$i 199.4.223.0/24
$i 199.19.225.0/24
$i 199.195.254.0/24
$i 202.44.240.0/24
$i 202.44.247.0/24
$i 202.44.251.0/24
$i 202.164.139.0/24
$i 203.159.80.0/24
$i 204.16.0.0/24
$i 204.48.16.0/20
$i 205.185.113.0/24
$i 205.185.114.0/24
$i 205.185.117.0/24
$i 205.185.119.0/24
$i 205.185.120.0/24
$i 205.185.123.0/24
$i 205.185.124.0/23
$i 205.185.127.0/24
$i 206.81.0.0/19
$i 206.185.0.0/16
$i 206.189.0.0/16
$i 207.154.192.0/18
$i 208.68.36.0/22
$i 208.103.169.0/24
$i 209.17.96.0/24
$i 209.97.128.0/18
$i 209.141.32.0/19
$i 211.23.160.0/24
$i 212.192.241.0/24
$i 216.189.52.0/24
$i 216.218.206.0/24
$i 220.178.67.0/24
$i 223.252.6.0/24
I’m glad we have some Arbor Networks technologies (now Netscout) deployed in the core/edges of our networks.
We see quite a lot of attacks, and the “average” volumetric ones are about 250Gbits/sec these days.
Not that long ago we (auto) mitigated one of 400Gbits/sec :wink: Keep 'm coming :wink:
Exactly so instead of endlessly playing with his config and chasing everyone’s favourite piece of script, I am begging the op, DONT WASTE YOUR TIME,
try one of the free trials by a service that does all the legwork for you (keeps it up to date from multiple sources). This will demonstrate to you whether blocking works or not.
Then consider your options.
