[Ticket#2014032566001217]
BUG 6.12: Replicable kernel crash when try to discover why winbox not working well from 6.8 over IP obtained from pppoe-client
when I try to replicate this problem:
“Winbox connection freeze after some kb received over mppe encrypted connection”
RouterOS version affected: all from 6.8, 6.9, 6.10, 6.11, 6.12 (2014/03/24)
From 6.10 the problem go worst.
I get continuosly kernel failure and routerboard reboot with this configuration:
For this example I use one RB1100AHx2 and one RB951G-2HnD,
netinstalled with NO Keep old configuration and routeros-powerpc-6.12.npk / routeros-mipsbe-6.12.npk
both have last 3.10 / 3.12 bios.
The connection maded with ethernet cable are:
PC → PoE - > ether13 RB1100AHx2
RB1100AHx2 ether2 → RB951G-2HnD ether2
power jack → RB951G-2HnD
The PoE and the ethernet cable do not matter, also tried to change.
RB1100AHx2 and RB951G-2HnD:
after netinstall
disable all packages except for:
routeros-powerpc / routeros-mipsbe
ppp
system
and reboot
paste this on RB1100AHx2 terminal
/interface eoip
add keepalive=10 local-address=192.168.3.1 mac-address=02:AE:6D:55:61:E2 name=eoip-tunnel1 remote-address=192.168.3.2 tunnel-id=666
/interface bridge settings
set use-ip-firewall=yes
/interface pppoe-server server
add authentication=mschap2 default-profile=default-encryption disabled=no interface=eoip-tunnel1 mrru=1614 service-name=service1
add address=192.168.2.1/24 interface=ether13 network=192.168.2.0
add address=192.168.3.1/24 interface=ether2 network=192.168.3.0
set enabled=yes
/ppp secret
add local-address=10.0.0.1 name=test password=test profile=default-encryption remote-address=10.0.0.2
/system identity
set name=“Test Gateway"paste this on RB951G-2HnD terminal
/interface eoip
add keepalive=10 local-address=192.168.3.2 mac-address=02:08:2C:28:55:D6 name=eoip-tunnel1 remote-address=192.168.3.1 tunnel-id=666
/interface pppoe-client
add ac-name=”" add-default-route=yes allow=mschap2 default-route-distance=1 dial-on-demand=no disabled=no interface=eoip-tunnel1 keepalive-timeout=60 max-mru=1480 max-mtu=1480 mrru=1614 name=pppoe-out1 password=test profile=default-encryption
service-name=“” use-peer-dns=yes user=test
add address=192.168.3.2/24 interface=ether2 network=192.168.3.0
set enabled=yes
/system identity
set name="Test CPE"When you open with winbox 10.0.0.2 [after 1 hour, or 1 minutes are equal]
the RB1100AHx2 continuosly reboot / freeze without creating any autosupout.rif,
but with kernel failure on log and on terminal on serial port:
[admin@Test Gateway] /file> Oops: Exception in kernel mode, sig: 5 [#1]
SMP NR_CPUS=2 RB1120
NIP: 8021a730 LR: 8021a46c CTR: 00000000
REGS: dffefd30 TRAP: 0700 Not tainted (3.3.5-smp)
MSR: 00029000 <CE,EE,ME> CR: 42000028 XER: 20000000
TASK = 8036d3c0[0] 'swapper/0' THREAD: 80380000 CPU: 0
GPR00: 8021a46c dffefde0 8036d3c0 fffffff2 de6f58aa 00000001 de6f4e50 dc870cd2
GPR08: 120ff29a 0000001d 00000000 8021a400 42000022 00000001 dd9fc300 00000012
GPR16: 00000003 00000000 e1811a40 000005e2 de6dd414 e1811a2c e18119c8 e18119ec
GPR24: 00000012 e1811828 de6dd484 0000003b 000000fd dd9fc300 dd9fc300 de6dd3c0
NIP [8021a730] __pskb_pull_tail+0x330/0x340
LR [8021a46c] __pskb_pull_tail+0x6c/0x340
Call Trace:
[dffefde0] [8021a46c] __pskb_pull_tail+0x6c/0x340 (unreliable)
[dffefe00] [e180df30] ppp_register_channel+0xb20/0x1b4c [ppp_generic@0xe180c000]
[dffefe30] [e180f8d4] ppp_output_wakeup+0x978/0xa20 [ppp_generic@0xe180c000]
[dffefe90] [e180fb30] ppp_input+0xf0/0x12a4 [ppp_generic@0xe180c000]
[dffefeb0] [e18494d0] 0xe18494d0 [pppoe@0xe1849000]
[dffefed0] [80221f9c] __netif_receive_skb+0x220/0x400
[dffeff30] [802224a0] process_backlog+0xac/0x178
[dffeff60] [80223870] net_rx_action+0xc0/0x170
[dffeffa0] [80031a14] __do_softirq+0xf4/0x178
[dffefff0] [8000c054] call_do_softirq+0x14/0x24
[80381e80] [80003f5c] do_softirq+0x98/0xc4
[80381ea0] [80031d84] irq_exit+0xa0/0xd4
[80381eb0] [80003c44] do_IRQ+0x94/0x190
[80381ee0] [8000d71c] ret_from_except+0x0/0x18
--- Exception: 501 at cpu_idle+0x8c/0xe0
LR = cpu_idle+0x8c/0xe0
[80381fc0] [8034076c] start_kernel+0x2d4/0x2e8
[80381ff0] [800003f8] skpinv+0x2e4/0x320
Instruction dump:
7fdcf378 3b400000 4bffffa0 7fc3f378 7c84f850 4bfffced 2f830000 409eff9c
7f43d378 4bffe9c9 38600000 4bffff00 <0fe00000> 38c00001 7cc903a6 4bfffd90
---[ end trace 72421d3cf3d534d4 ]---
Kernel panic - not syncing: Fatal exception in interrupt
panicSaver: dumping panic to flash
flash: erase 10
flash: prg 10
flash: prg err 0
Rebooting in 1 seconds..
------------[ cut here ]------------
Kernel BUG at 800a3a70 [verbose debug info unavailable]
Oops: Exception in kernel mode, sig: 5 [#2]
NIP: 800a3a70 LR: 800113ec CTR: 00000000
REGS: dffefa60 TRAP: 0700 Tainted: G D (3.3.5-smp)
MSR: 00021000 <CE,ME> CR: 22000024 XER: 20000000
GPR00: 800113ec dffefb10 8036d3c0 00001000 00000001 00000001 e1000000 edffc000
GPR08: 000000d0 80017554 00000300 fffffffd 22000024 00000001 dd9fc300 00000012
GPR24: 80017554 80380000 e1000000 edffc000 000000d0 00000001 00000001 80017554
NIP [800a3a70] __get_vm_area_node.isra.31+0x34/0x180
LR [800113ec] __ioremap_caller+0x170/0x1a4
Call Trace:
[dffefb10] [e137c43c] flash_fixed_cmd+0x140/0x204 [flash@0xe137b000] (unreliable
[dffefb40] [800113ec] __ioremap_caller+0x170/0x1a4
[dffefb70] [80017554] rb1120_restart+0x68/0xa4
[dffefb90] [8000b35c] machine_restart+0x48/0x60
[dffefbb0] [802ad3b0] panic+0x198/0x1e8
[dffefc00] [800096b4] die+0x244/0x284
[dffefc30] [8000984c] _exception+0x100/0x114
[dffefd20] [8000d6d0] ret_from_except_full+0x0/0x4c
--- Exception: 700 at __pskb_pull_tail+0x330/0x340
LR = __pskb_pull_tail+0x6c/0x340
Instruction dump:
9421ffd0 bf010010 542a0024 90010034 7c9d2378 7cbe2b78 7cda3378 814a000c
7cfb3b78 7d1c4378 7d384b78 554a016e <0f0a0000> 70a90001 41820018 7c690034
---[ end trace 72421d3cf3d534d5 ]---
I hope that I’ve explained everything well and sufficently detailed all.
Thanks to all.
