Note: wireless-fp package is discontinued in this version. It needs to be uninstalled/disabled before upgrade. Use wireless-rep or wireless-cm2 instead.
What’s new in 6.36rc3 (2016-Apr-19 11:33):
*) bonding - do not corrupt bonding statistics on configuration changes;
*) bonding - fixed crash when vlan parent mtu is higher than bonding mtu;
*) ethernet - do not allow mtu to be higher than l2mtu and l2mtu to be higher than max-l2mtu (reduce automatically on upgrade if it was wrong before);
*) firewall - added udplite, dccp, sctp connection tracking helpers;
*) switch - fixed switch compact export;
*) traffic-flow - added ipfix support (RFC5101 and RFC5102);
*) wireless - wireless-fp is discontinued, it needs to be uninstalled/disabled before upgrade;
If you experience version related issues, then please send supout file from your router to support@mikrotik.com. File must be generated while router is not working as suspected or after crash.
PLEASE make wireless-fp auto replaced by wireless-cm2. Otherwise it will be a pain to upgrade all CPEs in the network to 6.36
And… Could you please release a changelog for wireless-fp → wireless-cm2?
You can install cm2 before update. Then switch the packages and update afterwards. I agree that automatic wireless packages switch during the update would be much more convenient.
Sure, but you have to manually (or automatically in batch) change package.
It’s not so simple and you have to schedule both wireless package change and RouterOS upgrade.
As far as I’m aware the only major difference between the two is the supported version of CAPsMAN. Otherwise they should be functionally equivalent. If you happen to used CAPsMAN v1, there are upgrade instruction on the wiki.
yes, but doing auto-upgrade with manually added packages (e.g. not the bundled in main package) will fail as wireless-fp-x.xx-arch.npk will not be on the distribution site.
I´d like to request a feature for wireless-rep package:
Is it possible to show the username (beside the MAC address) for all connected clients within CAPSMAN window?
(It would be helpful to see on which access point a client is connected when users calling support and complains about connectivity issues they have…)
I have a few more requests:
Is it possible to show CCQ for each connected client? Or dropped / retransmitted frames percentage?
Is it possible to perform background scan for each remote radio?
(It would be helpful to see connection quality statistics as well as channel usage statistics within CAPSMAN window)
Let´s summarize the feature requests for wireless-rep:
vendor OUI auto naming
custom names for CAP devices
centralized ressource monitoring / statistics ([CPU, RAM, amount of connected clients for each CAP device], total amount of connected devices, frequency band usage, “rogue devices” using the same frequency band or the same SSID per CAP device,…)
Also: Since upgrading from 6.35rc48 to 6.35, my hAP acting as CAPsMAN loses the association with some of the CAPs after a few hours (<1 day), even though the CAPs are accessible from the hAP. The CAPs that have dissassociated stop publishing any wlans. A reboot of the problematic CAPs fixes the problem: they appear again in the “Remote CAP” table. This has happened three times within two days, while had never happened before. I don’t know whether this is of any relevance, but free disk space on the hAP is low, to about 1.4MB, even though there are no files taking up any significant space. Sometimes I even get error messages from User Manager because of low space.
All devices are running on 6.35 stable.
I am publishing this here because it has to be worked on in this version.
please add into the CapsMan Registration Table fields:
CCQ, RadioName, Distance,
and the option to scan for free frequencies for each cap
and also the Channel Width 10mhz
I use CapsMan to have a centralized management of all my sectors and customers with SXT of my Wisp
so the request of the CCQ and RadioName
and in some sector still in use migrated 10mhz
When was this bug introduced and how did it make it into the “stable” version? It is not a rare bug. Possibly you should start remaining to the last RC, the one which can ACTUALLY be named Release Candidate, for a few days without making any further additions, just bug fixing, before releasing it as stable. Even from rc48 and rc49 to the stable, there were additions which could introduce new bugs.
What you call “stable” is called “bugfix only” by Mikrotik guys. And it is version 6.32.4 at the moment. Please read release branch descriptions at the top of official download page. CAPsMAN is rock solid in 6.32.4 with wireless-cm2 for me.
