To upgrade, click “Check for updates” at /system package in your RouterOS configuration interface, or head to our download page: http://www.mikrotik.com/download
If you experience version related issues, then please send supout file from your router to support@mikrotik.com. File must be generated while router is not working as suspected or after crash.
What’s new in 6.40.4 (2017-Oct-02 08:38):
*) address - show warning on IPv6 address when acquire from pool has failed;
*) arp - properly update dynamic ARP entries after interface related changes;
*) crs1xx/2xx - fixed 1 Gbps forced mode for several SFP modules;
*) crs317 - added L2MTU support;
*) crs3xx - improved packet processing in slowpath;
*) defconf - fixed RouterOS default configuration (introduced in v6.40.3);
*) dhcp - fixed downgrade from RouterOS v6.41 or higher;
*) dhcpv6 client - added IAID check in reply;
*) dhcpv6-client - fixed IA check on solicit when “rapid-commit” is enabled;
*) dhcpv6-client - ignore unknown IA;
*) dhcpv6-client - require pool name to be unique;
*) e-mail - auto complete file name on “file” parameter (introduced in v6.40);
*) export - fixed wireless “ssid” and “supplicant-identity” compact export;
*) hotspot - fixed missing “/ip hotspot server profile” if invalid “dns-name” was specified;
*) hotspot - improved user statistics collection process;
*) ike1 - remove PH1 and PH2 when “mode-config” exchange fails;
*) ipsec - kill PH1 on “mode-config” address failure;
*) ipv6 - fixed IPv6 address request from pool;
*) lte - fixed modem initialization after reboot;
*) ntp-client - properly start NTP client after reboot if manual server IP is not configured;
*) rb931-2nd - fixed startup problems (requires additional reboot after upgrade);
*) routerboard - fixed “/system routerboard upgrade” for CRS212-8G-4S;
*) sfp - fixed OPTON module DDM information readings;
*) sfp - fixed temperature readings for various SFP modules;
*) snmp - fixed “/caps-man registration-table” uptime values;
*) snmp - fixed “/system license” parameters for CHR;
*) tile - improved reliability on MPLS package processing;
*) userman - fixed unresponsive RADIUS server (introduced in v6.40.3);
*) vlan - do not allow VLAN MTU to be higher than L2MTU;
*) webfig - improved reliability of login process;
*) wireless - added “etsi1” regulatory domain information;
*) wireless - improved WPA2 key exchange reliability;
*) wireless - updated “norway” regulatory domain information;
Here is the info:
[admin@MikroTik] > interface wireless info country-info etsi1
ranges: 5270-5330/a,an20,an40,ac20,ac40,ac80,ac160(17dBm)/dfs
5490-5590/a,an20,an40,ac20,ac40,ac80,ac160(30dBm)/dfs,passive
5650-5730/a,an20,an40,ac20,ac40,ac80,ac160(30dBm)/dfs,passive
5735-5835/a,an20,an40,ac20,ac40,ac80,ac160(30dBm)/dfs,passive
2402-2482/b,g,gn20,gn40(20dBm)
2417-2457/g-turbo(20dBm)
Saleh9416 - No, this fix helps in rare cases when Hotspot service stops working properly due to incorrectly processed coherence between hosts and active users.
I have 22 clients connecting to various services from their homes using SSTP with cert. After upgrading to v6.40.4 I’m able to establish the connection, but for example - I can’t RDP to Windows PCs. I can’t ping any internal address from my IP pool.
After downgrade to 6.40.3 problem is resolved. Everything works as it should. I can see and connect to any PCs on my internal network.
lotnybartek, eddieb - Send supout file from 6.40.4 which would be generated after problem has appeared to support@mikrotik.com and refer to this forum post; Lakis - You did see this tab under “Wireless/Security Profiles” on 6.40.3 version and it disappeared on 6.40.4?
all modules works of PPP-emulation → PPP-out interfaces stopped working!!!
in systems - ports - the usb interface disappeared !!!
for example sierra wireless mc7304 and other vendors in ppp-emulalation
curent version - not trust !
Fix it !!
sorry for my English
I can see it in terminal
/interface wireless> print
…security-profile=default
but not in winbox ->interface wlan1 it should be located under Wireless Protocol
not just on one device, problem appeared after 6.4x.
