v6.42 [current]
RouterOS version 6.42 has been released in public “current” channel!
Before an upgrade:
  2. Make sure the device will not lose power during upgrade process;
  3. Device has enough free storage space for all RouterOS packages to be downloaded.
What’s new in 6.42 (2018-Apr-13 11:03):
!) tile - improved system performance and stability (“/system routerboard upgrade” required);
!) w60g - increased distance for wAP 60G to 200+ meters;
*) bridge - added host aging timer for CRS3xx and Atheros hw-bridges;
*) bridge - added per-port forwarding options for broadcasts, unknown-multicasts and unknown-unicasts;
*) bridge - added per-port learning options;
*) bridge - added support for static hosts;
*) bridge - fixed “master-port” configuration conversion from pre-v6.41 RouterOS versions;
*) bridge - fixed bridge port interface parameter under “/interface bridge host print detail”;
*) bridge - fixed false MAC address learning on hAP ac^2 and cAP ac devices;
*) bridge - fixed incorrect “fast-forward” enabling when ports were switched;
*) bridge - fixed MAC learning for VRRP interfaces on bridge;
*) bridge - fixed reliability on software bridges when used on devices without switch chip;
*) bridge - hide options for disabled bridge features in CLI;
*) bridge - show “hw” flags only on Ethernet interfaces and interface lists;
*) capsman - added “allow-signal-out-of-range” option for Access List entries;
*) capsman - added support for “interface-list” in Access List and Datapath entries;
*) capsman - improved CAPsMAN responsiveness with large amount of CAP interfaces;
*) capsman - log “signal-strength” when successfully connected to AP;
*) certificate - added PKCS#10 version check;
*) certificate - dropped DES support and added AES instead for SCEP;
*) certificate - dropped MD5 support and require SHA1 as minimum for SCEP;
*) certificate - fixed incorrect SCEP URL after an upgrade;
*) chr - added “open-vm-tools” on VMware installations;
*) chr - added “qemu-guest-agent” and “virtio-scsi” driver on KVM installations;
*) chr - added “xe-daemon” on Xen installations;
*) chr - added support for Amazon Elastic Network Adapter (ENA) driver;
*) chr - added support for booting from NVMe disks;
*) chr - added support for Hyper-V ballooning, guest quiescing, host-guest file transfer, integration services and static IP injection;
*) chr - added support for NIC hot-plug on VMware and Xen installations;
*) chr - fixed additional disk detaching on Xen installations;
*) chr - fixed interface matching by name on VMware installations;
*) chr - fixed interface naming order when adding more than 4 interfaces on VMware installations;
*) chr - fixed suspend on Xen installations;
*) chr - make additional disks visible under “/disk” on Xen installations;
*) chr - make Virtio disks visible under “/disk” on KVM installations;
*) chr - run startup scripts on the first boot on AWS and Google Cloud installations;
*) console - fixed “idpr-cmtp” protocol by changing its value from 39 to 38;
*) console - improved console stability after it has not been used for a long time;
*) crs1xx/2xx - added BPDU value for “ingress-vlan-translation” menu “protocol” option;
*) crs212 - fixed Ethernet boot when connected to boot server through CRS326 device;
*) crs326 - fixed known multicast flooding to the CPU;
*) crs3xx - added switch port “storm-rate” limiting options;
*) crs3xx - added “hw-offload” support for 802.3ad and “balance-xor” bonding;
*) detnet - fixed “detect-internet” feature unavailability if router had too long identity (introduced in v6.41);
*) dhcp - improved DHCP service reliability when it is configured on bridge interface;
*) dhcp - reduced resource usage of DHCP services;
*) dhcpv4-server - added “dns-none” option to “/ip dhcp-server network dns”;
*) dhcpv6 - make sure that time is set before restoring bindings;
*) dhcpv6-client - added info exchange support;
*) dhcpv6-client - added possibility to specify options;
*) dhcpv6-client - added support for options 15 and 16;
*) dhcpv6-client - implement confirm after reboot;
*) dhcpv6-server - added DHCPv4 style user options;
*) dns - do not generate “Undo” messages on changes to dynamic servers;
*) email - set maximum number of sessions to 100;
*) fetch - added “http-content-type” option to allow setting MIME type of the data in free text form;
*) fetch - added “output” option for all modes in order to return result to file, variable or ignore it;
*) fetch - increased maximum number of sessions to 100;
*) filesystem - implemented additional system storage maintenance checks on ARM CPU based devices;
*) flashfig - properly apply configuration provided by Flashfig;
*) gps - improved NMEA sentence handling;
*) health - added log warning when switching between redundant power supplies;
*) health - fixed empty measurements on CRS328-24P-4S+RM;
*) hotspot - improved HTTPS matching in Walled Garden rules;
*) ike1 - display error message when peer requests “mode-config” when it is not configured;
*) ike1 - do not accept “mode-config” reply more than once;
*) ike1 - fixed wildcard policy lookup on responder;
*) ike2 - fixed framed IP address received from RADIUS server;
*) interface - improved interface configuration responsiveness;
*) ippool - added ability to specify comment;
*) ippool6 - added pool name to “no more addresses left” error message;
*) ipsec - fixed AES-CTR and AES-GCM support on RB1200;
*) ipsec - improved single tunnel hardware acceleration performance on MMIPS devices;
*) ipsec - properly detect interface for “mode-config” client IP address assignment;
*) ipv6 - fixed IPv6 behaviour when bridge port leaves bridge;
*) ipv6 - update IPv6 DNS from RA only when it is changed;
*) kidcontrol - initial work on “/ip kid-control” feature;
*) led - added “Dark Mode” support for wAP 60G;
*) led - added w60g alignment trigger;
*) led - fixed unused “link-act-led” LED trigger on RBLHG 2nD, RBLHG 2nD-XL and RBSXTsq 2nD;
*) led - removed unused “link-act-led” trigger for devices which does not use it;
*) lte - added initial support for Quectel LTE EP06-E;
*) lte - added initial support for SIM7600 LTE modem interface;
*) lte - added support for the user and password authentication for wAP-LTE-kit-US (R11e-LTE-US);
*) lte - do not add DHCP client on LTE modems that doesn’t use DHCP;
*) lte - fixed DHCP client adding for MF823 modem;
*) lte - fixed LTE band setting for SXT LTE;
*) mac-ping - fixed duplicate responses;
*) modem - added initial support for AC340U;
*) netinstall - fixed MMIPS RouterOS package description;
*) netinstall - sign Netinstall executable with an Extended Validation Code Signing Certificate;
*) netwatch - limit to read, write, test and reboot policies for Netwatch script execution;
*) poe - do not show “poe-out-current” on devices which can not determine it;
*) poe - hide PoE related properties on interfaces that does not provide power output;
*) ppp - added initial support for NETGEAR AC340U and ZyXEL WAH1604;
*) ppp - allow to override remote user PPP profile via “Mikrotik-Group”;
*) quickset - fixed NAT if PPPoE client is used for Internet access;
*) quickset - properly detect IP address when one of the bridge modes is used;
*) quickset - properly detect LTE interface on startup;
*) quickset - show “G” flag for guest users;
*) quickset - use “/24” subnet for local network by default;
*) r11e-lte - improved LTE connection initialization process;
*) rb1100ahx4 - improved reliability on hardware encryption;
*) routerboard - added RouterBOOT “auto-upgrade” after RouterOS upgrade (extra reboot required);
*) routerboard - properly detect hAP ac^2 RAM size;
*) sniffer - fixed “/tool sniffer packet” results listed in incorrect order;
*) snmp - added “/caps-man interface print oid”;
*) snmp - added “/interface w60g print oid”;
*) snmp - added “board-name” OID;
*) snmp - improved request processing performance for wireless and CAP interfaces;
*) ssh - fixed SSH service becoming unavailable;
*) ssh - generate SSH keys only on the first connect attempt instead of the first boot;
*) ssh - improved key import error messages;
*) ssh - remove imported public SSH keys when their owner user is removed;
*) switch - hide “ingress-rate” and “egress-rate” for non-CRS3xx switches;
*) tile - added “aes-ctr” hardware acceleration support;
*) tr069-client - added “DownloadDiagnostics” and “UploadDiagnostics”;
*) tr069-client - correctly return “TransferComplete” after vendor configuration file transfer;
*) tr069-client - fixed “/tool fetch” commands executed with “.alter” script;
*) tr069-client - fixed HTTPS authentication process;
*) traffic-flow - fixed IPv6 destination address value when IPFIX protocol is used;
*) upgrade - improved RouterOS upgrade process and restrict upgrade from RouterOS older than v5.16;
*) ups - improved communication between router and UPS;
*) ups - improved disconnect message handling between RouterOS and UPS;
*) userman - added support for ARM and MMIPS platform;
*) w60g - added “tx-power” setting (CLI only);
*) w60g - added RSSI information (CLI only);
*) w60g - added TX sector alignment information (CLI only);
*) watchdog - retry to send “autosupout.rif” file to an e-mail if initial delivery failed up to 3 times within 20 second interval;
*) winbox - added “antenna” setting under GPS settings for MIPS platform devices;
*) winbox - added “crl-store” setting to certificate settings;
*) winbox - added “insert-queue-before” to DHCP server;
*) winbox - added “use-dn” setting in OSPF instance General menu;
*) winbox - added 160 MHz “channel-width” to wireless settings;
*) winbox - added DHCPv6 client info request type and updated statuses;
*) winbox - added missing protocol numbers to IPv4 and IPv6 firewall;
*) winbox - added possibility to delete SMS from inbox;
*) winbox - allow to comment new object without committing it;
*) winbox - allow to open bridge host entry;
*) winbox - fixed name for “out-bridge-list” parameter under bridge firewall rules;
*) winbox - fixed typo from “UPtime” to “Uptime”;
*) winbox - fixed Winbox closing when viewing graph which does not contain any data;
*) winbox - improved stability when using trackpad scrolling in large lists;
*) winbox - made UDP local and remote TX size parameters optional in Bandwidth Test tool;
*) winbox - moved “ageing-time” setting from STP to General tab;
*) winbox - moved OSPF instance “routing-table” setting in OSPF instance General menu;
*) winbox - removed “VLAN” section from “Switch” menu for CRS3xx devices;
*) winbox - show Bridge Port PVID column by default;
*) winbox - show CQI in LTE info;
*) winbox - show dual SIM options only for RouterBOARDS which does have two SIM slots;
*) winbox - show only master CAP interfaces under CAPsMAN wireless scan tool;
*) winbox - use proper graph name for HDD graphs;
*) wireless - added “realm-raw” setting for “/interface wireless interworking-profiles” (CLI only);
*) wireless - added initial support for “nstreme-plus”;
*) wireless - added support for “band=5ghz-n/ac”;
*) wireless - added support for “interface-list” for Access List entries;
*) wireless - added support for legacy AR9485 chipset;
*) wireless - enable all chains by default on devices without external antennas after configuration reset;
*) wireless - fixed “wds-slave” channel selection when single frequency is specified;
*) wireless - fixed incompatibility with macOS clients;
*) wireless - fixed long “scan-list” entries not working for ARM based wireless interfaces;
*) wireless - fixed nv2 protocol on ARM platform SXTsq devices;
*) wireless - fixed RB911-5HnD low transmit power issue;
*) wireless - fixed RTS/CTS option for the ARM based wireless devices;
*) wireless - fixed wsAP wrong 5 GHz interface MAC address;
*) wireless - improved compatibility with specific wireless AC standard clients;
*) wireless - improved Nv2 PtMP performance;
*) wireless - improved packet processing on ARM platform devices;
*) wireless - improved wireless performance on hAP ac^2 devices while USB is being used;
*) wireless - improved wireless scan functionality;
To upgrade, click “Check for updates” at /system package in your RouterOS configuration interface, or head to our download page: http://www.mikrotik.com/download
If you experience version related issues, then please send supout file from your router to support@mikrotik.com. File must be generated while router is not working as suspected or after some problem has appeared on device
Please keep this forum topic strictly related to this concrete RouterOS release.
Please note that improvements regarding upgrade process will become active only after an upgrade and will not affect upgrade to version 6.42.
Upgrade process happens on the old version, not the one which you try to put on your RouterOS instance.
Well. Looks awesome. Going to test how it helps to WiFi on hap ac2.
just posted this in the v6.41.4 current thread, here again because the problem is still there… (and wasn’t with v.6.41.2):
I just upgraded 2 minutes ago all of my devices to v6.42 [current].
I have one RB450G (configured as a pure switch) behind my CCR1016-12G router. Thus, the RB450G itself should not ask for and should not get any IP assigned from the DHCP server (CCR).
But since I updated the RouterOS, suddenly my logs on my CCR are flooded with
dhcp,warning dhcp1 offering lease 192.168.7.247 for <MAC_OF_RB450G_HERE> without success
Any idea what is wrong now?
Cheers, nin
nin - You should send supout file to support. Is it possible that “Detect Internet” feature is enabled on your device?
@strods: On the RB450G:
user@RB450G] /interface detect-internet> print
detect-interface-list: none
lan-interface-list: none
wan-interface-list: none
internet-interface-list: none
supout file of which device, the CCR?
Cheers, nin
What Mikrotik devices support 160 MHz channel WiFi?
I’d send both the CCR one and the 450 one, while the problem is occurring. Just to be sure.
I´m awaiting your results…
RB850Gx2. After upgrade ROS to 6.42 does not show Tx rate when used Torch.
It seems the results on hAP ac^2 using the new firmware v6.42 is more or less the same as v6.42rc52. Please take a look at the following five runs. The results are still not satisfactory as the average speed is around 130Mbps something, which is pretty far away from our expectations of over 300Mbps (stable and zero Retry count).
Please find sometime to see the last log which provides a lot of information of instability of download rate and packet retry count. Whenever the higher value of Retry count, the lower the speed.
Please help to resolve this issue as I have already brought 4 pieces of hAP ac^2. If you are able to resolve this issue, I am very sure that your sales of this product will be significantly increased.
YH
First Attempt
[ ID] Interval           Transfer     Bandwidth       Retr
[  4]   0.00-300.00 sec  9.22 GBytes   264 Mbits/sec  4236             sender
[  4]   0.00-300.00 sec  9.22 GBytes   264 Mbits/sec                  receiver
Second Attempt
[  4]   0.00-300.00 sec  5.25 GBytes   150 Mbits/sec  5845             sender
[  4]   0.00-300.00 sec  5.25 GBytes   150 Mbits/sec                  receiver
Third Attempt
[  4]   0.00-300.01 sec  5.44 GBytes   156 Mbits/sec  4605             sender
[  4]   0.00-300.01 sec  5.44 GBytes   156 Mbits/sec                  receiver
Fourth Attempt
[  4]   0.00-300.00 sec  4.79 GBytes   137 Mbits/sec  6206             sender
[  4]   0.00-300.00 sec  4.79 GBytes   137 Mbits/sec                  receiver
Fifth Attempt
[  4]   0.00-300.00 sec  4.90 GBytes   140 Mbits/sec  3702             sender
[  4]   0.00-300.00 sec  4.90 GBytes   140 Mbits/sec                  receiver
The following are the log showing the downloading rate and packet retry count due to errors (Retr)
Accepted connection from 192.168.55.70, port 60260
[  5] local 192.168.55.203 port 5201 connected to 192.168.55.70 port 60261
[ ID] Interval           Transfer     Bitrate         Retr  Cwnd
[  5]   0.00-1.00   sec  41.1 MBytes   344 Mbits/sec   41    315 KBytes
[  5]   1.00-2.01   sec  42.1 MBytes   352 Mbits/sec    0    342 KBytes
[  5]   2.01-3.01   sec  30.8 MBytes   258 Mbits/sec   49    139 KBytes
[  5]   3.01-4.01   sec  12.6 MBytes   106 Mbits/sec   53   80.6 KBytes
[  5]   4.01-5.01   sec  14.4 MBytes   120 Mbits/sec   51   72.1 KBytes
[  5]   5.01-6.01   sec  8.08 MBytes  67.8 Mbits/sec   84   52.3 KBytes
[  5]   6.01-7.01   sec  8.08 MBytes  67.8 Mbits/sec   24   49.5 KBytes
[  5]   7.01-8.01   sec  7.46 MBytes  62.5 Mbits/sec   29   46.7 KBytes
[  5]   8.01-9.01   sec  9.94 MBytes  83.4 Mbits/sec   28   56.6 KBytes
[  5]   9.01-10.01  sec  8.70 MBytes  73.0 Mbits/sec   67   65.0 KBytes
[  5]  10.01-11.01  sec  7.02 MBytes  58.9 Mbits/sec   57   55.1 KBytes
[  5]  11.01-12.01  sec  2.49 MBytes  20.9 Mbits/sec    7   28.3 KBytes
[  5]  12.01-13.01  sec  6.21 MBytes  52.1 Mbits/sec   14   70.7 KBytes
[  5]  13.01-14.01  sec  8.08 MBytes  67.8 Mbits/sec    2   55.1 KBytes
[  5]  14.01-15.01  sec  17.2 MBytes   144 Mbits/sec   31    102 KBytes
[  5]  15.01-16.01  sec  27.0 MBytes   226 Mbits/sec    5    178 KBytes
[  5]  16.01-17.00  sec  21.3 MBytes   179 Mbits/sec   35    180 KBytes
[  5]  17.00-18.01  sec  26.5 MBytes   221 Mbits/sec    5    164 KBytes
[  5]  18.01-19.01  sec  13.2 MBytes   111 Mbits/sec   21    102 KBytes
[  5]  19.01-20.01  sec  7.52 MBytes  63.1 Mbits/sec    7   62.2 KBytes
[  5]  20.01-21.01  sec  5.65 MBytes  47.4 Mbits/sec    2   56.6 KBytes
[  5]  21.01-22.01  sec  9.32 MBytes  78.2 Mbits/sec   28   91.9 KBytes
[  5]  22.01-23.01  sec  17.8 MBytes   150 Mbits/sec    8   89.1 KBytes
[  5]  23.01-24.01  sec  25.9 MBytes   217 Mbits/sec    0    173 KBytes
[  5]  24.01-25.00  sec  20.1 MBytes   169 Mbits/sec    1    156 KBytes
[  5]  25.00-26.01  sec  19.0 MBytes   159 Mbits/sec    5    165 KBytes
[  5]  26.01-27.01  sec  8.89 MBytes  74.5 Mbits/sec    9    102 KBytes
[  5]  27.01-28.00  sec  28.0 MBytes   235 Mbits/sec    0    182 KBytes
[  5]  28.00-29.00  sec  29.8 MBytes   250 Mbits/sec    5    199 KBytes
[  5]  29.00-30.01  sec  22.3 MBytes   186 Mbits/sec   35    113 KBytes
[  5]  30.01-31.00  sec  27.2 MBytes   229 Mbits/sec    0    185 KBytes
[  5]  31.00-32.00  sec  29.7 MBytes   248 Mbits/sec    5    170 KBytes
[  5]  32.00-33.01  sec  12.1 MBytes   101 Mbits/sec    9   96.2 KBytes
[  5]  33.01-34.01  sec  7.52 MBytes  63.1 Mbits/sec    6   74.9 KBytes
[  5]  34.01-35.01  sec  6.84 MBytes  57.3 Mbits/sec   65   82.0 KBytes
[  5]  35.01-36.00  sec  12.7 MBytes   107 Mbits/sec    2   65.0 KBytes
[  5]  36.00-37.00  sec  23.9 MBytes   200 Mbits/sec    0    154 KBytes
[  5]  37.00-38.01  sec  15.5 MBytes   130 Mbits/sec    1    130 KBytes
[  5]  38.01-39.01  sec  14.9 MBytes   125 Mbits/sec    5    143 KBytes
[  5]  39.01-40.01  sec  8.26 MBytes  69.3 Mbits/sec   10   52.3 KBytes
[  5]  40.01-41.01  sec  9.45 MBytes  79.2 Mbits/sec    2   1.41 KBytes
[  5]  41.01-42.01  sec  12.5 MBytes   105 Mbits/sec   30    105 KBytes
[  5]  42.01-43.01  sec  11.5 MBytes  96.5 Mbits/sec    1    113 KBytes
[  5]  43.01-44.01  sec  6.21 MBytes  52.1 Mbits/sec   52   60.8 KBytes
[  5]  44.01-45.01  sec  24.7 MBytes   207 Mbits/sec    0    156 KBytes
[  5]  45.01-46.00  sec  28.0 MBytes   236 Mbits/sec   12    156 KBytes
[  5]  46.00-47.01  sec  30.0 MBytes   251 Mbits/sec    1    150 KBytes
[  5]  47.01-48.01  sec  16.9 MBytes   142 Mbits/sec   14    109 KBytes
[  5]  48.01-49.01  sec  6.28 MBytes  52.6 Mbits/sec   20   70.7 KBytes
[  5]  49.01-50.01  sec  4.97 MBytes  41.7 Mbits/sec    3   39.6 KBytes
[  5]  50.01-51.01  sec  4.97 MBytes  41.7 Mbits/sec    2   59.4 KBytes
[  5]  51.01-52.01  sec  8.70 MBytes  73.0 Mbits/sec   16   70.7 KBytes
[  5]  52.01-53.00  sec  23.4 MBytes   197 Mbits/sec    0    157 KBytes
[  5]  53.00-54.01  sec  19.5 MBytes   162 Mbits/sec   36    120 KBytes
[  5]  54.01-55.01  sec  12.1 MBytes   101 Mbits/sec   36   91.9 KBytes
[  5]  55.01-56.01  sec  1.86 MBytes  15.6 Mbits/sec   34   22.6 KBytes
[  5]  56.01-57.01  sec  6.21 MBytes  52.1 Mbits/sec    2   29.7 KBytes
[  5]  57.01-58.01  sec  9.94 MBytes  83.4 Mbits/sec    1   80.6 KBytes
[  5]  58.01-59.01  sec  1.86 MBytes  15.6 Mbits/sec    3   26.9 KBytes
[  5]  59.01-60.01  sec  6.84 MBytes  57.3 Mbits/sec   22   48.1 KBytes
[  5]  60.01-61.01  sec  3.73 MBytes  31.3 Mbits/sec   14   32.5 KBytes
[  5]  61.01-62.01  sec  1.86 MBytes  15.6 Mbits/sec    7   24.0 KBytes
[  5]  62.01-63.01  sec  4.97 MBytes  41.7 Mbits/sec    2   32.5 KBytes
[  5]  63.01-64.01  sec  10.6 MBytes  88.6 Mbits/sec    2   83.4 KBytes
[  5]  64.01-65.01  sec  9.45 MBytes  79.2 Mbits/sec   27   86.3 KBytes
[  5]  65.01-66.01  sec  18.1 MBytes   152 Mbits/sec    1    116 KBytes
[  5]  66.01-67.01  sec  20.4 MBytes   172 Mbits/sec    5   93.3 KBytes
[  5]  67.01-68.01  sec  21.6 MBytes   181 Mbits/sec    0    164 KBytes
[  5]  68.01-69.01  sec  15.2 MBytes   127 Mbits/sec   23    132 KBytes
[  5]  69.01-70.01  sec  8.89 MBytes  74.5 Mbits/sec    2   74.9 KBytes
[  5]  70.01-71.01  sec  1.86 MBytes  15.6 Mbits/sec    7   36.8 KBytes
[  5]  71.01-72.01  sec  2.49 MBytes  20.9 Mbits/sec    3   19.8 KBytes
[  5]  72.01-73.01  sec  3.11 MBytes  26.1 Mbits/sec    2   45.2 KBytes
[  5]  73.01-74.01  sec  9.32 MBytes  78.2 Mbits/sec   19   87.7 KBytes
[  5]  74.01-75.01  sec  16.2 MBytes   136 Mbits/sec    1    124 KBytes
[  5]  75.01-76.01  sec  17.8 MBytes   149 Mbits/sec    1    129 KBytes
[  5]  76.01-77.01  sec  18.5 MBytes   155 Mbits/sec    1    105 KBytes
[  5]  77.01-78.01  sec  22.9 MBytes   192 Mbits/sec    0    175 KBytes
[  5]  78.01-79.01  sec  15.0 MBytes   126 Mbits/sec   19    107 KBytes
[  5]  79.01-80.01  sec  14.5 MBytes   122 Mbits/sec   16    122 KBytes
[  5]  80.01-81.01  sec  8.70 MBytes  73.0 Mbits/sec    2   91.9 KBytes
[  5]  81.01-82.01  sec  6.84 MBytes  57.3 Mbits/sec    2   73.5 KBytes
[  5]  82.01-83.01  sec  25.7 MBytes   216 Mbits/sec    0    167 KBytes
[  5]  83.01-84.01  sec  21.3 MBytes   179 Mbits/sec   31    154 KBytes
[  5]  84.01-85.01  sec  18.0 MBytes   151 Mbits/sec   27    139 KBytes
[  5]  85.01-86.01  sec  15.7 MBytes   132 Mbits/sec    1    123 KBytes
[  5]  86.01-87.01  sec  19.7 MBytes   165 Mbits/sec   15    156 KBytes
[  5]  87.01-88.01  sec  31.8 MBytes   267 Mbits/sec    0    225 KBytes
[  5]  88.01-89.01  sec  26.0 MBytes   218 Mbits/sec    5    181 KBytes
[  5]  89.01-90.01  sec  12.7 MBytes   107 Mbits/sec    5    106 KBytes
[  5]  90.01-91.00  sec  17.2 MBytes   145 Mbits/sec   16    136 KBytes
[  5]  91.00-92.01  sec  12.7 MBytes   107 Mbits/sec    6   1.41 KBytes
[  5]  92.01-93.01  sec  7.52 MBytes  63.1 Mbits/sec   23   74.9 KBytes
[  5]  93.01-94.01  sec  13.8 MBytes   116 Mbits/sec    3    109 KBytes
[  5]  94.01-95.01  sec  15.2 MBytes   127 Mbits/sec   17    105 KBytes
[  5]  95.01-96.01  sec  22.7 MBytes   190 Mbits/sec    1    157 KBytes
[  5]  96.01-97.01  sec  7.52 MBytes  63.1 Mbits/sec   21   77.8 KBytes
[  5]  97.01-98.00  sec  16.7 MBytes   140 Mbits/sec    1   93.3 KBytes
[  5]  98.00-99.01  sec  16.6 MBytes   139 Mbits/sec    4    130 KBytes
[  5]  99.01-100.01 sec  10.2 MBytes  85.5 Mbits/sec    2   73.5 KBytes
[  5] 100.01-101.01 sec  6.84 MBytes  57.3 Mbits/sec   26   49.5 KBytes
[  5] 101.01-102.01 sec  13.1 MBytes   110 Mbits/sec    1   74.9 KBytes
[  5] 102.01-103.01 sec  7.46 MBytes  62.6 Mbits/sec    6   49.5 KBytes
[  5] 103.01-104.01 sec  8.08 MBytes  67.8 Mbits/sec    2   62.2 KBytes
[  5] 104.01-105.01 sec  13.9 MBytes   116 Mbits/sec   18    110 KBytes
[  5] 105.01-106.01 sec  27.2 MBytes   228 Mbits/sec    0    189 KBytes
[  5] 106.01-107.00 sec  20.2 MBytes   170 Mbits/sec   19    163 KBytes
[  5] 107.00-108.01 sec  31.8 MBytes   266 Mbits/sec    0    230 KBytes
[  5] 108.01-109.01 sec  34.9 MBytes   292 Mbits/sec    0    286 KBytes
[  5] 109.01-110.01 sec  31.9 MBytes   268 Mbits/sec   36    226 KBytes
[  5] 110.01-111.00 sec  14.4 MBytes   122 Mbits/sec   36    173 KBytes
[  5] 111.00-112.01 sec  8.26 MBytes  68.9 Mbits/sec   25   77.8 KBytes
[  5] 112.01-113.01 sec  4.35 MBytes  36.5 Mbits/sec   25   42.4 KBytes
[  5] 113.01-114.01 sec  1.86 MBytes  15.6 Mbits/sec   18   45.2 KBytes
[  5] 114.01-115.01 sec  10.6 MBytes  88.6 Mbits/sec    6   79.2 KBytes
[  5] 115.01-116.01 sec  15.5 MBytes   130 Mbits/sec    1    124 KBytes
[  5] 116.01-117.01 sec  29.1 MBytes   244 Mbits/sec    0    199 KBytes
[  5] 117.01-118.00 sec  13.9 MBytes   117 Mbits/sec   46   89.1 KBytes
[  5] 118.00-119.01 sec  7.52 MBytes  62.8 Mbits/sec    2   73.5 KBytes
[  5] 119.01-120.01 sec  14.4 MBytes   121 Mbits/sec    1    116 KBytes
[  5] 120.01-121.01 sec  20.6 MBytes   173 Mbits/sec    4   99.0 KBytes
[  5] 121.01-122.01 sec  19.7 MBytes   165 Mbits/sec    1   1.41 KBytes
[  5] 122.01-123.01 sec  8.76 MBytes  73.5 Mbits/sec   21   1.41 KBytes
[  5] 123.01-124.01 sec  13.2 MBytes   111 Mbits/sec    1    107 KBytes
[  5] 124.01-125.01 sec  15.8 MBytes   133 Mbits/sec    1    127 KBytes
[  5] 125.01-126.01 sec  29.4 MBytes   247 Mbits/sec    0    204 KBytes
[  5] 126.01-127.01 sec  22.9 MBytes   192 Mbits/sec    1   1.41 KBytes
[  5] 127.01-128.01 sec  13.8 MBytes   116 Mbits/sec   19   1.41 KBytes
[  5] 128.01-129.01 sec  25.4 MBytes   213 Mbits/sec    0    173 KBytes
[  5] 129.01-130.01 sec  26.2 MBytes   220 Mbits/sec    0    228 KBytes
[  5] 130.01-131.01 sec  20.3 MBytes   171 Mbits/sec    5    180 KBytes
[  5] 131.01-132.01 sec  31.4 MBytes   264 Mbits/sec   27    177 KBytes
[  5] 132.01-133.00 sec  34.0 MBytes   287 Mbits/sec    0    242 KBytes
[  5] 133.00-134.01 sec  23.3 MBytes   194 Mbits/sec    1    173 KBytes
[  5] 134.01-135.01 sec  11.4 MBytes  95.9 Mbits/sec   23    116 KBytes
[  5] 135.01-136.01 sec  11.4 MBytes  95.4 Mbits/sec   11   79.2 KBytes
[  5] 136.01-137.01 sec  26.0 MBytes   218 Mbits/sec    0    167 KBytes
[  5] 137.01-138.01 sec  8.39 MBytes  70.4 Mbits/sec    7   82.0 KBytes
[  5] 138.01-139.01 sec  7.46 MBytes  62.6 Mbits/sec    7   1.41 KBytes
[  5] 139.01-140.01 sec  10.6 MBytes  88.6 Mbits/sec    1   94.7 KBytes
[  5] 140.01-141.01 sec  6.21 MBytes  52.1 Mbits/sec    9   52.3 KBytes
[  5] 141.01-142.01 sec  13.7 MBytes   115 Mbits/sec    1   93.3 KBytes
[  5] 142.01-143.01 sec  5.65 MBytes  47.4 Mbits/sec    6   52.3 KBytes
[  5] 143.01-144.01 sec  6.90 MBytes  57.9 Mbits/sec    2   60.8 KBytes
[  5] 144.01-145.01 sec  10.7 MBytes  89.7 Mbits/sec    2   72.1 KBytes
[  5] 145.01-146.01 sec  8.76 MBytes  73.5 Mbits/sec   22   76.4 KBytes
[  5] 146.01-147.01 sec  15.3 MBytes   128 Mbits/sec    1    124 KBytes
[  5] 147.01-148.01 sec  4.41 MBytes  37.0 Mbits/sec    3   46.7 KBytes
[  5] 148.01-149.01 sec  10.6 MBytes  89.1 Mbits/sec    2   96.2 KBytes
[  5] 149.01-150.01 sec  15.7 MBytes   131 Mbits/sec   26    115 KBytes
[  5] 150.01-151.01 sec  22.2 MBytes   187 Mbits/sec    0    178 KBytes
[  5] 151.01-152.01 sec  9.45 MBytes  79.2 Mbits/sec    2   93.3 KBytes
[  5] 152.01-153.01 sec  8.70 MBytes  73.0 Mbits/sec    2   82.0 KBytes
[  5] 153.01-154.01 sec  4.35 MBytes  36.5 Mbits/sec    6   58.0 KBytes
[  5] 154.01-155.01 sec  1.86 MBytes  15.6 Mbits/sec   19   17.0 KBytes
[  5] 155.01-156.01 sec  5.59 MBytes  46.9 Mbits/sec    2   70.7 KBytes
[  5] 156.01-157.01 sec  7.46 MBytes  62.6 Mbits/sec   18   62.2 KBytes
[  5] 157.01-158.01 sec  6.21 MBytes  52.1 Mbits/sec    2   50.9 KBytes
[  5] 158.01-159.01 sec  13.8 MBytes   116 Mbits/sec    5    110 KBytes
[  5] 159.01-160.01 sec  17.0 MBytes   143 Mbits/sec    6    141 KBytes
[  5] 160.01-161.01 sec  29.8 MBytes   250 Mbits/sec    5    139 KBytes
[  5] 161.01-162.01 sec  30.1 MBytes   253 Mbits/sec    0    209 KBytes
[  5] 162.01-163.01 sec  35.5 MBytes   298 Mbits/sec    0    270 KBytes
[  5] 163.01-164.00 sec  37.5 MBytes   316 Mbits/sec   36    198 KBytes
[  5] 164.00-165.01 sec  10.4 MBytes  86.7 Mbits/sec   30   89.1 KBytes
[  5] 165.01-166.01 sec  3.11 MBytes  26.1 Mbits/sec   23   49.5 KBytes
[  5] 166.01-167.00 sec  23.2 MBytes   195 Mbits/sec    0    147 KBytes
[  5] 167.00-168.01 sec  30.0 MBytes   251 Mbits/sec    1    141 KBytes
[  5] 168.01-169.01 sec  12.7 MBytes   106 Mbits/sec    2   66.5 KBytes
[  5] 169.01-170.01 sec  24.5 MBytes   205 Mbits/sec    0    158 KBytes
[  5] 170.01-171.01 sec  15.3 MBytes   129 Mbits/sec    5    156 KBytes
[  5] 171.01-172.01 sec  12.6 MBytes   106 Mbits/sec   37    110 KBytes
[  5] 172.01-173.01 sec  18.9 MBytes   158 Mbits/sec   36    137 KBytes
[  5] 173.01-174.01 sec  29.9 MBytes   251 Mbits/sec    0    212 KBytes
[  5] 174.01-175.01 sec  12.2 MBytes   103 Mbits/sec    9   72.1 KBytes
[  5] 175.01-176.01 sec  23.8 MBytes   200 Mbits/sec    0    164 KBytes
[  5] 176.01-177.01 sec  9.45 MBytes  79.2 Mbits/sec    1    116 KBytes
[  5] 177.01-178.01 sec  4.97 MBytes  41.7 Mbits/sec   29   60.8 KBytes
[  5] 178.01-179.01 sec  1.24 MBytes  10.4 Mbits/sec    7   28.3 KBytes
[  5] 179.01-180.01 sec  1.24 MBytes  10.4 Mbits/sec    3   28.3 KBytes
[  5] 180.01-181.01 sec  5.59 MBytes  46.9 Mbits/sec    2   60.8 KBytes
[  5] 181.01-182.01 sec  5.59 MBytes  46.9 Mbits/sec    2   50.9 KBytes
[  5] 182.01-183.01 sec  13.8 MBytes   116 Mbits/sec    5    112 KBytes
[  5] 183.01-184.01 sec  12.6 MBytes   105 Mbits/sec   44   76.4 KBytes
[  5] 184.01-185.01 sec  16.9 MBytes   142 Mbits/sec    1    113 KBytes
[  5] 185.01-186.01 sec  5.78 MBytes  48.5 Mbits/sec    4   53.7 KBytes
[  5] 186.01-187.01 sec  3.73 MBytes  31.3 Mbits/sec    3   42.4 KBytes
[  5] 187.01-188.01 sec  10.0 MBytes  83.9 Mbits/sec    1   91.9 KBytes
[  5] 188.01-189.01 sec  4.97 MBytes  41.7 Mbits/sec   24   43.8 KBytes
[  5] 189.01-190.01 sec  10.1 MBytes  84.4 Mbits/sec    6   50.9 KBytes
[  5] 190.01-191.01 sec  8.08 MBytes  67.8 Mbits/sec    2   1.41 KBytes
[  5] 191.01-192.01 sec  20.4 MBytes   171 Mbits/sec    0    134 KBytes
[  5] 192.01-193.01 sec  17.9 MBytes   150 Mbits/sec    1    153 KBytes
[  5] 193.01-194.01 sec  20.3 MBytes   171 Mbits/sec   22    107 KBytes
[  5] 194.01-195.01 sec  6.21 MBytes  52.1 Mbits/sec    6   58.0 KBytes
[  5] 195.01-196.01 sec  4.35 MBytes  36.5 Mbits/sec    4   45.2 KBytes
[  5] 196.01-197.01 sec  8.08 MBytes  67.8 Mbits/sec    2   1.41 KBytes
[  5] 197.01-198.01 sec  3.73 MBytes  31.3 Mbits/sec    2   38.2 KBytes
[  5] 198.01-199.01 sec  9.94 MBytes  83.4 Mbits/sec    2   82.0 KBytes
[  5] 199.01-200.01 sec  17.6 MBytes   148 Mbits/sec    1    107 KBytes
[  5] 200.01-201.01 sec  10.0 MBytes  84.0 Mbits/sec   34   79.2 KBytes
[  5] 201.01-202.00 sec  15.2 MBytes   128 Mbits/sec    1    116 KBytes
[  5] 202.00-203.01 sec  6.34 MBytes  52.9 Mbits/sec    8   72.1 KBytes
[  5] 203.01-204.01 sec  1.24 MBytes  10.4 Mbits/sec   13   31.1 KBytes
[  5] 204.01-205.01 sec  1.86 MBytes  15.6 Mbits/sec    3   33.9 KBytes
[  5] 205.01-206.01 sec  4.97 MBytes  41.7 Mbits/sec    3   25.5 KBytes
[  5] 206.01-207.01 sec  6.84 MBytes  57.3 Mbits/sec    2   53.7 KBytes
[  5] 207.01-208.01 sec  10.6 MBytes  88.6 Mbits/sec   11   77.8 KBytes
[  5] 208.01-209.01 sec  17.5 MBytes   147 Mbits/sec    5    130 KBytes
[  5] 209.01-210.01 sec  17.6 MBytes   148 Mbits/sec    1    120 KBytes
[  5] 210.01-211.01 sec  16.0 MBytes   134 Mbits/sec    5    122 KBytes
[  5] 211.01-212.01 sec  13.9 MBytes   116 Mbits/sec   26    103 KBytes
[  5] 212.01-213.01 sec  20.4 MBytes   171 Mbits/sec    1    100 KBytes
[  5] 213.01-214.01 sec  12.8 MBytes   107 Mbits/sec    1    106 KBytes
[  5] 214.01-215.00 sec  12.6 MBytes   106 Mbits/sec    6    109 KBytes
[  5] 215.00-216.01 sec  18.3 MBytes   153 Mbits/sec   25    127 KBytes
[  5] 216.01-217.01 sec  18.3 MBytes   153 Mbits/sec   17    147 KBytes
[  5] 217.01-218.01 sec  23.0 MBytes   193 Mbits/sec    0    201 KBytes
[  5] 218.01-219.00 sec  26.3 MBytes   222 Mbits/sec   36    195 KBytes
[  5] 219.00-220.01 sec  20.5 MBytes   171 Mbits/sec    6   32.5 KBytes
[  5] 220.01-221.01 sec  14.3 MBytes   120 Mbits/sec    1    113 KBytes
[  5] 221.01-222.01 sec  3.11 MBytes  26.1 Mbits/sec   61   45.2 KBytes
[  5] 222.01-223.01 sec  4.35 MBytes  36.5 Mbits/sec    3   41.0 KBytes
[  5] 223.01-224.01 sec  15.0 MBytes   126 Mbits/sec    1   80.6 KBytes
[  5] 224.01-225.01 sec  8.82 MBytes  74.0 Mbits/sec    6   58.0 KBytes
[  5] 225.01-226.00 sec  24.0 MBytes   203 Mbits/sec    0    151 KBytes
[  5] 226.00-227.01 sec  29.1 MBytes   243 Mbits/sec    5    157 KBytes
[  5] 227.01-228.01 sec  14.8 MBytes   124 Mbits/sec   32   1.41 KBytes
[  5] 228.01-229.01 sec  15.1 MBytes   127 Mbits/sec   29   97.6 KBytes
[  5] 229.01-230.01 sec  28.9 MBytes   242 Mbits/sec   39    482 KBytes
[  5] 230.01-231.01 sec  47.3 MBytes   396 Mbits/sec    0    550 KBytes
[  5] 231.01-232.01 sec  45.9 MBytes   385 Mbits/sec   10    413 KBytes
[  5] 232.01-233.01 sec  44.8 MBytes   376 Mbits/sec    0    450 KBytes
[  5] 233.01-234.01 sec  39.0 MBytes   327 Mbits/sec   59    233 KBytes
[  5] 234.01-235.01 sec  34.1 MBytes   286 Mbits/sec   36    206 KBytes
[  5] 235.01-236.01 sec  16.9 MBytes   142 Mbits/sec   36    182 KBytes
[  5] 236.01-237.01 sec  5.90 MBytes  49.5 Mbits/sec   29    144 KBytes
[  5] 237.01-238.01 sec  31.1 MBytes   261 Mbits/sec    0    216 KBytes
[  5] 238.01-239.00 sec  19.4 MBytes   163 Mbits/sec   39   99.0 KBytes
[  5] 239.00-240.00 sec  17.0 MBytes   142 Mbits/sec    1    120 KBytes
[  5] 240.00-241.00 sec  28.6 MBytes   241 Mbits/sec    0    198 KBytes
[  5] 241.00-242.01 sec  20.4 MBytes   170 Mbits/sec    2    102 KBytes
[  5] 242.01-243.00 sec  9.20 MBytes  77.6 Mbits/sec   36   72.1 KBytes
[  5] 243.00-244.01 sec  13.5 MBytes   113 Mbits/sec    8    102 KBytes
[  5] 244.01-245.00 sec  28.3 MBytes   238 Mbits/sec    0    182 KBytes
[  5] 245.00-246.01 sec  20.1 MBytes   168 Mbits/sec   27    164 KBytes
[  5] 246.01-247.00 sec  21.4 MBytes   180 Mbits/sec   28    163 KBytes
[  5] 247.00-248.01 sec  31.7 MBytes   265 Mbits/sec    0    229 KBytes
[  5] 248.01-249.01 sec  37.7 MBytes   316 Mbits/sec    0    287 KBytes
[  5] 249.01-250.01 sec  39.2 MBytes   329 Mbits/sec    0    335 KBytes
[  5] 250.01-251.01 sec  43.2 MBytes   362 Mbits/sec    0    382 KBytes
[  5] 251.01-252.01 sec  44.7 MBytes   376 Mbits/sec    0    423 KBytes
[  5] 252.01-253.01 sec  43.3 MBytes   363 Mbits/sec   36    298 KBytes
[  5] 253.01-254.01 sec  41.0 MBytes   344 Mbits/sec    0    344 KBytes
[  5] 254.01-255.01 sec  36.0 MBytes   302 Mbits/sec   36    286 KBytes
[  5] 255.01-256.01 sec  37.8 MBytes   317 Mbits/sec    0    334 KBytes
[  5] 256.01-257.01 sec  40.1 MBytes   337 Mbits/sec   31    173 KBytes
[  5] 257.01-258.01 sec  20.2 MBytes   169 Mbits/sec    0    218 KBytes
[  5] 258.01-259.01 sec  18.3 MBytes   153 Mbits/sec   38    137 KBytes
[  5] 259.01-260.01 sec  7.83 MBytes  65.7 Mbits/sec   29   67.9 KBytes
[  5] 260.01-261.01 sec  11.4 MBytes  95.9 Mbits/sec   24    103 KBytes
[  5] 261.01-262.01 sec  10.8 MBytes  90.7 Mbits/sec    6   77.8 KBytes
[  5] 262.01-263.01 sec  16.8 MBytes   141 Mbits/sec    8    100 KBytes
[  5] 263.01-264.01 sec  18.0 MBytes   151 Mbits/sec    8    107 KBytes
[  5] 264.01-265.01 sec  28.0 MBytes   235 Mbits/sec    0    188 KBytes
[  5] 265.01-266.01 sec  15.0 MBytes   126 Mbits/sec   34    158 KBytes
[  5] 266.01-267.01 sec  20.5 MBytes   172 Mbits/sec    1    143 KBytes
[  5] 267.01-268.01 sec  17.2 MBytes   144 Mbits/sec   30    132 KBytes
[  5] 268.01-269.01 sec  29.1 MBytes   244 Mbits/sec    1    137 KBytes
[  5] 269.01-270.00 sec  29.8 MBytes   251 Mbits/sec    0    206 KBytes
[  5] 270.00-271.01 sec  28.7 MBytes   240 Mbits/sec    5    182 KBytes
[  5] 271.01-272.01 sec  33.1 MBytes   278 Mbits/sec    0    245 KBytes
[  5] 272.01-273.00 sec  30.8 MBytes   259 Mbits/sec   37    218 KBytes
[  5] 273.00-274.00 sec  34.1 MBytes   285 Mbits/sec    0    273 KBytes
[  5] 274.00-275.01 sec  37.3 MBytes   312 Mbits/sec   37    228 KBytes
[  5] 275.01-276.01 sec  34.9 MBytes   292 Mbits/sec    0    279 KBytes
[  5] 276.01-277.01 sec  20.3 MBytes   170 Mbits/sec   39    143 KBytes
[  5] 277.01-278.01 sec  11.1 MBytes  93.3 Mbits/sec    5   93.3 KBytes
[  5] 278.01-279.01 sec  21.3 MBytes   179 Mbits/sec    0    163 KBytes
[  5] 279.01-280.01 sec  7.08 MBytes  59.4 Mbits/sec   39   56.6 KBytes
[  5] 280.01-281.01 sec  14.7 MBytes   124 Mbits/sec    1   79.2 KBytes
[  5] 281.01-282.01 sec  24.7 MBytes   207 Mbits/sec    0    163 KBytes
[  5] 282.01-283.01 sec  30.6 MBytes   257 Mbits/sec    0    228 KBytes
[  5] 283.01-284.00 sec  34.5 MBytes   291 Mbits/sec   30    173 KBytes
[  5] 284.00-285.01 sec  24.9 MBytes   208 Mbits/sec    1    177 KBytes
[  5] 285.01-286.01 sec  32.7 MBytes   274 Mbits/sec    0    242 KBytes
[  5] 286.01-287.00 sec  18.3 MBytes   154 Mbits/sec   36    164 KBytes
[  5] 287.00-288.01 sec  17.9 MBytes   149 Mbits/sec   36    141 KBytes
[  5] 288.01-289.01 sec  22.9 MBytes   192 Mbits/sec    3    157 KBytes
[  5] 289.01-290.01 sec  23.3 MBytes   195 Mbits/sec    5    177 KBytes
[  5] 290.01-291.01 sec  21.6 MBytes   181 Mbits/sec    1   1.41 KBytes
[  5] 291.01-292.01 sec  7.02 MBytes  58.9 Mbits/sec   51   94.7 KBytes
[  5] 292.01-293.01 sec  3.42 MBytes  28.7 Mbits/sec    8   35.4 KBytes
[  5] 293.01-294.01 sec  3.42 MBytes  28.7 Mbits/sec    5   45.2 KBytes
[  5] 294.01-295.01 sec  4.23 MBytes  35.4 Mbits/sec   11   31.1 KBytes
[  5] 295.01-296.01 sec  11.9 MBytes   100 Mbits/sec    8    103 KBytes
[  5] 296.01-297.01 sec  6.21 MBytes  52.1 Mbits/sec   29   39.6 KBytes
[  5] 297.01-298.01 sec  2.73 MBytes  22.9 Mbits/sec   16   26.9 KBytes
[  5] 298.01-299.01 sec  1.37 MBytes  11.5 Mbits/sec    3   18.4 KBytes
[  5] 299.01-300.00 sec  2.05 MBytes  17.2 Mbits/sec    3   31.1 KBytes
[  5]   0.00-300.00 sec  4.90 GBytes   140 Mbits/sec  3702             sender
Server listening on 5201
RB951Ui-2HnD. After the upgrade to 6.42, the first port does not work
No improvement on the hAP ac^2. Similar results to the ones above.
Previous versions don’t support for these? What actually was not supported? We have one LHG-5ac that is in bridge mode but its UM assigned authentication is coming and going…
add admin-mac=E4:8D:8C:53:5A:9B auto-mac=no fast-forward=no name=bridge1
add bridge=bridge1 interface=wlan1
add bridge=bridge1 interface=ether1-local
/interface pppoe-client
add add-default-route=yes disabled=no interface=bridge1 keepalive-timeout=60 max-mru=1500 max-mtu=1500 name=pppoe-out1 service-name=internet use-peer-dns=yes \
    user="**************************"
“************” is actually real name…
/interface pppoe-client> pr
Flags: X - disabled, I - invalid, R - running
 0  R name="pppoe-out1" max-mtu=1500 max-mru=1500 mrru=disabled interface=bridge1 user="************************" password="" profile=default
      keepalive-timeout=60 service-name="internet" ac-name="" add-default-route=yes default-route-distance=1 dial-on-demand=no use-peer-dns=yes
      allow=pap,chap,mschap1,mschap2
When we make a telnet to this router we see the client getting its assigned IP.
 /ip address> pr
 #   ADDRESS            NETWORK         INTERFACE
 0 D 192.168.226.80/24  192.168.226.0   vlan2_Gestion_P2MP
 1 D 192.168.201.210/32 192.168.200.1   pppoe-out1
It also creates the gw
/ip route> pr
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme, B - blackhole, U - unreachable, P - prohibit
 0 ADS  0.0.0.0/0                          pppoe-out1                1
 1  DS  0.0.0.0/0                          192.168.226.1             2
 2 ADC  192.168.200.1/32   192.168.201.210 pppoe-out1                0
 3 ADC  192.168.226.0/24   192.168.226.80  vlan2_Gestion_P2MP        0
We had 6.42rc37 installed when the problem was noticed (We needed this version to have the ‘arm’ radio to connect anyway…
We managed to update it via de management network to 6.42 current
But the issue is still there.
We have several ‘arm’ units running with pppoe-clients but the pppoe client sits usually on the wlan1 interface. In this case it is on the bridge.
Anybody any suggestions?
Previously you could not install User Manager server on ARM systems at all.
After upgrade, on hAP ac2 and cAP ac I see strange channel options, XXX :slight_smile:
In CLI:
[admin@KowalCAP] > /int wire set 1 channel-width=
ChannelWidth ::= 10mhz | 20/40/80/160mhz-Ceeeeeee | 20/40/80/160mhz-XXXXXXXX | 20/40/80/160mhz-eCeeeeee | 20/40/80/160mhz-eeCeeeee | ...
Winbox:
I also installed 6.42 on friend’s hAP ac^2, previously on 6.41.4 on 5GHz-AC with laptop card Intel DualBand 8260 has transfer 8-14 Mbit… Waiting for results. On TP-Link T4UH v1 (RTL8812AU chipset) I have transfers about 130 - 150 Mbit/s.
After work I will check performance with cAP ac and TP-Link T4UH.
Upgraded a bunch of hEX r3, wAP AC and hAP AC (original) with no issues. Holding off on the CCR-1009 for a bit.
Thanks for another great update.
How about this feature released at 6.42rc52?
*) chr - added support for “multi-queue” feature for “virtio-net” drivers
There is no mention on 6.42 changelog and it’s a feature I’ve been waiting for.
Thanks again!
I can’t see any improvement in Nv2 PTMP, someone have some tests and can share AP and client configuration?
did you upgrade AP and stations, or only AP ?
