v6.43.11 [stable] is released!
RouterOS version 6.43.11 has been released in public “stable” channel!
Before an upgrade:
  2. Make sure the device will not lose power during upgrade process;
  3. Device has enough free storage space for all RouterOS packages to be downloaded.
What’s new in 6.43.11 (2019-Feb-04 12:24):
Changes in this release:
*) ipsec - accept only valid path for “export-pub-key” parameter in “key” menu;
*) quickset - fixed “country” parameter not properly setting regulatory domain configuration;
*) smb - fixed possible buffer overflow;
*) w60g - fixed disconnection issues in PtMP setups;
*) wireless - improved antenna gain setting for devices with built in antennas;
*) wireless - show indoor/outdoor frequency limitations under “/interface wireless info country-info” command;
What’s new in 6.43.10 (2019-Jan-24 07:09):
(factory only release)
What’s new in 6.43.9 (2019-Jan-10 07:11):
To upgrade, click “Check for updates” at /system package in your RouterOS configuration interface, or head to our download page: http://www.mikrotik.com/download
If you experience version related issues, then please send supout file from your router to support@mikrotik.com. File must be generated while router is not working as suspected or after some problem has appeared on device
Please keep this forum topic strictly related to this concrete RouterOS release.
Is the 5 GHz issue with RB4011 fixed ?
I have been testing for an hour, it works, it does not fall.
Please provide us step by step example how to repeat your mentioned issue with attached supout.rif file to support@mikrotik.com.
Can we have more info about that.
What kind of more information you require? It simply validates the file-name value when exporting a public key from IPsec Keys menu.
release the 6.44 as stable. don’t releasing spam updates !!!
Newer generation iPhone/iPad issue will be fixed in RouterOS v6.44
WW Dish before upgrade: RSSI -49 on both ends, after upgrade -56 on one side, -59 on 2nd side
After a reboot one side was fixed at -49 RSSI again, but 2nd shows MCS 1 and signal level 20, RSSI -59 again.
After another reboot, it is back on -49 on both ends with MCS 8 and signal level 95.
Another issue iswith making supout.rif - after waiting for more than 10 minutes, it was stucked at 1%. When stopped and tried to run again, I just got an error message: Couldn’t start - busy.
Yes, the same problems, 5ghz fell - turned off.
RB3011-RM updated with no problems
They are fixing the places where commands can write to arbitrary files and thus can destroy internal configuration or open the built-in shell.
Another example was the telnet session log that was recently fixed.
Those bugs can be used by malware to cause more trouble and/or prevent removal of the malware, although they do not pose a security problem themselves.
One mans spam, is another mans meat.
To put things in perspective, in Newfoundland, the poor folk had to eat sandwiches everyday of lobster meat.
How awful. :slight_smile:
If an interim release is deemed required by MT, then so be it.
I am just super happy they ignore ignorant comments.
I just marked your post as spam!
As for the topic at hand. I recently manually inserted a 2DB antenna gain after watching a recent MUM presentation in the UK (on my capacs).
Will the update automatically insert that gain??
http://forum.mikrotik.com/t/problem-with-mount-point/94/1
Says It should be released in the next public beta version.
Already wating long time now
Aren’t you still planning to integrate udpxy from openwrt into RouterOS? It depends only from libc, and compiles under any architecture easily, and a lot of users pleasing you to add, and when you claims “router should do routing and not being overloaded by 3rd party crap” - that’s it, just route for my TV’s udp multicast to http tcp stream, this action won’t eat CPU so much. You are don’t giving a chance to do anything, proprietary OS, no toolchains to compile, no ways to create packages, just metarouter - that is not useful on hAP.
After upgrading hEX and hAP ac from 6.43.8 to 6.43.11 (ROS and FW) samba got broken.
I got the following message in Windows 10:
\router.lan\backup is not accessible. You might not have permission to use this network resource…
The parameter is incorrect.
I restored access to samba shares by downgrading hEX back to 6.43.8 and hAP ac to 6.43.10 (factory only release).
Memory leak in proxy on HEX r3 still present. Behavior is the same as described in the 6.43.8 thread
With proxy disabled the memory usage is around 42mb. If you enable the proxy but don’t send any traffic the memory consumption stays at 42mb. As soon as you open the web proxy interface in winbox the memory consumption jumps to 64mb (still no traffic via proxy). As soon as any traffic flows via the proxy the memory consumption jumps to 102mb. At the same time, if you go and look at the proxy it says Total RAM Used: 996KiB. So something somewhere is leaking close to 60mb. This did not happen before on 6.42.7 or older versions.
Upgraded from 6.43.8 → 6.43.11
using dude to push the packages on
CCR1009-8G-1S (2x ipsec/l2tp site-to-site, dhcpd)
CRS125-24G-1S
RB1100
RB962UiGS-5HacT2HnT (10pc)
RB951
RB750GL
RB2011UAS-RM
CHR running dude (CHR running in VirtualBox on OSX)
without any issues
What it exactly means?
I guess it works now. :slight_smile:
May be they have some predefined defaults for such devices ?
So users report lower signal after upgrade…
