v6.49.4 60GHz disconnects Mikrotik nRAYG-60ad
After upgrading from v6.49.2 to the latest stable v6.49.4, the Mikrotik nRAYG-60ad pair disconnects down every few days.
In the log there is only the message wlan60-staton-1: link down
I have had these problems twice so far. Every time it happend weather outside was sunny and clear.
Signal is fine (above 80%) and RSSI value is around -55dB. When it works we have full capacity available (2.3Gbps)
Before the upgrade link was online for 60 days with no issues.
I have tried to restart client nRAY and noting happend.
Also disable and enable of the AP w60interface didnt help.
After AP was restarted everthing works again until next time.
Hello, how are you? Were you able to solve the problem?
Thank you.
