v7.0.3 Chateau
Can someone re-upload v7.0.3 stable version for chateau?
The link posted in the previous threads is expired and it is impossible to download the only stable version for this router.
Please don’t use that version. It is in no way stable or suggested. It is just a number.
If you care for an actually stable version, use 7.1rc6
+1
“Stable” means that v7.0.3 has passed QA/QC tests for Chateau. Unfortunately, it does not mean “bug-free”. Since there is no reported Chateau-specific regression from v7.0.3 to 7.1rc6, we recommend using the latter. If you already use v7.0.3 and are happy with the firmware, you may keep it until v7.1 stable release. Otherwise, upgrade to 7.1rc6, as that proved general stability except for some edge-case issues that we are 100% focused on fixing.
please see this post ros7 have a bug
http://forum.mikrotik.com/t/socks5-not-working-in-routeros7/153414/1
