If there are no need for function from 7.1 do not upgrade yet.
When upgrade, do it on a 100% equal unit with same configuration and same RouterOS as the remote.
If that goes well, it may be that you can upgrade the remote device.
I totally agree with Jotne: do NOT upgrade on business critical systems yet!
And make sure you have physical access to the devices you want to upgrade to 7.1 to be prepaired to downgrade via netinstall, if nessesary.
Ahh, MikroTik cleans up the DOWNLOAD section
It´s now separeted between ROS V6 and ROS V7.
Makes it more clear!! @MikroTik: one remark: in the device lists over the chip section the RB5009 is still missing at ARM64
Remote devices need to be upgraded too at some point and it is not always possible to have someone on site to hard reset or even netinstall. I’m sure there are many, many of us who manage remote Mikrotik devices (especially in home & soho environment) on behalf of dumb users on the other side. In such cases it could be a nightmare if the upgrade fails catastrophically. Hopefully reliability of upgrades will continue to be improved..
So how do you expect your firewall to function properly?
You have two rules that use the LAN interface list
add action=drop chain=input comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
add action=drop chain=forward comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
Tried on a W60g link - the 60G link is established, but IP-traffic over it is not working. Not ready much for anything it seems.
Edit: It seems that it was putting the station interface to a wrong bridge after upgrade and changing it did bring the IP-traffic up and working for that link.
Note: Make RoMon transfer files as well, that at least it will make it good for bringing firmware files over the non-ip trunk.
[quote=ganyda post_id=896282 time=1638974808 user_id=194268]
can’t input text in this column
[/quote]
That is correct. You need to create new routing tables under the routing->table menu now.
