OpenVPN is still useless without more secure auth methods, like SHA256. Most VPN providers use this auth method in their ovpn configurations, any chance that it will be added anytime soon?
Tried this version on my wAP AC and hAP AC. On both I have problem with 5Ghz WiFi in direction from client to router. Receiving fine, but transmitting braking, stops. Tried different devices, LAN and WAN destination - same result.
Last “official” info was that IPv6 fast track is in the backlog but not yet on the roadmap.
See initial posting in this thread: Feature Request : IPv6 Fasttrack
If you think this feature should be prioritized, please raise your voice there to increase visibility.
It works fine here! Are you sure your interface lists (LAN, WAN) are correct?
Maybe it is better that you reset the entire router to default, when you don’t have a lot of special config in there this is much easier.
i disable all rules in filter and raw
and i stay only with accept established/related in forward
and drop invalid.
Even if i have only this two rules, all connections go to drop as invalid
and nothing catch in accept.
use /export file=name show-sensitive, download the file, reset router to defaults, setup router with quickset (choose PPPoE there), now verify that everything is working OK.
Now use the downloaded file AS A GUIDE to know what else you NEED to put back. Do NOT blindly put everything back, only what you NEED.
(e.g. port forward, WiFi SSID and password)
That will solve the problem. Now whenever you make “improvements”, test them and be prepared to change them back.
I believe VTI was not present in the Linux kernel that RouterOS v6 used, but it should be in the kernel that RouterOS v7 uses, so theoretically it shouldn’t be much harder to implement than Wireguard. Probably they did not want to implement it right away to prevent the ipsec code from diverging between v6 and v7 to make backporting or forward-porting easier, until 7 was stable enough.
Is anybody else seeing their link dropping with SFP+ interfaces on a CRS328-24P-4S+? Every SFP+ I have is showing link down/up events sporadically. These did not occur prior to update. I cleaned/reinstalled SFPs, but the behavior is the same. FS SFP-10GLR-31 for the SFP+s.
Uplink:
sfpplus2:
4 is the same, so no need for another SS.
Link status:
SUP-68278 in for the link flapping, it’s affecting all SFP+s on the switch, which are connected to various other devices/SFPs.
Upgraded to v7.1 a while ago and I’m still struggling to run the recursive fail-over configuration I was using. It’s just stating Invalid on multiple rules and refuses to work. Are recursive routes working on v7 at all?
i found the problem with ipv6 connections and drop packets in mangle rules.
If i have any packet mark to post routing, the connections drop as invalid.
If i disable the packet marks, all work perfect: no drop packet and connections tabs show the connections.
But without packet mangle i cant have qos in ipv6.
Seems there are too many bugs that needs to be baked to have a solid stable release!. I am happy that Mikrotik is finally doing the big push here for RouterOS v7 but needs to polish all these issues that everyone is reporting in this forum
