Crs326 - bonding stop working after update to 7.13
Disabling/enabling bonding interface, recreation doesn’t help.
Traffic is just stop going after update. (Synology nas is in the other end)
Thanks, however, HAP AC3 (RBD53iG-5HacD2HnD) central led now flashing red. I believe this central LED is related to lte / wps?
Up until version 7.12.1 it was solid blue.
Please advise.
Upgraded two LHG XL52 ac (PtP setup), settings were intact, no issue with signal (-42), devices register themselves on one another (both 2GHz and 5GHz), but can’t see other LHG via Winbox.
Any clues ?
Are you using the new wifi package? If yes, it does not support station bridge mode yet with old devices/old driver! I use bridge and eoip over wifi link for extending the L2 segment
I know it’s a guessing game, but I cannot find what seems to be the problem. I have 2 pairs of PtP link, similar setup (apart for SSID names etc). Both pairs were on 6.49.11. I’ve upgraded both pairs to 7.12.1 and both were working. Now I upgraded one pair to 7.13 and have above issues. I checked all settings but cannot find the cause.
When i upgraded LHG52 to 7.13 first in didn’t even see wireless intefaces even if wireless package was installed (checked). Probably because there was also Zerotier package on it and something went wrong with the instalation (to little space for all those packages).
I just deleted it and installed qcom ac package and everything seems fine.
Yes!
Just tested this and your’re right. After connecting the USB modem the LED starts flashing red.
Unplugging it doesn’t change it’s behavior. You need to reboot the whole router with the modem unplugged. Plugging it back makes the LED starts blinking red again.
EDIT: disabling the dynamic lte1 interface also restores the LED back to normal (static blue).
At least with FT disabled, the default connect-priority setting delays roaming to a new AP until a client has disconnected from its previous AP. With my Android phone this caused several seconds of delay when roaming.
Setting connect-priority=0/1 ensures connections to a new AP are immediately accepted and the old AP connection is dropped automatically. When using PSK authentication, this allows seamless roaming even without FT.
I have the same problem with script on CHR after upgrade
Download from https://antifilter.download/list/ip.lst to <nothing> FINISHED
Download from https://antifilter.download/list/ip.lst to RAM FAILED: Fetch failed with status 206
