v7.14.3 [stable] is released!
RouterOS version 7.14 have been released in the “v7 stable” channel!
Before an upgrade:
  2. Make sure the device will not lose power during upgrade process;
  3. Device has enough free storage space for all RouterOS packages to be downloaded.
What’s new in 7.14.3 (2024-Apr-17 15:47):
*) bgp - correctly synchronize input.accept-nlri address list;
*) bridge - use default “edge=auto” for dynamically bridged interfaces (PPP, VPLS, WDS);
*) disk - improved system stability;
*) fetch - fixed slow throughput due to “raw” logging which occurred even when not listening to the topic (introduced in v7.13);
*) queue - improved system stability (introduced in v7.6);
*) wifi-qcom - added configuration.distance setting to enable operation over multi-kilometer distances (CLI only);
What’s new in 7.14.2 (2024-Mar-27 09:48):
*) defconf - do not override default DHCP server lease time;
*) defconf - fixed 5ghz-ax channel width for L11, L22 devices;
*) ethernet - fixed interface disable for CRS326-4C+20G+2Q;
*) ethernet - improved port speed downshift functionality for CRS326-4C+20G+2Q;
*) leds - fixed LEDs for L22 device;
*) lte - fixed firmware upgrade not found issue for Chateau LTE12 (introduced in v7.14.1);
*) ssh - require “policy” user policy when adding public key;
*) timezone - updated timezone information from “tzdata2024a” release;
*) traffic-flow - improved system stability;
*) vrf - fixed VRF interfaces being moved to main table after reboot (introduced in v7.14);
What’s new in 7.14.1 (2024-Mar-08 14:50):
*) bgp-vpn - use VRF interface as gateway for leaked connected routes;
*) chr - fixed Xen and Vultr missing ethernet (introduced in v7.14);
*) chr - fixed bogus messages printed out while booting up the system (introduced in v7.14);
*) console - fixed do/while implementation not working with variables (introduced in v7.14);
*) ethernet - fixed default names for CRS310-8G+2S+ device (introduced in v7.14);
*) lte - fixed R11e-LTE-US modem dial-up;
*) sfp - improved system stability for CR2004-1G-2XS-PCIe (introduced in v7.14);
*) wireguard - do not attempt to connect to peer without specified endpoint-address;
What’s new in 7.14 (2024-Feb-29 09:10):
!) rose-storage - moved SMB service to the RouterOS bundle;
!) smb - removed legacy SMB service (replaced with newer and faster ROSE SMB service, compatible with SMB 2.1, SMB 3.0 and SMB 3.1.1);
*) 6to4 - make “ipsec-secret” sensitive parameter;
*) api - improved REST API stability when processing invalid requests;
*) api - properly return SNMP OIDs when requested;
*) arm - improved system stability when using microSD on RB1100Dx4;
*) arp - added ARP status;
*) bgp - allow to leak routes between local VRFs;
*) bridge - added MLAG support for MSTP bridges;
*) bridge - avoid per-VLAN host flushing on HW offloaded bridge;
*) bridge - fixed auto “path-cost” for bonding interfaces (introduced in v7.13);
*) bridge - fixed MLAG connection after peer-link flap (introduced in v7.13);
*) bridge - fixed packet forwarding after changing HW offloaded bridge interface settings in certain cases (introduced in v7.13);
*) bridge - improved bridge VLAN configuration validation;
*) bridge - improved configuration speed on large VLAN setups;
*) bridge - improved protocol-mode MSTP functionality;
*) bridge - improved protocol-mode STP and RSTP functionality;
*) bridge - make “point-to-point=yes” default value for non-wireless bridge ports;
*) bridge - removed “mst-config-digest” from MSTI menu;
*) bridge - try to set wireless bridge ports as edge ports automatically;
*) bth - added simple “Back To Home Users” manager under IP/Cloud menu;
*) calea - improved system stability when adding bridge rule without “calea” package installed;
*) certificate - improved certificate validation performance;
*) console - added “:tolf” and “:tocrlf” commands for converting line break to/from LF or CRLF;
*) console - added “show-at-cli-login” option to display a note before telnet login;
*) console - added missing “where” clause for “/ipv6/firewall/filter” table print command;
*) console - do not accept negative or too large values for “:delay” command;
*) console - do not allow to use out-of-range values for time type fields;
*) console - fix configuration export when user does not have a “sniff” policy;
*) console - fixed delayed output from “:grep” command in certain cases;
*) console - fixed incorrect behavior of “:onerror” command in certain cases;
*) console - hint on reset command help that “.rsc file” is required for “run-after-reset” parameter;
*) console - improved editor functionality in full screen mode;
*) console - improved stability when using autocomplete with “export”;
*) console - increased maximum file content length that can be managed through command line to 60 KB;
*) console - updated copyright notice;
*) container - improved VETH interface management responsiveness and reliability;
*) container - restrict “/container/shell” menu for users without “write” permissions;
*) defconf - added log about configuration reset due to pressed reset button;
*) defconf - fixed Audience scanning-for-wps-ap timeout;
*) defconf - fixed configuration script on KNOT devices if “ppp-out” interface is removed;
*) defconf - fixed firewall rule for IPv6 UDP traceroute;
*) defconf - fixed wifi configuration if interface MAC address is changed;
*) defconf - improved wifi interface detection after upgrade;
*) defconf - increased LTE interface wait time;
*) defconf - updated health settings on configuration revert;
*) defconf - use “fq_codel” queue as default interface queue for wired ports on LTE devices;
*) dhcpv6-client - install dynamic IPv6 blackhole routes in corresponding routing-table;
*) dhcpv6-client - updated error logging when multiple prefixes received on renew;
*) disk - added exFAT and NTFS mount/read/write support;
*) disk - added global disk “settings” menu;
*) disk - fixed changing settings on some GPT formatted disks;
*) disk - properly unmount disk when it is disconnected;
*) dns - do not add new entries to cache if “cache-size” is reached;
*) dns - fixed domain name lookup resolving for internal services;
*) ethernet - fixed issue with default interface names for CRS310-8G+2S+ in rare cases;
*) ethernet - improved cable-test reliability for hAP ax3 PoE out port;
*) ethernet - resolved minor memory leak while processing packets;
*) fetch - added “head” option for “http-method”;
*) fetch - added “patch” option for “http-method”;
*) fetch - allow specifying link-local address in FTP mode;
*) fetch - allow to use certificate and check-certificate parameters only in HTTPS mode;
*) fetch - do not require “content-length” for HTTP (introduced in v7.13);
*) fetch - fixed DNS resolving when domain has only AAAA entries (introduced in v7.13);
*) fetch - fixed fetch execution when unexpected data is received in HTTP payload;
*) fetch - fixed fetch when using “src-path” with HTTP/HTTPS modes (introduced in v7.13);
*) fetch - fixed fetch when using “src-path” with SFTP mode (introduced in v7.13);
*) fetch - fixed incorrect “src-path” error message when “upload=yes”;
*) fetch - fixed IPv4 address logging (introduced in v7.13);
*) fetch - improved fetch stability in SFTP mode;
*) fetch - improved file download stability with HTTP/HTTPS modes;
*) fetch - less verbose logging;
*) fetch - print all “Set-Cookies” headers in response;
*) fetch - treat any 2xx HTTP return code as success (introduced in v7.13);
*) filesystem - improved filesystem integrity for several RB3011 units with automatic firmware upgrade;
*) firewall - added “creation-time” parameter for IPv6 address list entries;
*) firewall - fixed underlying CAPsMAN tunnel reusing packet marks of encapsulated packets;
*) firewall - fixed underlying VXLAN/EoIP tunnel reusing packet marks of encapsulated packets;
*) firewall - increased default “udp-timeout” value from 10s to 30s;
*) health - added limited manual control over fans for CCR1016r2, CCR1036r2 devices;
*) health - changed default “fan-min-speed-percent” from 0% to 12%;
*) health - improved fan control on CRS3xx and CCR1016-12S-1S+r2;
*) health - show voltage when powering KNOT R through Micro-USB;
*) health - updated health properties for CCR1016r2, CCR1036r2 devices;
*) iot - added bluetooth whitelist wildcard asterisk support;
*) iot - added LoRa CUPs protocol support;
*) iot - fixed modbus partial frame reception issue;
*) iot - improved LoRa LNS;
*) iot - improved modbus Tx/Rx switching behaviour;
*) iot - improvements to GPIO behavior on boot;
*) iot - improvements to LoRa CUPS;
*) iot - removed bluetooth whitelist maximum entry limit of 8;
*) ipv6 - made “valid” and “lifetime” parameters dynamic for SLAAC IPv6 addresses;
*) isis - show passive interface active levels;
*) l3hw - fixed IPv6 host offloading in certain cases;
*) l3hw - fixed neighbor offloading after link flap;
*) l3hw - preserve offloading for VLANs when bridge ports are down;
*) leds - added “dark-mode” functionality for hAP ax3 and Chateau ax series devices;
*) leds - do not show LTE connection state/mode using RGB power LED from configless LTE modems;
*) leds - fixed “type=on” LED behaviour after reboot;
*) leds - fixed default LTE LED configuration for wAPR-2nD;
*) leds - fixed modem LED indication for SXT LTE 3-7;
*) leds - fixed wireless type of LED triggers for routers using WiFi package;
*) lte - added “at-chat” support for Sierra Wireless EM9293 5G modem;
*) lte - added AT channel support for Quectel EM120K-GL modem;
*) lte - added redial timer when the MBIM modem fails to register or does not receive APN activation notification;
*) lte - don’t duplicate primary band in 5G SA mode for chateau 5G;
*) lte - fixed “use-peer-dns” setting for EC200A modem;
*) lte - fixed an issue for EC200A modem that IPv6 address could be added as IPv4 address;
*) lte - fixed APN authentication for FG621-EA modem;
*) lte - fixed MBIM interface enabling for Quectel EC25 modem (introduced in v7.13);
*) lte - fixed Simcom modem support in 0x9000; 0x9002, 0x9002; 0x901a and 0x901b USB compositions;
*) lte - fixed Simcom modem support in 0x9001 USB composition;
*) lte - fixed support for config-less modem detection (introduced in v7.13);
*) lte - fixed USB mode switch and initialization race condition for configless USB modems;
*) lte - improved FG621-EA modem firmware upgrade;
*) lte - improved modem recovery after failed IPv4 configuration;
*) lte - improved support for “ACER” and “MSFT” branded EM12-G modems;
*) lte - optimized “at-chat” response reading;
*) lte - refactored AT command control for AT modems;
*) modem - fixed SMS removal (introduced in v7.13);
*) modem - improved stability when performing modem FOTA upgrade;
*) mpls - fixed VPN fragmentation when forwarding IP traffic;
*) netinstall-cli - check package and device architecture before formatting;
*) ovpn - added support for pushing routes;
*) ovpn - improved “push-routes” option handling when large amount of routes is specified;
*) ovpn - improved key-renegotiation process;
*) ovpn - improved OVPN configuration file import process;
*) ovpn - improved system stability when using HW encryption on ARM64 devices (introduced in v7.13);
*) ovpn - limit the maximum length for “push-routes” up to 1400 characters;
*) package - added “size” property;
*) package - reduced “wireless” package size for ARM, ARM64, MIPSBE, MMIPS devices;
*) package - reduced package size for SMIPS;
*) poe-out - driver optimization for AF/AT controlled boards;
*) poe-out - fixed “power-cycle” for CRS354-48P-4S+2Q+ device (introduced in v7.13);
*) poe-out - improved 802.3at classification and measurement accuracy;
*) poe-out - improved cable test for hAP ac3 and hAP ax3 devices;
*) poe-out - improved PoE out reliability on routers with a single PoE out interface;
*) port - fixed support for USB/serial adapters (introduced in v7.13);
*) port - removed bogus serial port on RB750Gr3, RB760iGS and RBM11G devices;
*) ppp - added support for “WISPr-Session-Terminate-Time” RADIUS attribute;
*) ppp - log an error when IPv6 DHCP pool is exhausted;
*) ptp - added “aes67” and “smpte” profiles;
*) ptp - added configurable “domain” and “priority2” parameters;
*) ptp - added support for Management message forwarding in BC;
*) ptp - fixed “default” and “g8275.1” profiles go into “slave” instead of “uncalibrated” state;
*) ptp - fixed default values for “802.1as” profile;
*) ptp - fixed flags in Announce message;
*) ptp - fixed potential error in packet exchange;
*) ptp - make clock go into grandmaster state if slave port goes down;
*) qos-hw - fixed “tx-queue7-packet” counter;
*) route - fixed gateways of locally imported vpnv4 routes;
*) route - improved route print “count-only” process speed;
*) route - improved stability on route table lookup;
*) route-filter - added option to set “isis-ext-metric”;
*) route-filter - fixed AS path matchers when input and output chains are used;
*) routerboard - added “reset-button” support for RBwAPR-2nD device;
*) sfp - added support for modules requiring single byte I2C read transactions;
*) sfp - fixed corrupted Tx traffic at 10Gbps rate on CCR2004-16G-2S+ in rare cases;
*) sfp - fixed corrupted Tx traffic at 10Gbps rate on RB4011 in rare cases;
*) sfp - improve high-power SFP module initialization;
*) sfp - improved combo-sfp handling for CRS328-4C-20S-4S+;
*) sfp - improved link establishment for RB4011 devices;
*) smb - added option to specify SMB service mode as “auto”;
*) sms - fixed SMS inbox for FG621-EA modem (introduced in v7.13);
*) sms - fixed SMS sending from WinBox and WebFig (introduced in v7.13);
*) sms - improved system stability when working with SMS;
*) sms - increased SMS read timeout;
*) snmp - added “bgpLocalAs” and “bgpIdentifier” OID reporting;
*) snmp - fixed “bgpPeerFsmEstablishedTime” OID reporting;
*) snmp - hide “MikroTik” in LLDP MIB when branding with hide SNMP option is used;
*) snmp - updated timeout log;
*) ssh - improved SSH performance on ARM, MIPS, MMIPS, SMIPS and TILE devices;
*) ssh - refactored SSH service internal processes;
*) sstp - added support for “aes256-gcm-sha384” encryption;
*) sstp - improved system stability for PPC devices;
*) supout - added PTP section;
*) switch - fixed Ethernet disable/enable for CRS310-8G+2S+ devices;
*) switch - fixed reserved multicast receive on Atheros-8327, QCA8337 switches for R/STP bridge;
*) switch - improved 100G interface stability for 98DX4310 and 98DX8525 switches;
*) switch - minimise potential packet overflows on CRS354;
*) system - changed build time format according to ISO standard;
*) system - expose “lo” and “vrf” interfaces;
*) system - fixed “cpu-frequency” for CRS3xx ARM devices;
*) system - improved memory allocation for ARM64 devices;
*) system - improved RAM allocation for L009UiGS-RM;
*) system - improved system stability when processing packets in FastPath (introduced in v7.13);
*) system - properly assign destination port for HTTP/S connections initiated by the router (introduced in v7.13);
*) system - properly close HTTP/S connections initiated by the router;
*) system - provide more precise “total-memory” value for ARM devices;
*) system - provide more precise “total-memory” value under “System/Resources” menu for L009 and hAP ax lite routers;
*) tftp - improved invalid request processing;
*) timezone - updated timezone information from “tzdata2023d” release;
*) tr069 - don’t duplicate cellular info in “X_MIKROTIK_5G” nodes when connected in NR SA mode;
*) tr069 - fixed bandwidth test;
*) tr069-client - show 5G signal info in X_MIKROTIK_5G nodes only for 5G NSA bands;
*) traffic-flow - use 64bit counters for v9 and IPFIX flows;
*) traffic-generator - improved system stability when receiving bogus traffic;
*) usb - show “Supermicro CDC” adapter as Ethernet interface;
*) vlan - fixed non-running VLAN interface after failed MTU change;
*) vrf - prevent VRF interface name collision with interface lists;
*) vxlan - fixed underlying tunnel reusing routing marks of encapsulated packets;
*) webfig - fixed routing table filter under “IP/Routes” menu;
*) webfig - fixed setting the user’s password;
*) webfig - fixed showing WireGuard peers;
*) webfig - improved stability when adding new entries under “IP/Routes” menu;
*) wifi - added “station-pseudobridge” interface mode;
*) wifi - fixed issue with setting country profile (introduced in v7.13.1);
*) wifi - improved handling of CAP connections in dual CAPsMAN scenario;
*) wifi - increased value for SAE retransmit period to 3s to improve WPA3 compatibility with IoT client devices;
*) wifi - use “Latvia” as the default value for “country” property;
*) wifi - use correct CAP identity for interface name provisioning after it has been changed by remote-cap/set-identity;
*) wifi-qcom - enable display of regulatory information on L11,L22 devices;
*) wifi-qcom - fixed new connections, when maximum supported number of MAC addresses behind connected station-bridges is reached;
*) wifi-qcom - improve system stability for L11, L22 devices;
*) wifi-qcom - improved memory allocating process;
*) wifi-qcom - improved regulatory compliance for L11, L22 devices;
*) wifi-qcom - improved system stability when using FastPath (introduced in v7.13);
*) winbox - added “accept-protocol-version” parameter to the L2TP server settings;
*) winbox - added “mode-button” and “switch” menus for L41G-2axD&FG621-EA;
*) winbox - added “Name” parameter under “Tools/Netwatch” menu;
*) winbox - added “page-refresh” setting to the Graphing settings;
*) winbox - added “Port Cost Mode” setting under “Bridge” menu;
*) winbox - added “VRF” parameter under “Tools/Ping” menu;
*) winbox - added “x25519” argument for “DH Group” parameter under “IP/IPsec/Profiles” menu;
*) winbox - added missing “Protocol” arguments under “IPv6/Firewall” menu;
*) winbox - added missing monitoring properties under “WireGuard/Peers” menu;
*) winbox - added Preboot Etherboot settings to the System/RouterBOARD/Settings menu;
*) winbox - do not show USB settings for CRS devices that does not need it;
*) winbox - fixed “Bridge Cost” range under “Interfaces/VPLS” menu;
*) winbox - fixed “Password” button under “Quick Set” menu;
*) winbox - improved connection speed and reliability;
*) winbox - improved route table automatic refresh process for static routes;
*) winbox - improved status values under “System/PTP” menu;
*) winbox - improved system stability with large packets;
*) winbox - include “te-tunnel” parameter in VPLS interface monitor;
*) winbox - properly validate “passthrough-subnet-size” in the LTE APN settings;
*) winbox - remove “Root Bridge ID” property under “Bridge/MSTIs” menu;
*) winbox - removed “sfp all” option from combo port settings;
*) winbox - renamed “Wireless Table” menu to “Wifi”;
*) winbox - show “routing-table” column under IP/Route menu by default;
*) winbox - show all columns under “Routing/PIM SM/Static RP” menu by default;
*) wireguard - do not allow to use multiple WireGuard interfaces on the same “listen-port”;
*) wireguard - optimised and improved WireGuard service logging;
*) x86 - fixed VLAN tagged packet transmit for igb (introduced in v7.12);
To upgrade, click “Check for updates” at /system package in your RouterOS configuration interface, or head to our download page: http://www.mikrotik.com/download
If you experience version related issues, then please send supout file from your router to support@mikrotik.com. File must be generated while a router is not working as suspected or after some problem has appeared on the device
Huge changelog, congratulations for the excellent work :clap:
awesome, thx for your hard work
Yahoooo, thank you
Remember this:
**Notice - Starting from RouterOS version 7.13, significant changes have been made to the RouterOS wireless packages. This is done due to a new product development which will require more disk space for hardware drivers so we had to split it in order to maintain old products alongside the new ones. More wireless packages are yet to come.
  1. When upgrading by using “check-for-updates”, all versions earlier than 7.12 will display 7.12 as the latest available version. Upgrade from v7.12 to v7.13 or later versions must be done through 7.12 in order to convert wireless packages automatically. Fresh installation with Netinstall or manual package installation works in the same manner as always.
  2. Drivers for older wireless and 60GHz interfaces, as well as the wireless management system CAPsMAN, are now part of a separate “wireless” package instead of being a part of the bundle package. This package can be uninstalled if not needed.
  3. The existing “wifiwave2” package has been divided into distinct packages: “wifi-qcom” and “wifi-qcom-ac”, and the necessary utilities for WiFi management are now included in the RouterOS bundle. RouterOS and “wifi-qcom-ac” packages alongside each other now fit into 16MB flash memory.**
Also note that upgrading beyond 7.12.1 can cause issues on ARM devices with “16MB flash”, especially for devices that actually have only 15.3MB flash.
So be extra careful when upgrading such a device (e.g. hAP ac2), especially when you cannot easily netinstall it (remote location).
I have the following wireguard bth info in the log on a hap ax lite LTE 6 and an RB 5009. With version 7.13
was everything OK. A new configuration of Wiregurad BTH does not bring any changes.
What causes this message regarding a backup-routerboot upgrade?
edit: Device is RB960PGS (hEX PoE) r2.
I’m getting endless messages ‘Handshake for peer did not complete after 5 seconds, retrying (try 2)’ in log.
Note: I spotted several lines in the changelog that where already in 7.13.x releases. So changelog looks longer than it actually is.
I still cannot ugrade hAP Lite from 7.13 to 7.14 (7.6MiB required, 7.5MiB free, although it’s only few kilobytes that are actually missing).
Manual upgrade also won’t pass, missing those few kb to upload wireless package.
Look out when upgrading a CCR2004-1G-2XS-PCIe.
I’ve got one here that is gone into a reboot loop, even after powering down and up again.
It can be bad luck, but I’m not going to upgrade the rest of them until I know how to get it running again.
Update:
I got the board working again after resetting it to defaults with the reset solder pads.
Somewhat unbelievably… while 7.13.5 took 14,4 MB of space in hap ac2 - 7.14 has seem to got smaller as used space indicates now 14,3 MB (that with legacy wireless package).
Upgrade took almost 3 minutes which is longest for that device so far…
Old wireless package got smaller but how it is with wifi-qcom-ac? Anyone knows if it is possible to upgrade to 7.14 and how much flash space will be left free afterwards?
All ethernet interfaces on the CHR machine on the VDSINA hosting are missing. I checked the installation process twice, the ethernet is always lost. I installed 7.13.5, the ethernet is back.
What device this is?
Since 7.14 there is a lot more verbose logging w.r.t. Wireguard in general, not only BTH.
It’s in the change log.
But if you ask me, there should also be an ‘off’ switch for this logging … haven’t found it yet.
Upgrade done!
I hope it will be better than 7.13… it was a nightmare…
7.13.2 and 7.13.4 has broken file save on NAS. I don’t know how and why but I observed that in two different locations.
So far upgraded successfully (home and lab gear):
RB5009
AX2
AX3
AX Lite LTE
Map
Minor comment:
log file on AX Lite LTE shows something weird:
19:36:54 script,warning USB device count: 2 >> 3 .id=*1;device=1-0;name=xHCI Host Controller;speed=480;vendor=Linux 5.6.3 xhci-hcd;.id=*2;device=2-0;name=xHCI Host Controller;speed=5000;vendor=
Linux 5.6.3 xhci-hcd;.id=*3;device=1-1;name=FG621 Module;speed=480;vendor=Fibocom
19:37:16 script,warning LTE inteface count: 0 >> 1
But everything works.
In Logging, select info, then add wireguard to it, then add the negative sign to wireguard.
Can you elaborate please ? I don’t seem to get it right.
BTW same with DNS and NTP logging. It’s being SWAMPED now with messages.
