v7.14rc [testing] is released!
RouterOS version 7.14rc has been released on the “v7 testing” channel!
Before an upgrade:
  2. Make sure the device will not lose power during the upgrade process;
  3. Device has enough free storage space to download all RouterOS packages.
What’s new in 7.14rc4 (2024-Feb-28 13:38):
*) route - use correct routing table for addresses on VRF interface (introduced in v7.14beta3);
*) smb - fixed export with default configuration (introduced in v7.14beta7);
What’s new in 7.14rc3 (2024-Feb-27 10:06):
*) lte - improved FG621-EA modem firmware upgrade;
*) ovpn - limit the maximum length for “push-routes” up to 1400 characters;
*) sstp - added support for “aes256-gcm-sha384” encryption;
What’s new in 7.14rc2 (2024-Feb-20 12:35):
!) rose-storage - moved SMB service to the RouterOS bundle;
!) smb - removed legacy SMB service (replaced with newer and faster ROSE SMB service, compatible with SMB 2.1, SMB 3.0 and SMB 3.1.1);
*) bridge - fixed MLAG connection after peer-link flap (introduced in v7.13);
*) bridge - fixed MLAG connection issues due to STP (introduced in v7.14beta3);
*) bridge - fixed packet forwarding after changing HW offloaded bridge interface settings in certain cases (introduced in v7.13);
*) bridge - fixed port mst-override status (introduced in v7.14beta3);
*) defconf - improved wifi interface detection after upgrade;
*) lte - added redial timer when the MBIM modem fails to register or does not receive APN activation notification;
*) ovpn - improved “push-routes” option handling when large amount of routes is specified;
*) sms - increased SMS read timeout;
What’s new in 7.14rc1 (2024-Feb-09 12:32):
*) disk - added global disk “settings” menu;
*) disk - fixed changing settings on some GPT formatted disks;
*) dns - do not close connection with DoH server after query execution (introduced in 7.14beta8);
*) ethernet - fixed issue with default interface names for CRS310-8G+2S+ in rare cases;
*) fetch - added “patch” option for “http-method”;
*) fetch - fixed fetch execution when unexpected data is received in HTTP payload;
*) isis - show passive interface active levels;
*) modem - fixed modem firmware-upgrade (introduced in v7.14beta9);
*) sstp - improved system stability for PPC devices;
*) system - expose “lo” and “vrf” interfaces;
*) webfig - fixed showing WireGuard peers;
*) wifi-qcom - improved memory allocating process;
Other changes since v7.13:
*) 6to4 - make “ipsec-secret” sensitive parameter;
*) api - improved REST API stability when processing invalid requests;
*) api - properly return SNMP OIDs when requested;
*) arm - improved system stability when using microSD on RB1100Dx4;
*) arp - added ARP status;
*) bgp - allow to leak routes between local VRFs;
*) bridge - added MLAG support for MSTP bridges;
*) bridge - avoid per-VLAN host flushing on HW offloaded bridge;
*) bridge - fixed auto “path-cost” for bonding interfaces (introduced in v7.13);
*) bridge - fixed host flush on BPDU-guard port disable (introduced in v7.14beta3);
*) bridge - improved bridge VLAN configuration validation;
*) bridge - improved configuration speed on large VLAN setups;
*) bridge - improved protocol-mode MSTP functionality;
*) bridge - improved protocol-mode STP and RSTP functionality;
*) bridge - make “point-to-point=yes” default value for non-wireless bridge ports;
*) bridge - removed “mst-config-digest” from MSTI menu;
*) bridge - try to set wireless bridge ports as edge ports automatically;
*) bth - added simple “Back To Home Users” manager under IP/Cloud menu;
*) calea - improved system stability when adding bridge rule without “calea” package installed;
*) certificate - improved certificate validation performance;
*) console - added “:tolf” and “:tocrlf” commands for converting line break to/from LF or CRLF;
*) console - added “show-at-cli-login” option to display a note before telnet login;
*) console - added missing “where” clause for “/ipv6/firewall/filter” table print command;
*) console - do not accept negative or too large values for “:delay” command;
*) console - do not allow to use out-of-range values for time type fields;
*) console - fix configuration export when user does not have a “sniff” policy;
*) console - fixed delayed output from “:grep” command in certain cases;
*) console - fixed incorrect behavior of “:onerror” command in certain cases;
*) console - hint on reset command help that “.rsc file” is required for “run-after-reset” parameter;
*) console - improved editor functionality in full screen mode;
*) console - improved stability when using autocomplete with “export”;
*) console - increased maximum file content length that can be managed through command line to 60 KB;
*) console - updated copyright notice;
*) container - improved VETH interface management responsiveness and reliability;
*) container - restrict “/container/shell” menu for users without “write” permissions;
*) defconf - added log about configuration reset due to pressed reset button;
*) defconf - do not add loopback interface to the bridge ports (introduced in v7.14beta3);
*) defconf - fixed Audience scanning-for-wps-ap timeout;
*) defconf - fixed configuration script on KNOT devices if “ppp-out” interface is removed;
*) defconf - fixed firewall rule for IPv6 UDP traceroute;
*) defconf - fixed wifi configuration if interface MAC address is changed;
*) defconf - increased LTE interface wait time;
*) defconf - updated health settings on configuration revert;
*) defconf - use “fq_codel” queue as default interface queue for wired ports on LTE devices;
*) dhcpv6-client - install dynamic IPv6 blackhole routes in corresponding routing-table;
*) dhcpv6-client - updated error logging when multiple prefixes received on renew;
*) disk - added exFAT and NTFS mount/read/write support;
*) disk - properly unmount disk when it is disconnected;
*) dns - do not add new entries to cache if “cache-size” is reached;
*) dns - fixed DNS service crash when DoH used (introduced in v7.14beta4);
*) dns - fixed domain name lookup resolving for internal services;
*) ethernet - improved cable-test reliability for hAP ax3 PoE out port;
*) ethernet - resolved minor memory leak while processing packets;
*) fetch - added “head” option for “http-method”;
*) fetch - allow specifying link-local address in FTP mode;
*) fetch - allow to use certificate and check-certificate parameters only in HTTPS mode;
*) fetch - do not require “content-length” for HTTP (introduced in v7.13);
*) fetch - fixed DNS resolving when domain has only AAAA entries (introduced in v7.13);
*) fetch - fixed fetch when using “src-path” with HTTP/HTTPS modes (introduced in v7.13);
*) fetch - fixed fetch when using “src-path” with SFTP mode (introduced in v7.13);
*) fetch - fixed incorrect “src-path” error message when “upload=yes”;
*) fetch - fixed IPv4 address logging (introduced in v7.13);
*) fetch - fixed timeout when content-length is 0 (introduced in v7.14beta4);
*) fetch - improved fetch stability in SFTP mode;
*) fetch - improved file download stability with HTTP/HTTPS modes;
*) fetch - less verbose logging;
*) fetch - print all “Set-Cookies” headers in response;
*) fetch - treat any 2xx HTTP return code as success (introduced in v7.13);
*) filesystem - improved filesystem integrity for several RB3011 units with automatic firmware upgrade;
*) firewall - added “creation-time” parameter for IPv6 address list entries;
*) firewall - fixed underlying CAPsMAN tunnel reusing packet marks of encapsulated packets;
*) firewall - fixed underlying VXLAN/EoIP tunnel reusing packet marks of encapsulated packets;
*) firewall - increased default “udp-timeout” value from 10s to 30s;
*) health - added limited manual control over fans for CCR1016r2, CCR1036r2 devices;
*) health - changed default “fan-min-speed-percent” from 0% to 12%;
*) health - improved fan control on CRS3xx and CCR1016-12S-1S+r2;
*) health - show voltage when powering KNOT R through Micro-USB;
*) health - updated health properties for CCR1016r2, CCR1036r2 devices;
*) iot - added bluetooth whitelist wildcard asterisk support;
*) iot - added LoRa CUPs protocol support;
*) iot - fixed modbus partial frame reception issue;
*) iot - improved LoRa LNS;
*) iot - improved modbus Tx/Rx switching behaviour;
*) iot - improvements to GPIO behavior on boot;
*) iot - improvements to LoRa CUPS;
*) iot - removed bluetooth whitelist maximum entry limit of 8;
*) ipv6 - made “valid” and “lifetime” parameters dynamic for SLAAC IPv6 addresses;
*) l3hw - fixed IPv6 host offloading in certain cases;
*) l3hw - fixed neighbor offloading after link flap;
*) l3hw - preserve offloading for VLANs when bridge ports are down;
*) leds - added “dark-mode” functionality for hAP ax3 and Chateau ax series devices;
*) leds - do not show LTE connection state/mode using RGB power LED from configless LTE modems;
*) leds - fixed “type=on” LED behaviour after reboot;
*) leds - fixed default LTE LED configuration for wAPR-2nD;
*) leds - fixed modem LED indication for SXT LTE 3-7;
*) leds - fixed modem signal strength for RBSXTR&R11e-LTE (introduced in v7.14beta6);
*) leds - fixed wireless type of LED triggers for routers using WiFi package;
*) lte - added “at-chat” support for Sierra Wireless EM9293 5G modem;
*) lte - added AT channel support for Quectel EM120K-GL modem;
*) lte - don’t duplicate primary band in 5G SA mode for chateau 5G;
*) lte - fixed “use-peer-dns” setting for EC200A modem;
*) lte - fixed an issue for EC200A modem that IPv6 address could be added as IPv4 address;
*) lte - fixed APN authentication for FG621-EA modem;
*) lte - fixed MBIM interface enabling for Quectel EC25 modem (introduced in v7.13);
*) lte - fixed Simcom modem support in 0x9000; 0x9002, 0x9002; 0x901a and 0x901b USB compositions;
*) lte - fixed Simcom modem support in 0x9001 USB composition;
*) lte - fixed support for config-less modem detection (introduced in v7.13);
*) lte - fixed USB mode switch and initialization race condition for configless USB modems;
*) lte - improved modem recovery after failed IPv4 configuration;
*) lte - improved support for “ACER” and “MSFT” branded EM12-G modems;
*) lte - optimized “at-chat” response reading;
*) lte - refactored AT command control for AT modems;
*) modem - fixed SMS removal (introduced in v7.13);
*) modem - improved stability when performing modem FOTA upgrade;
*) mpls - fixed VPN fragmentation when forwarding IP traffic;
*) netinstall-cli - check package and device architecture before formatting;
*) ovpn - added support for pushing routes;
*) ovpn - improved key-renegotiation process;
*) ovpn - improved OVPN configuration file import process;
*) ovpn - improved system stability when using HW encryption on ARM64 devices (introduced in v7.13);
*) package - added “size” property;
*) package - reduced “wireless” package size for ARM, ARM64, MIPSBE, MMIPS devices;
*) package - reduced package size for SMIPS;
*) poe-out - driver optimization for AF/AT controlled boards;
*) poe-out - fixed “power-cycle” for CRS354-48P-4S+2Q+ device (introduced in v7.13);
*) poe-out - improved 802.3at classification and measurement accuracy;
*) poe-out - improved cable test for hAP ac3 and hAP ax3 devices;
*) poe-out - improved PoE out reliability on routers with a single PoE out interface;
*) port - fixed support for USB/serial adapters (introduced in v7.13);
*) port - removed bogus serial port on RB750Gr3, RB760iGS and RBM11G devices;
*) ppp - added support for “WISPr-Session-Terminate-Time” RADIUS attribute;
*) ppp - log an error when IPv6 DHCP pool is exhausted;
*) ptp - added “aes67” and “smpte” profiles;
*) ptp - added configurable “domain” and “priority2” parameters;
*) ptp - added support for Management message forwarding in BC;
*) ptp - fixed “default” and “g8275.1” profiles go into “slave” instead of “uncalibrated” state;
*) ptp - fixed default values for “802.1as” profile;
*) ptp - fixed flags in Announce message;
*) ptp - fixed potential error in packet exchange;
*) ptp - make clock go into grandmaster state if slave port goes down;
*) qos-hw - fixed “tx-queue7-packet” counter;
*) route - fixed gateways of locally imported vpnv4 routes;
*) route - fixed route lockup when loading large amount of routes on ARM64 (introduced in v7.14beta4);
*) route - improved route print “count-only” process speed;
*) route - improved stability on route table lookup;
*) route-filter - added option to set “isis-ext-metric”;
*) route-filter - fixed AS path matchers when input and output chains are used;
*) routerboard - added “reset-button” support for RBwAPR-2nD device;
*) sfp - added support for modules requiring single byte I2C read transactions;
*) sfp - fixed corrupted Tx traffic at 10Gbps rate on CCR2004-16G-2S+ in rare cases;
*) sfp - fixed corrupted Tx traffic at 10Gbps rate on RB4011 in rare cases;
*) sfp - improve high-power SFP module initialization;
*) sfp - improved combo-sfp handling for CRS328-4C-20S-4S+;
*) sfp - improved link establishment for RB4011 devices;
*) smb - added option to specify SMB service mode as “auto”;
*) smips - improved system stability (introduced in v7.14beta4);
*) sms - fixed SMS inbox for FG621-EA modem (introduced in v7.13);
*) sms - fixed SMS sending from WinBox and WebFig (introduced in v7.13);
*) sms - improved system stability when working with SMS;
*) snmp - added “bgpLocalAs” and “bgpIdentifier” OID reporting;
*) snmp - fixed “bgpPeerFsmEstablishedTime” OID reporting;
*) snmp - hide “MikroTik” in LLDP MIB when branding with hide SNMP option is used;
*) snmp - updated timeout log;
*) ssh - improved SSH performance on ARM, MIPS, MMIPS, SMIPS and TILE devices;
*) ssh - refactored SSH service internal processes;
*) supout - added PTP section;
*) switch - fixed “cpu-flow-control” for RB3011 (introduced in v7.14beta3);
*) switch - fixed “vlan-mode” and “default-vlan-id” property reset after reboot (introduced in v7.14beta3);
*) switch - fixed Atheros switch port configuration export (introduced in v7.14beta3);
*) switch - fixed Atheros-8327 switch rules (introduced in v7.14beta3);
*) switch - fixed Ethernet disable/enable for CRS310-8G+2S+ devices;
*) switch - fixed reserved multicast receive on Atheros-8327, QCA8337 switches for R/STP bridge;
*) switch - improved 100G interface stability for 98DX4310 and 98DX8525 switches;
*) switch - minimise potential packet overflows on CRS354;
*) system - changed build time format according to ISO standard;
*) system - correctly handle HTTP 1xx and 204 response status codes (introduced in v7.14beta6);
*) system - fixed “cpu-frequency” for CRS3xx ARM devices;
*) system - improved memory allocation for ARM64 devices;
*) system - improved RAM allocation for L009UiGS-RM;
*) system - improved system stability when processing packets in FastPath (introduced in v7.13);
*) system - properly assign destination port for HTTP/S connections initiated by the router (introduced in v7.13);
*) system - properly close HTTP/S connections initiated by the router;
*) system - properly start HTTP/S connections initiated by the router if non-default port is used (introduced in v7.14beta3);
*) system - provide more precise “total-memory” value for ARM devices;
*) system - provide more precise “total-memory” value under “System/Resources” menu for L009 and hAP ax lite routers;
*) tftp - improved invalid request processing;
*) timezone - updated timezone information from “tzdata2023d” release;
*) tr069 - don’t duplicate cellular info in “X_MIKROTIK_5G” nodes when connected in NR SA mode;
*) tr069 - fixed bandwidth test;
*) tr069-client - show 5G signal info in X_MIKROTIK_5G nodes only for 5G NSA bands;
*) traffic-flow - use 64bit counters for v9 and IPFIX flows;
*) traffic-generator - improved system stability when receiving bogus traffic;
*) usb - show “Supermicro CDC” adapter as Ethernet interface;
*) vlan - fixed non-running VLAN interface after failed MTU change;
*) vrf - prevent VRF interface name collision with interface lists;
*) vxlan - fixed underlying tunnel reusing routing marks of encapsulated packets;
*) webfig - fixed routing table filter under “IP/Routes” menu;
*) webfig - fixed setting the user’s password;
*) webfig - improved stability when adding new entries under “IP/Routes” menu;
*) wifi - added “station-pseudobridge” interface mode;
*) wifi - fixed issue with setting country profile (introduced in v7.13.1);
*) wifi - improved handling of CAP connections in dual CAPsMAN scenario;
*) wifi - increased value for SAE retransmit period to 3s to improve WPA3 compatibility with IoT client devices;
*) wifi - use “Latvia” as default value for “country” property;
*) wifi - use correct CAP identity for interface name provisioning after it has been changed by remote-cap/set-identity;
*) wifi-qcom - enable display of regulatory information on L11,L22 devices;
*) wifi-qcom - fixed new connections, when maximum supported number of MAC addresses behind connected station-bridges is reached;
*) wifi-qcom - improve system stability for L11, L22 devices;
*) wifi-qcom - improved system stability when using FastPath (introduced in v7.13);
*) winbox - added “accept-protocol-version” parameter to the L2TP server settings;
*) winbox - added “mode-button” and “switch” menus for L41G-2axD&FG621-EA;
*) winbox - added “Name” parameter under “Tools/Netwatch” menu;
*) winbox - added “page-refresh” setting to the Graphing settings;
*) winbox - added “Port Cost Mode” setting under “Bridge” menu;
*) winbox - added “VRF” parameter under “Tools/Ping” menu;
*) winbox - added “x25519” argument for “DH Group” parameter under “IP/IPsec/Profiles” menu;
*) winbox - added missing “Protocol” arguments under “IPv6/Firewall” menu;
*) winbox - added missing monitoring properties under “WireGuard/Peers” menu;
*) winbox - aded Preboot Etherboot settings to the System/RouterBOARD/Settings menu;
*) winbox - do not show USB settings for CRS devices that does not need it;
*) winbox - fixed “Bridge Cost” range under “Interfaces/VPLS” menu;
*) winbox - fixed “Password” button under “Quick Set” menu;
*) winbox - fixed status under “Bridge/Ports” menu (introduced in v7.14beta3);
*) winbox - improved connection speed and reliability;
*) winbox - improved route table automatic refresh process for static routes;
*) winbox - improved status values under “System/PTP” menu;
*) winbox - improved system stability with large packets;
*) winbox - include “te-tunnel” parameter in VPLS interface monitor;
*) winbox - properly validate “passthrough-subnet-size” in the LTE APN settings;
*) winbox - remove “Root Bridge ID” property under “Bridge/MSTIs” menu;
*) winbox - removed “sfp all” option from combo port settings;
*) winbox - renamed “Wireless Table” menu to “Wifi”;
*) winbox - show “routing-table” column under IP/Route menu by default;
*) winbox - show all columns under “Routing/PIM SM/Static RP” menu by default;
*) wireguard - do not allow to use multiple WireGuard interfaces on the same “listen-port”;
*) wireguard - optimised and improved WireGuard service logging;
*) x86 - fixed VLAN tagged packet transmit for igb (introduced in v7.12);
To upgrade, click “Check for updates” at /system package in your RouterOS configuration interface, or head to our download page: http://www.mikrotik.com/download
If you experience version related issues, please send a supout file from your router to support@mikrotik.com. File must be generated while a router is not working as suspected or after some problem has appeared on the device
No solution for the memory shortage in 15.3MB ARM devices?
What do you mean? I can not install this RC on ARM with 16 MB?
cAP XL ac and wAP ac upgraded (from 7.13.4) without problems (besides my RB4011).
Only had to suppress Wireguard logging.
It still doesn’t work for me…
Windows clients see the share but cannot access it.
It works fine for me.
Thanks to your help I found the cause!
Doesn’t work when the share name is uppercase:
Test - KO
test - OK
Reported with SUP-143577
Is this update only for wifi-qcom or also for wifi-qcom-ac?
Also not working for me. Tried with Windows PC and Android. Not uppercase/lowercase issue for me. Share can be seen, but can’t access.
I presume wAP ac is an arm version not mipsbe...
Was the wifi-qcom-ac package used?
How much HDD space was left free on cAP XL ac and wAP ac after the upgrade?
kalaposl post your SMB export please
Yes
Yes
cAP XL ac: 372 KiB
wAP ac: 356 KiB
This according to /system/resources
The solution is simple! Reset the device without def.conf. , after that make upgrade, or make netinstall with new npk version. The occupied space after the procedure is 14.9MB.
Finally new setup based on old config, do not use old backup file.
Impressive list of changes, looking forward to 7.14 stable.
Yes, but for me a device with only 350kB free is not viable. Too much risk that it gets corrupted at some time again at an upgrade or when configuring something.
There really has to be more free space.
I have a device I use for some test and when upgrading between two of the 7.14beta versions I again lost 500kB, instead of gaining space.
I have lost the confidence in the future of 15.3MB ARM devices (hAP ac2, LHG5ac and maybe others).
Is the menu suppose to do something?
/disk settings print
  auto-smb-sharing: yes
     auto-smb-user: *****
I had only one share before… but checking the “auto share” box does not add other non-shared partitions, or do anything it seems. Docs don’t mention it either.
There is a bug in the selection of interfaces (Winbox), SMB only works with the first interface in the list.
kalaposl put the bridge as the first interface and try again…
Remove old credentials from windows also if they are the same and use \routerIP\shareforder URL format
Call for ed25519 private key.
After Update from 7.14beta10 to 7.14RC1 the throughput of my fileserver dropped down to only ~80-500KBit!!
Both servers are connected to a CRS326-24S+2Q+ (MIBSBE) to the both QSFP ports with 40GBit.
No errors are shown in the logs and also not in the connection of the QSFP modules. (which are in use since ~2 years with this switch)
After downgrade to 7.14beta10 everything went back to normal.
@MT: nothing in the changelog let assume that this behaviour could happen. Do you have an explanation?
Ullinator, we would need to see the full config in the RC1
