v7.14rc [testing] is released!
Are you sure that it isn’t actually a power supply issue?
Maybe try a different one…
I removed it after I saw comments explaining USB stick might’ve caused all the trouble, but the issue persisted. Solved it by downgrading to 7.13.5 AND(!) removing wireless, rose and container images.
Most definitely was not a power supply issue. I monitor the draw of the devices connected to my UPS.
I solved the problem by downgrading to 7.13.5 AND removing wireless, rose and container packages.
Ok i’ve found when the MTU reset occur : it is occurring simply after a router reboot.
In the meantime i’m going to use a start script to set it at 1700 after router reboot :
delay 15
/interface vlan set VLAN-WAN-DATA mtu=1600
delay 4
/interface vlan set VLAN-WAN-DATA mtu=1700
Strangely i need both lines and those long delays. I cannot set the MTU directly to 1700.
I’ll try to find the time to make a report. Let me know if you find the cause. Perhaps you’ll find it quite easily with this indication.
Why do you need to put the WAN interface under the bridge in the first place? You can create a VLAN interface directly on top of an SFP port.
I need to put the WAN SFP in the bridge because i need to bridge a VLAN from the provider in a LAN side VLAN (without routing here, direct bridging). There is no VLAN interface on the bridge for this WAN VLAN, it is just a VLAN L2 bridging from a WAN VLAN to a LAN VLAN that is located inside a trunk port (a bridge port too) that goes to a managed switch for LAN VLAN distribution.
Another point : putting the WAN interface in the main bridge is simpler and do allow to bridge some VLANs between WAN and LAN side with L2 hardware acceleration or even L3 acceleration for some high end Mirkotik routers.
This is the setup when you want to replace a provider triple play box by a router, but put back the box behind the router for TV and telephony services that are difficult to manage without the box. You need to bridge the triple play VLANs to the box.
I don’t think this is 100% correct. WAN is a network just like any other, there isn’t anything special about it except for understanding how NAT comes into play on either side of the imaginary boundary. When you look at it from an ipv6 perspective it becomes even clearer, there is no difference they are just two seperate networks and you may or may not want certain traffic going between the networks. With regards to the bridge, if you want to offload any traffic to the switch chip or make use of the l3hw capabilities while having things like VLAN, Bonding etc then you need to put everything into a single bridge (which includes the WAN port). Now we can say that not everything can be offloaded and in those cases there won’t be any performance benefit of putting it in the bridge. But it is incorrect to say that WAN ports should not be on the bridge. Basically my point is, yes there are some situations where you cannot offload the traffic so it doesn’t matter what approach you choose, but if you want to have a simple configuration then you can put everything on the bridge and it will work just as well.
I’ve only seen this weird bridge problem only on MikroTik to begin with.
See this thread for details:
http://forum.mikrotik.com/t/discussion-mikrotik-configuration-abstraction-complexity/173293/1
This has been discussed ad nauseam. In all of the current documentation regarding bridges and switch chips for recent software versions, MikroTik emphasizes the requirement for a single bridge with all VLANs in it in order for any of the device’s hardware offloading to work properly. Otherwise it’s punted to the CPU, or worse yet, causes unsupported/undefined behavior.
What you suggest works fine for older v6 versions, in v7 for routers without offload capabilities, such as the CCR1000 series, and may be best practices for other hardware vendors. But for L2/L3HW-offload to work properly/most efficiently in v7, especially on Marvell chips, there is to be but one bridge.
Yes, if not VLAN aware bridges would not have been implemented in a first place.
This is the tendency, if you watch at the RB5009 design, a high end Soho router, even here the SFP port (generally used for the WAN side) is part of the hardware chip for offloading. If you do not put the SFP inside the main bridge, then there is no L2 hardware offloading and the setup become more complex, you’ll eventually need another old-style bridge with VLAN interfaces inside it if you need to bridge some VLANs between WAN and LAN. This is not the recommended setup specially with RouterOS 7.
You’re preaching to the choir. I’m one of the users on this forum who pushes for SINGLE bridge config all the god-damn time.
If you like Mikrotik prices, but would like an even better price / performance ratio, then use your experience, advanced knowledge, speed and smartness to make some detailed reports to help to speed up the corrections. :slight_smile:
Could anyone help me with IS-IS in 7.14rc?
I’m doing some laboratory tests, but it seems to me that not all parameters are behaving as they should, metric, filter, have no effect on my tests.
Is the IS-IS incomplete?
Has this been fixed yet, seems still open on my system? seems no one commenting on it
in the routing protocol status page it says “Initial support” - see https://help.mikrotik.com/docs/display/ROS/Routing+Protocol+Overview
It’s now more than that, but probably still incomplete.
Is there a correction for LLDP-MED ? In the beta it was missing Ieee 802.3 - MAC/PHY Configuration/Status.
Without this option, LLDP-MED does not work, it is rejected by phones. The LLDP-MED standard (ansi-tia-1057) is asking for a mandatory MAC/PHY Configuration/Status TLV.
The consequence is that the phones Ethernet interfaces do not switch to the right tagged VLAN. It stays on untagged traffic.
9.2.2 IEEE 802.3 MAC/PHY Configuration/Status TLV
IEEE 802.1AB-2005 [1] Annex G.2, defines the MAC/PHY configuration/status TLV that identifies:
a) The duplex and bit-rate capability of the sending 802.3 LAN node;
b) The current duplex and bit-rate settings of the sending 802.3 LAN node;
c) Whether theses settings are the result of auto-negotiation during the initialization of the link, or
of manual set override actions.
All LLDP-MED Devices shall include this TLV in outgoing LLDP-MED LLDPDUs.
Here is a Mikrotik LLDPDU announcement (missing MAC/PHY TLV) :
Link Layer Discovery Protocol
Chassis Subtype = MAC address, Id: 70:fc:8f:xx:xx:xx
Port Subtype = Interface name, Id: Bridge-LANs/ether5
Time To Live = 120 sec
System Name = MikroTik
System Description = MikroTik RouterOS 7.14beta7 (development) 2024-01-15 09:37:08 RB5009UPr+S+
Management Address
0001 000. … … = TLV Type: Management Address (8)
… …0 0000 1100 = TLV Length: 12
Address String Length: 5
Address Subtype: IPv4 (1)
Management Address: 192.168.88.1
Interface Subtype: ifIndex (2)
Interface Number: 5
OID String Length: 0
Management Address
… …0 0001 1000 = TLV Length: 24
Address String Length: 17
Address Subtype: IPv6 (2)
Management Address: fe80::7a9a:18ff:xxxx:xxxx
Interface Number: 5
Capabilities
Telecommunications Industry Association TR-41 Committee - Media Capabilities
Telecommunications Industry Association TR-41 Committee - Network Policy
1111 111. … … = TLV Type: Organization Specific (127)
… …0 0000 1000 = TLV Length: 8
Organization Unique Code: 00:12:bb (Telecommunications In
Media Subtype: Network Policy (0x02)
Application Type: Voice (1)
0… … … … … … = Policy: Defined
.1.. … … … … … = Tagged: Yes
…1 1111 0100 000. … … = VLAN Id: 4000
… … … …0 00.. … = L2 Priority: 0
… … … … ..00 0000 = DSCP Priority: 0
End of LLDPDU
Here is an example of the missing TLV (from a Procurve switch announcement, packet capture) :
…1 1111 0100 000. … … = VLAN Id: 500
… … … …1 10.. … = L2 Priority: 6
… … … … ..10 1110 = DSCP Priority: 46
Injecting correct packets every 2 seconds solve the problem, for example :
/tool/traffic-generator/inject-pcap pcap-file=lldp-ros-lin-and-dscp-and-phy2.pcap interface=ether3 once
/tool/traffic-generator/inject-pcap pcap-file=lldp-ros-lin-and-dscp-and-phy2.pcap interface=ether4 once
/tool/traffic-generator/inject-pcap pcap-file=lldp-ros-lin-and-dscp-and-phy2.pcap interface=ether5 once
As usual, there’s new configuration flotsam in this release. Removal methods for the ones affecting this release begin here, but I’m stuck on one:
/interface sstp-server server set ciphers=aes256-sha
That can take only one other value, but setting it to aes256-gcm-sha384 doesn’t make the line go away. I don’t use SSTP here, so there is no value in having this in my configuration backups.
Any ideas for how to squish this noise?
I think you have to set both, with comma in between.
Indeed; thank you! I’ve updated the article.
Next beta (7.15) will have support for it
Hey Reinis,
What can you tell me about IS-IS?
Is it already finished?
Finished??? 7.15 beta is not even released. It may be in alpha.
