v7.14rc [testing] is released!
@emilst
What issue are you referring to? Do you have a support ticket already open for this issue?
support #[SUP-138649]:
The bridge interface MTU is 1700 (L2MTU 1704). Bridge ports members have a 1500 MTU except for the WAN SFP interface that have a 1704 MTU (1704 L2MTU).
Then i have VLANs interfaces on the Bridge interface, for WAN and LANs. They all have a 1500 MTU (1700 L2MTU), except for the WAN VLAN that have a 1700 MTU (1700 L2MTU). The WAN port is the SFP physical interface.
The MTU values are accepted without problems at setup. But the VLAN WAN interface, after setting it to MTU = 1700, reset silently to MTU = 1500 probably a few hours later, difficult to say when exactly because there is no error report. It could be reset when changing routes or firewall rules.
I need a 1700 MTU on the WAN VLAN because it is my provider setup for an IPIPv6 tunnel. When the MTU reset to 1500 silently on this interface, i loose connectivity. Then i put it back to 1700 again, and it is ok but only for a few hours.
Something seems wrong in the code, i do not think that it is a setup problem. If it where a setup problem, i think that the MTU value would be rejected during setup, not silently after a random time.
I’ll need to create a report if you need it.
With rc2 if the folder begins with a capital letter there is a double SMB share with the same name: one with a capital initial and one with a lowercase initial.
As eworm already pointed out, you can just issue the same upgrade command which will now downgrade it back to 04, as 04 is now the “latest version”.
[admin@MikroTik] > interface/lte/firmware-upgrade lte1
installed: 16121.1034.00.01.01.05
latest: 16121.1034.00.01.01.04
/interface/lte/firmware-upgrade lte1 upgrade=yes
It happened again. SUP-144626
We use CRS326-24S+2Q+ as Boundary Clock with smpte profile
When IGMP Snooping is disabled PTP works almost fine (but we cant use it that way because video mcast kills CPU of the CRS326 and floods ports - even though it was just smpte2110-20 720-50p and our scenario base on high bandwidth mcast 4K-60p, unicast is working fully fine but its not right way for normal multimedia scenarios).
When we are using IGMP Snooping and PTPv2 (SMPTE2110 use case) PTP Delay Resp never emitted by the CRS326
       	PTP GM
       CRS326 (BoundaryClock)
       Receiver1	Receiver2
When I check tcpdump/wireshark - I do see PTP Delay Req being sent (tcpdump on Receiver1 and Receiver2 sees both - own and the second receiver PTP Delay Req).
When I check with PacketSniffer streaming from used iface port by Receiver1/2 I do not see also PTP Delay Req
Both Receiver1/2 we see as registered in ptp mcast goups in CRS326 (and both are getting PTP Announce, Followup, Sync)
Is it known limitation/issue or its our config issue, do you have any advice?
Thank you in advance
Upgraded from 7.13 stable to 7.14RC4, started having kernel panics. Downgraded to 7.13.5 stable and still having the kernel panics (full system reboot, log not displaying anything except for that a power supply interruption might’ve happened). RB5009UPr.
Why would a normal user run an RC version?
One can always download the package for the older version, put it on the router and reboot. It should work.
Using CAKE queues (as an Interface Queue or Queue Trees) on a CCR2004-16G-2S-PC results in a router crash when saturating a link.
Ticket SUP-139556
He talking about modem firmware version and not for ros version
Again …
this comment was about Fibocom LTE FW version 05 used on Ax Lite LTE.
Normally a user CAN NOT downgrade such a FW (or for any LTE FW version).
But because now they have removed 05 from their servers, you can.
Are you using a USB drive?
Create a report, please, and we will try to reproduce it on our end.
Why do you need to put the WAN interface under the bridge in the first place? You can create a VLAN interface directly on top of an SFP port.
Well now that’s more a philosophical question… The illusion of order?
Isn’t it recommended by Mikrotik documentation in the L3HW docs and the basic VLAN docs to not place a VLAN directly on top of a physical interface? That the new/improved/recommended method is to always use the bridge? Obviously this is the only way to take advantage of L3HW inter-vlan routing and some other features but I thought in general for v7 it was discouraged to do it the other way.
It is. But that’s only true for devices supporting L3HW (which RB5009 doesn’t). Which in turn only works for “plain” VLANs … but we’re discussing IPIPv6 tunnel, which is exclusively CPU-bound.
Alas, I agree that it should be possible to have different MTUs on different VLANs (L2MTU permitting). I’m not sure if this is possible for linux bridge though.
It is possible, just keep in mind you have to set all underlying connected physical interfaces that are plugged into the bridge to the highest minimum MTU you want. For example, I set all my physical interfaces at 9000 MTU and then on the VLANs themselves I set individual requirements, but all VLAN MTUs have to be less than 9000 obviously. TLDR, the bridge takes the lowest attached physical interface MTU as the maximum.
Only if that physical interface is a bridge port.
I’ve seen this on a number of releases over the past year or so, but in my case it can take weeks or months to happen.
IP WAN ports (like eBGP Transit, IXP port, PNI port, residential broadband DHCP, PPPoE etc) are meant to be independent PHY ports outside any bridge, if they need VLAN tagging on egress, you directly create layer 3 sub-interface VLAN on top of the port.
The bridge is for LAN-facing and intra-as facing ports with the usual single VLAN-aware aware Linux bridge principle.
