v7.15beta [testing] is released!
answering my own question:
it is about the output of /interface/wifi/monitor. confused me because IMHO output is not a parameter. Maybe call it property, label, term or key (as in key/value pair). Whatever you choose: parameter is a synonym for argument in a data input operation.
*) wifi - improve channel selection after radar detection events;
Does this fix the issue where the interface remained in “selecting channel” state after a radar event? e.g. http://forum.mikrotik.com/t/dfs-and-radar-channels/173814/1
This was a problem introduced in 7.14 and needs to be addressed ASAP. VRFs are broken for us.
See:
https://forum.mikrotik.com/posting.php?mode=quote&p=1060662
https://forum.mikrotik.com/posting.php?mode=quote&p=1059546
https://forum.mikrotik.com/posting.php?mode=quote&p=1059579
Can BGP-VPLS has staic name? (even if disconection happen)
@Mikrotik are you going to add an auto-update feature to addlist function. My lists have updated twice in as many days.
Would be great to be able to schedule it to fetch/look early in the morning etc.
yes, this is the last feature that MikroTik devices needed, a broken half baked adlist.
Thats my choice like I don’t have a choice to use half the crap people ask for ??
Guys …
Oh, the reply wasn’t directed at you, sorry @ToTheFull.
adlist updates every 1 hour, but in upcoming versions you will be able to change it
Please add a Whitelist if possible.
@normis I was using the fetch function and storing the file local hence no change. Yes 1 hour is very aggressive, good plan.
Thanks.
What’s new in 7.15beta6 (2024-Mar-08 08:23):
*) certificate - added support for importing pbes2 encrypted private keys with aes128;
*) chr - fixed bogus messages printed out while booting up the system (introduced in v7.14);
*) chr - fixed Xen and Vultr missing ethernet (introduced in v7.14);
*) ethernet - fixed default names for CRS310-8G+2S+ device (introduced in v7.14);
*) lte - make interface persistent (unused interface configs can be removed, allow to export and examine current configuration without the device present);
*) package - reduced package size for SMIPS;
*) poe-out - improved firmware upgrade stability for AF/AT controlled boards;
*) qos-hw - added congestion avoidance support for 98DX8xxx, 98DX4xxx, 98DX325x switch chips (CLI only);
*) qos-hw - added WRED support for compatible switches;
*) route - rework of route attributes;
*) sfp - improved system stability for CR2004-1G-2XS-PCIe (introduced in v7.14);
*) ssh - added passphrase option for host key import;
*) vrf - fixed VRF interfaces being moved to main table after reboot (introduced in v7.14);
*) wifi-qcom - improved regulatory compliance for L11, L22 devices;
*) wireguard - added peer “name” field and display it in logs;
*) wireguard - do not attempt to connect to peer without specified endpoint-address;
Upgraded rb5009 / AX2 / AX3 to 7.15b6
I see this in AX3 upon inspection of logs (same on AX2 but not for RB5009)
What script ?
holvoetn please create and send to support@mikrotik.com supout.rif file.
Done - SUP-146311
Did this happen on your ax2 as well ?
Sorry I didn’t read it properly
hAP ac2 doesn’t download the Adlist from URL…
SUP-146323
I can confirm CR2004-1G-2XS-PCIe is coming up again with 7.15beta6. Updated from 7.13.5.
Please back port this patch to 7.14.x
