I’m surprised they managed to make the propietary QCOM drivers run on a board with 128MB of RAM, back then when I had the ac2 it OOM’d even on OpenWrt running the “small buffers” ath10k driver.
Have a small bug. On my CCR1009, when I right click Interfaces → Interface → any interface → Detail Mode in winbox3.41 just closed. https://imgur.com/a/Ompf5pA
Thank you for clarifying, Sit75. My earlier post wasn’t intended as a direct response to the RAM issue you mentioned. I’ve been monitoring free memory on RouterOS since version 7.13, and my recent observation of approximately 280KB less free space after upgrading was meant as a general heads-up for the community.
Devices with limited free memory - say, around 200KB on 7.16 - could potentially encounter issues when moving to 7.17. Hopefully, this additional context will help others keep an eye on their device disk space during upgrades.
For any1 who upgraded to 7.17 pls check if it is still possible to downgrade to 7.14.3 after? Or it is now marked as not “allowed-versions” or whatever device mode forbids
Upgrade from 7.16.2 to 7.17 fails on a CCR2004-1G-12S+2XS. ~35MB of flash storage and ~3.8GB RAM available currently. Tried the upgrade multiple times.
Edit: tried to do the update on a second CCR2004-1G-12S+2XS which has a different configuration, got the exact same error.
If you use an old rebranding.dpk it doesn’t work. Do I need to regenerate it or do you still have to work on it?
The login page appears customized after loading the branding package but if I enter the credentials while clicking log in it adds /? instead of /webfig after the router address in the address bar and the login fails
Remember that “stable” in software releases means: “here you have a version that will remain for a while, we will not release a new version every week or two, so you can install this and won’t have to update it immediately”. The stability refers to the number of updates.
It does NOT mean that it will work in a stable way, i.e. will not crash or will not have problems with certain functions.
Wow… And how about me that, using semantic versioning as a reference, I was thinking that Stable could mean that the software manufacturer should only release as stable code that is free of any known bugs.
I think I’ll review a little more about versioning standards.
