v7.1beta6 [development] is released!
Common report - LTE support in beta6 is busted - either upgrade from 6.49beta54 to 7.1beta5 , or wait for 7.1beta7.
Is next beta/RC being released on 23rd August?
That’s what the rumor mill says!
I don’t know if it is just a bug in my setup but when I want to do an operator scan via lte1 the LTE Scanner always shows “Running”.
I tried:
  • Interfaces > lte1 > Scan… > Stop
  • Restart interface / device
  • /interface lte scan lte1 duration=1s
But it keeps showing the status “Running” and the scan does not work properly. Sometimes I see several operators but more often I don’t see any.
This appeared with a Chateau LTE12 running on v7.1beta6.
Did someone recognize the same behaviour?
Best regards,
McShadow
The only valid software for Chateau LTE12 is 7.0.3, why you install the beta called 7.1beta6?
Thanks for the reply. I will check it out. Installed it for test purposes and wanted to tell you about that bug.
If I can suggest something, next time check if you can go back before upgrade to non-removeable beta…
Download link for 7.0.3 is removed.
The clickable link is indeed not available at the https://mikrotik.com/download page as there's always only the latest version in each branch. However, the files themselves haven't been removed. You have to enter the complete url manually - see https://download.mikrotik.com/routeros/7.0beta3/routeros-7.0beta3-arm.npk etc.
I wrote 7.0.3, not 7.0beta3
The RouterOS 7.0.3 (stable) for ARM is an factory software dedicated version for Chateau LTE12 only.
@Normis posted a “private download” link, but it has been removed.
I don’t understand why is Mikrotik playing games with this Chateau 7.0.x download link. If you want to go back to original ROS version, you need it.
So just put it on official download page, what’s so complicated about that?!
Mikrotik is actually shipping device with this version for quite a while, but they are too embarrassed(?) to put in on download page?
They do not post the firmware publicly because it will brick non-chateau devices. Both times they posted a link, with warning, at least one user tried installing it on another model.
ROS 7.1 moving to testing channel on August 23th?
Why do speculate? Only MT knows the release schedule. Stop spreading rumor.
If some has a link to hard facts, do post…
Before that can happen, at least the conversion of configuration has to work reasonably well, and that has not been tested yet.
I think we need further beta versions that people can upload to their 6.48.3 install had see that it keeps functioning as before.
Observations of problems (MikroTik cannot possibly test all configurations) have to be reported and fixed, probably requiring another beta or two.
Moving it to testing now will result in a massacre, no matter how big the warning at the top of the release notes is to not just do a blind update of a router when you cannot afford hours of downtime and do not have local access.
Can anyone report/comment if OSPF is working with v7.1beta6 with wire guard? It has not worked in beta5 and earlier. Thank you!
Yes it works for me (OSPFv2).
(With PTP type /30 Wireguard links)
But it worked on beta5 for me too so…
[admin@MikroTik] > /system package update check-for-updates
            channel: development
  installed-version: 6.47.10
     latest-version: 7.1rc1
             status: New version is available
Looks like v7.1rc1 has been released (but the changelog is currently missing).
New version 7.1rc1 has been released in development RouterOS channel:
http://forum.mikrotik.com/t/v7-1rc1-development-is-released/151250/1
