V7.20.3 [stable] is released!
RouterOS version 7.20.3 have been released in the "v7 stable" channel!
Before an upgrade:
  2. Make sure the device will not lose power during upgrade process;
  3. Device has enough free storage space for all RouterOS packages to be downloaded.
What's new in 7.20.3 (2025-Oct-28 14:45):
  • lte - fixed LED behavior for Chateau 5G R17 ax;
  • ppp - do not automatically add apn=internet for manually created ppp-client interfaces;
  • ppp - fixed ppp-client not dialing when two interfaces use same multi-channel port;
  • snmp - fixed various connection tracking OID definitions in MIKROTIK-MIB;
  • ssh - fixed non-interactive command execution (introduced in v7.20);
  • wifi - changed country code to "XA" for "UK 5.8 fixed outdoor" regulatory domain;
To upgrade, click "Check for updates" at /system package in your RouterOS configuration interface, or head to our download page: http://www.mikrotik.com/download
If you experience version related issues, then please send supout file from your router to support@mikrotik.com. File must be generated while a router is not working as suspected or after some problem has appeared on the device.
I see 7.20.4 in WinBox with different changelog
Version 7.20.4 has been released:
The 7.20.3 was built in 28th October, but we did not want to publicly release it until PPPoE server fix was available. The one major issue a lot of users reported for v7.20. This 7.20.3 version however was needed for a new device for factory installation.
Now that PPPoE server fix is available, we have released both version, the 7.20.4 being the latest stable.
Please check (SUP-203163)
7.20.4 still have problem with this issue.
Thx
Does it mean that 7.20.3 has PPPoE bug and it is a factory version for some devices (guessing hAP ax S)?
There was this one guy who claimed he only installs "factory only releases" because, logically, those must be the most stable ones.
Interesting… In old times factory only releases were not publicly available for download, but this one actually is.
