V7.21.1 [stable] is released!
Before an upgrade:
  2. Make sure the device will not lose power during upgrade process;
  3. Device has enough free storage space for all RouterOS packages to be downloaded.
What's new in 7.21.1 (2026-Jan-19 17:09):
  • bridge - fixed dynamic switch-cpu VLAN creation (introduced in v7.21);
  • bridge - improved stability when using MVRP (introduced in v7.21);
  • certificate - fixed empty trust store handling in certain cases (introduced in v7.21);
  • container - changed app auto update to be off by default;
  • container - fixed issue where containers may not start with large mounts;
  • health - fixed fan and PSU state logging for MIPSBE devices;
  • leds - fixed power LED behavior for hAP ax S;
  • lte - fixed APN configuration for QMI modems in a 3G network when use-network-apn=yes is used;
  • switch - fixed switch type for hAP ax lite devices (introduced in v7.21);
  • system - fixed rare partial loss of RouterOS configuration;
To upgrade, click Check For Updates under System/Packages menu and select the stable Channel in RouterOS configuration interface, or head to our download page: http://www.mikrotik.com/download
  • Everything went smoothly
  • I encountered an issue after the update (please post about the device, configuration, and unexpected symptoms)
  • I encountered an issue, but solved it (please post the solution)
0 voters
If you experience version related issues, then please send supout file from your router to support@mikrotik.com. The file must be generated while a router is not working as suspected or after some problem has appeared on the device
I'm wrong, bug still exists.
Upgrade from 7.20.7 to 7.21.1 leads to make all containers stop working, have to repull them.
Does this bug still affect v7.20.7 long-term release? If so, then surely it is advisable to switch to stable, or push a new long-term release? It may be a rare bug, but it sounds pretty critical nonetheless
7.21.1 breaks my Chateau 5G R17 ax. After installing, 5G modem always falls back to 4G and cannot connect to internet. No IP/IPv6 is acquired on lte1 interface. Downgrading back to 7.21 solves the issue. After that, 5G modem stays at 5G NSA an I am getting an IP/IPv6 on lte1 interface.
I can reproduce that by upgrading again to 7.21.1. Created ticket: SUP-209010
[EDIT]
Fixed by provided testbuild from MikroTik support. According to MikroTIk, fix will be in next stable release.
I noticed that the PPPoE client appeared connected twice, and in addition, the DNS took about 20 seconds to respond.
  1. SUP-209012
On a quick test, looks like L3VPN (vpnv4 / vpnv6) still are not dealing correctly Next-Hop vs NLRI.
Obs.: On a VERY QUICK test and without any kind of analysis.
I will need to find some time to explore it deeply.
please fix rip timers . route gc timeout hardcoded to 3 minutes (180 seconds) and values configured for rip timers ignored . Issue already ages. SUP-199943
Just upgraded my Chateau R17 to RouterOS 7.21.1 and immediately lost LTE connectivity. The router physically connects to the cellular network but seems to be unable to get an IP address for its LTE interface. Downgrading back to 7.21 fixes the problem.
Hope this issue will be fixed in next versions of the system.
( mod edit: post merged into this thread)
Updated Chateau LTE12 (legacy model) and LTE works fine.
v7.20.7 lost some firewall parts of my config so i had to reset from a backup. this one went better but the dude is playing up
Start trying on systems where having trouble with vlan filtering on bridge.
I do hope this was just a test router. Upgrading 30 min after a new release is always risky. :slight_smile:
Installing Fresh RoS build in first 2 hours after release is the same like playing Russian Rulet!
If it has never been done, you should do what is described in the link, because the upgrade/update does not do it:
I see no changes to wifi/wifi-qcom-ac in the changelog, but one of my wireless clients (Intel AX200) went completely nuts after upgrade to 7.21.1. It was disconnecting about every 30 seconds. It was unusable. It went for a few hours this way. I tried rebooting, checked frequencies, nothing helped. After downgrade to 7.21 this client's connection is rock solid again. Don't know what caused this.
In lab, no problem
in smol homenet → no issues
RB5009, using VLAN filtering with l2hw, intra vlan IP routing and NAT towards ISP, the usual firewall rules and wireguard: Updated from 7.21.0 to 7.21.1 without issues so far.
Chateau R17: Same issue as reported by others: lte is reported as connected, but does not move any data and hence fails to even get an IP. lte works again after reverting to 7.21.0
There are no problems with the Mikrotik hAP ax². It is working perfectly and without any issues.
  • Google DoH is working. Cloudflare is giving an SSL certificate trust error.
Did you notice that they have a new certificate issued by another CA? You need "SSL.com Root Certification Authority ECC" now.
