V7.21.1 [stable] is released!
Interesting update. I updated the firmware and rebooted.
The route came up with this in the configuration:
/ipv6 address
add address=::2:0:0:0:1 from-pool=general-pool6 interface=wireguard1
add address=::1:0:0:0:1 from-pool=general-pool6 interface=VLAN30
add address=::1 from-pool=general-pool6 interface=VLAN10
and the actual ipv6 addresses seem to match
> /ipv6/address print
Flags: D - DYNAMIC; G - GLOBAL, L - LINK-LOCAL
Columns: ADDRESS, FROM-POOL, INTERFACE, VRF
 #    ADDRESS                                 FROM-POOL      INTERFACE             VRF
 0  G 2601:xxxx:xxxx:xx62::1/64                general-pool6  wireguard1            main
 1  G 2601:xxxx:xxxx:xx61::1/64                general-pool6  VLAN30                main
 2  G 2601:xxxx:xxxx:xx60::1/64                general-pool6  VLAN10                main
I guess the moral of the story is update your firmware and reboot often. I will do more experiments as time permits.
EDIT:
I spoke too soon. A couple minutes after I posted this, the configuration changed back to the old, bad config without me touching it. It is now:
/ipv6 address
add address=::3:0:0:0:1 from-pool=general-pool6 interface=VLAN10
/ipv6/address print
2 G 2601:xxxx:xxxx:xx63::1/64 general-pool6 VLAN10 main
It would seem this is buggy.
Last edit:
I got “address=::1” to work for a while by clearing the config and rebooting, but within an hour the configuration changed itself back to the “address=::3:0:0:0:1 ” form. I guess ROS really really doesnt want you to use the first subnet. To me this is a bug, but you could look at it as a (misguided in my opinion) design decision. Guess we should be happy that at least now you can always predict which subnet each network will get.
I have updated from v 7.20 and the new error started to appear in the logs:
DoH server connection error: resolving error
The reason is that I was using builtin-trust-anchors attribute that is no longer available.
/certificate settings set builtin-trust-anchors=trusted
So I had to import the CA of the DoH server manually into the Certificates. Now it seems to be solved.
downgrade done to 7.20.6 of more than 50 devices ; too many problems with this release
Which DNS server are we talking about? By default, these settings are enabled, and Google's DoH works perfectly.
Most probably cloudflare-dns.com. They have changed the CA of their certificate last week and now the built-in CAs in RouterOS are no longer enough to verify the certificate for cloudflare-dns.com.
I know that. I’m just asking users to specify DNS when they report that this is a NEW BUG in RouterOS 7.21.x.
A very strange buggy change.
Hey it is not compatible with sxt lite 5ndr2 I guess ! I installed but I dont see the wifi so I will downgrade. alsı the v 7 20 is the same situation. do you have any experience ? I couldnt find anything except chat gpt.It says v7 is not compatible with sxt lite 5
This device has 64Mb RAM and 128Mb flash so running ROS7 on it should not be a problem.
Did you install wireless package ?
Since ROS7.13 (if my memory serves me right) wireless has been removed from base package and is to be added separately for devices requiring it.
It can run v7, but what is reason to do that? That device had weak processor and low amount of RAM, better stay on v6.49.19.
For testing I’ve upgraded 1 piece some time ago ( target v7.19.6) and it worked fine, but it doesn’t make a sense to me to do mass upgrade.
Also don’t belive chat gpt in that manners.
MT says : Note: We do not recommend running v7 on hardware that does not have at least 64 MB of RAM.
It seems that with every startup, version 7.21.x tries to update the containers running from /App.
This is from the container log:
*** downloading and extracting remote image: registry:registry-1.docker.io nspace:technitium name:dns-server tag:latest arch:arm64
*** skipping the import because it’s the same version
Is there a way to stop the containers from trying to update on every startup? I’d like to update them only when I choose.
Dear Mikrotik Support,
I did the upgrade on my remote Chateau R17 connected to LTE/5G network and it stops respoding to me (“Welcome to the club..”) cycle of powersource I can only do via remote controlled person did not solve it.
Now I have to travell there and make the correction. Please is there some CLI task I can do from internal wifi on mobile phone client or I have to go there with PC and make reinstall ? Is there some new version of firmware I could apply now ? Many thanks for some advices
With Best Regards
Radek
It’s “nice” they have information about wrong symptoms of this release since Jan 21st and did not stopped updating to 7.21.1 :confused: Broken 5G/LTE connection is not a cosmetic topic to left it untouched.
If you have someone at the site who is competent enough to be talked through connecting to the device with winbox you may be able to talk them through performing a downgrade on it to the previous version. This should get it up and running again. It's unfortunately a known issue with this version of router os it breaks lte connectivity with the chateau 5g r17. If you don't need any of the newest features it may be wise to move this device onto the long term stable release channel.
Hmm. The problem in this case is, that we all know about breaking of connectivity to LTE/5G and the release is still available to download. At least release notes shall be updated with warning, that for 5G/LTE it is the killer. I did this remotely (as the Stable means STABLE w/o known major issues).. after that there is no way to rollback and need to travell to remote location and do the downgrade/update from internal network. I understand your position for BETA/DEV branches. There is no excuse for Stable..
I do understand your problem but it is never wise to jump on a new version without first checking if some issues already have been reported which affect your situation.
Never upgrade for the sake of upgrading.
In home lab, I try to follow most development/test versions. That's what my home lab is for.
But in production environment I usually wait at least 2 weeks before deploying a version, if needed.
I recently moved all production devices to 7.20.7 (even though 7.21 was already in stable at that moment) and I think they will stay there for quite a while unless I notice a bug which really merits upgrading.
Which up til now is not the case.
Yeap.. I’m new in this Mikrotik great world and the progress was I have read notes for 7.20.. than just read release notes for 7.21.1 after about week after release - did not expect that there is the reelase w/o warnings in release notes that is “bricking” for me my device that is remote. I already did update on other devices to 7.21.1 in my home network and this one was the last one and the only Chateau R17.. From my desk it has a “logic” and for future I know what and how to do. The lessaon learnt for Mikrotik but must be stop the release or at least update release notes with big warning about such a major problem.
Welcome to Mikrotik world ... where release notes and change log don't get updated after release of corresponding ROS.
I don't understand why this 7.21 series isn't stopped officialy....
This is indeed irritating. There is a - judging from the reports - critical issue with Chateau R17. But not a single mention in changelog. This is unfair to every device owner. Reading forum topic should not be mandatory, as this community discussion (with lots of OT in between). Mikrotik should think about a way to document critical problems better. The ones that are not "because of huge and complicated configuration".
