V7.21.1 [stable] is released!
I did not find out any official anoncements, warnings or whatever could make the user attention. Mikrotik is just “nothing happens - we have Stable release and if something wrong install older version or go to beta”. The only source is here in this forum where there are few people with some problems.. The release was in Stable brach so there should not be any user doubts about major problems with it. Also the correction is not in place. Reverting from from Stable to previous Stable is not the step towards trust in SW quality (that is I hope the priority also and it was and will be the reason why I selected Mikrotik).
Mikrotik is still recommending this release as the right one on their website for Chateau R17… :frowning:
They rarely pull a release because something doesn't work correctly. It's also not wise with mikrotik to be one of the first to update to a new version without checking the forums first to see if there are any issues with it. I know it's really frustrating for you, but I'm sure they are aware they have an issue with this release and the Chateau 5g R17, other people have posted the same problem as you gave been having. The solution was to downgrade to the previous version, until a fix is in the next release. Your other solution would be to move to the long term stable release 7.20.7. Highly recommended if you don't need the very latest features and just want stability and security fixes.
ROSE/RDS issue(s) report:
  • Upgrading from 7.20(.7) to 7.21(.1) makes the ROSE subsystem “forget” a raid-array (a fairly large raid 6 array in our case). The raid members are still showing and the array needs to be manually re-added/re-defined to get it back to life.
  • Enabling nfs-sharing on the array makes the RDS/ROSE subsystem DEEPLY UNHAPPY. All disks disappear once enabled and the only way to get them back is to manually force a /disk/eject via CLI, which ultimately fails since the disks are not seen by the system, but somehow, it brings them all back to life. Or it may be a coincidence and the disks magically appear on their own after a while, it's really hard to tell. Either way, disabling nfs sharing makes them come back instantly at the next reboot, while enabling nfs sharing clearly puts the router in a bind. Now, this specific issue may have been lurking since 7.19 or 7.20, we only tried NFS on 7.21.
Edit (nfs-sharing): The disks and array eventually and magically appear on their own after a while, but the router does freak out, crashes and reboots if you try to change any settings to the array if nfs-sharing is on. The log shows kernel failures. I can eventually mount the NFS share, but it won’t let me browse or write to it.
David
same issue here. switch from 5g to lte and ip stays at 0.0.0.0 ….
Mikrotik hAP ax². After upgrading to 7.21.1 all existing Wi-Fi connections (with WPA3 EAP-192, using certificates generated in router) are broken. Password-protected (WPA2-PSK) profiles still work.
There is no possibility to connect using existing setup (from Windows 10).
Tried to reconnect on Windows 10 from scratch didn't succeed.
What else can I try?
What does "broken" mean?
From what version did you upgrade?
Have you checked the logging (both MikroTik and Windows)?
Do the problems also occur when connecting with Windows 11/Linux/MacOS?
Can you share your security settings?
/interface wifi security export
“broken” - It means that all existing and previously working connections stopped to work only just after upgrading routeros version. Also it stops to work from Android device too…
Logs in Mikrotik didn’t show anything new related to the connection.
Windows logs:
The certificate received from the remote server is either expired or not yet valid. The TLS connection request failed. The attached data contains the server certificate.
Wi-Fi security settings:
add authentication-types=wpa2-psk disabled=no name=sec-ssmp wps=disable
add authentication-types=wpa3-eap-192 disabled=no eap-certificate-mode=verify-certificate eap-methods=tls eap-tls-certificate=WiFi_Server
encryption="" name=sec-wpa3-eap wps=disable
Looks like server cert is expired, and it's just a coincidence with the RouterOS update…
7.21.1 broke all containers I was running on a hAP ax^3 All of them fail to start and display could not load config json
repull them
is it me, or container mount points are set up now as directory instead of “container store” ?
Version 7.21.2 has been released:
I experienced that same issue - all images had to be repulled. Thankfully, it was easy enough to do, and the result was positive.
Good afternoon!
On my MikroTik routers, in the LAN bridge where there's a DHCP server, I also have a DHCP client to notify me if there's a rogue DHCP server.
After updating to this version, and with nothing connected to the physical ports, the DHCP client on the bridge is getting an IP address assigned by the DHCP server.
This didn't happen before. It also doesn't happen with long-term configuration.
Have I always configured something incorrectly? Or has an option been changed that I wasn't aware of?
Why don't you use the DHCP Alerts feature for this purpose?
