BGP-VPN4 issue with not being able to advertise BGP multihop still has not been fixed in version 7.21.3
The IPv6 default route issue has been fixed!! I no longer have to enable the “Add Default Route” option in the client.
It’s Déjà vu all over again
Hahahah it's real this time!
Just upgraded my home setup and all is working fine (since imgp-snooping=no) ![]()
wg, ipv6 ra, ipv6 neighbors, nat, bridge modifications, vxlans, ...
Updated smol-homenet, update took a long time. Thought everything is bricked. After a few minutes, devices came up. So far no issues, but this long playing dead reminds me of Sonicwall…
Thanks for fixing the IPv6 issue; so far, this version is very good. As for 7.22rc1
Since we upgraded a CCR2216 from 7.20.5 to 7.21.2 (and then to 7.22rc1 too) the VLAN counters (traffic and packets) no longer works if the VLANs are L3 Hardware Accellerated (no problem in counters with no-hardware VLANs).
The counters worked correctly with version 7.20.5 and previous. No problem with the traffic itself, but now they count only very few packets, probably only the broadcasts sent to the CPU.
Is it a known bug?
Has anyone else encountered this problem?
Opened a ticket to Mikrotik a few days ago, but with no reply at all…
Thanks.
I have an open bug about it. My workaround is to disable/enable one of the vlan that show no traffic. Then when it come back it start to show the traffic and all others vlan do the same.
Please do this when you have low level of traffic because disable an havy load hwl3 vlan could cause instability.
regards
Unfortunately it didn't worked for us (or only partially)
[SUP-209892]: LTE not working SIMCOM_SIM7600CE-T
still not solved ![]()
After upgrading to 7.21.3 from 2, all of my static DHCP configuration vanished. F*cking crap. Do you guys have QA or this is now handled by AI?
Restore that config section ![]()
They do get lots of Questions but reply with very few Answers. ![]()
My static dhcp leases are still where they were on 7.21.2.
If its not written that its fixed, no need to ask here. Its not fixed. Try email Mikrotik instead. You should be able to get status of you ticket.
And you have (nearly) zero flash space, probably?
No, 4.9 MiB left out of 16.0 MiB
Well in 7.21.1 Changelog, there was:
system - fixed rare partial loss of RouterOS configuration;
but, I haven’t had this issue at that time. So look like this is still not resolved.
