*) bgp - fixed reporting of session uptime;
*) branding - execute “autorun.scr” file when installing branding package;
*) certificate - restricted maximum retry attempt window for Let’s Encrypt certificate to 60 minutes;
*) container - allow changing container related parameters while it is running;
*) health - improved voltage reading on RBmAP-2nD;
*) hotspot - fixed SSL usage on all HotSpot pages;
*) l3hw - improved connected host offloading on startup;
*) l3hw - improved connected IPv6 host offloading when routing table is nearly full for 98DX224S, 98DX226S, and 98DX3236 switch chips;
*) l3hw - made route offloading selection work only on unicast;
*) lte - added interface name in MTU debug logging message;
*) ospf - fixed checksum calculation;
*) ospf - improved logging when invalid configuration is detected;
*) route - fixed disappearance of inactive static routes after upgrade;
*) routerboard - set “Delete” as default key to enter booter menu (“/system routerboard upgrade” required);
*) sms - fixed handling of SMS send attempts on unsupported modems;
*) user-manager - accept any username for outer authentication;
*) user-manager - added “comment” parameter for batch user creation;
*) user-manager - added support for multiple accounting sessions;
*) user-manager - added variables to print profile name and end time in voucher templates;
*) user-manager - forced username verification against client’s certificate for EAP-TLS;
*) webfig - fixed creation of new IPv6 routes;
*) winbox - changed order of tabs under “User Manager” menu;
*) wireless - fixed incorrectly applied ingress priority to non-wireless packets;
I know nothing is explicitly mentioned in the changelogs for this, but Once again the container was working fine until the version upgrade and occurs every time after upgrading to new beta (already reported for 7.6beta6: http://forum.mikrotik.com/t/v7-6beta-testing-is-released/160567/107)…
It’s a real tedious and time-consuming headache to recreate and reconfigure each time. When will this be fixed?? Pls guys
No! The uptime is ticking but it still displays fake information when a winbox “sessions” screen is open!
The uptime continues to tick up even when the session has been closed or failed.
It seems to be fixed at the CLI. They might need to do additional things to fix this in Winbox, as it is quite common for them to add a new feature in the CLI and it only works in Winbox in a future version. What I see now in the CLI is that the session timer is back when the session is active, but it disappears entirely when the session has stopped. I think Winbox doesn’t know how to handle this and instead just keeps counting the seconds from where it was before rather than clearing it. Probably, in a future version, we will see Winbox fixed.
The nice enhancement we have now, compared to 7.4, is that there are now fields for BGP session last-started and last-stopped date and time at the CLI.
BGP VRF MPLS L3 (PE-CE) in v7.6 beta7
still having problem with routing propagation.
route sent from PE did not propagate correctly to Other PE’s, missing AS-PATH
thx
What we need in winbox is an auto-refresh of the BGP sessions window, as it was with v6 with the BGP peers window!
It should poll the router for actual information (including the actual uptime) rather than make a single query and display that info forever, including a fake ticking uptime.
That is not what I am claiming! The session gets disconnected and gets restored when the link comes back, but that does not show in the sessions display.
No idea why it does not work for you. I never seen that happening. Did you check the log? Maybe it says something like “EBGP peer is not on a shared network and multihop is not configured”? There is a bug in the new BGP that sometimes makes it mis-detect this situation and you have to enable multihop even though the peer isn’t multihop!
