I got an Hap AC2 today and I have some trouble with setup…
I am testing from Windows 10 on a MacBook air, which has a wifi AC card.
- version 6.45.9 (long term)
- wifi connection status says it’s connected with good speed, e.g 866 Mbps
- speedtest.net shows only ~16 Mbps download and 200 Mbps upload, should be around 500/500.
- same laptop card is capable of higher speed, I restarted in MacOS and test was 370 mbps / 440 Mbps
- router browser interface loads slow, images under login form load slow
- after entering the user/pass, web page loads forever
- when I try to login with WinBox (v3.24) using router IP, I click connect and get “Downloading descriptors…” forever, not logging in
- other devices, e.g an iPhone 11 connected to this same router, speed test shown almost 500Mbps up/down
What can this indicate ? Is the router OK, should I focus on the laptop and reinstall OS maybe ? ![]()
Download is 10 times slower than upload, which is strange.
Wifi settings:
- on wifi2 interface (5Ghz), I set frequency to 5500 Mhz, because letting it to auto took ages to boot up the 5G
- Channel width: 20/40/80MHz XXXX
- Auth Types: WPA2 PSK
- Unicast Ciphers: aes ccm, tkip
- Group Chiphers: aes ccm, tkip
