Very slow LTE
As long as you don’t have an exception for the Address it will try accessing the MT WebGUI through the proxy.
Which I guess the proxy doesn’t like to do.
Thanks for confirmation.
I’m updating my software from the Debian stable repository.
So, if they don’t have a version that works with the said ROS version, then I cannot do anything else.
But I would have guessed that such a big company like MikroTik would have some inhouse test people who test the software with all the major webbrowser versions.
A good part-time job for students for example, IMO.
Yes, but 115.14 has been out of date for a long time (common Debian LTS thing, but we’re not starting this discussion here on MT Forums :smiley:)
115.15 has been released in September 2024.
And the current ESR Version 128 works great
ESR 115.20 doesn’t work, but support for it will end in MARCH 2025
Plenty of sites not working with Internet Explorer anymore.
Why would it be different with other old browser versions ?
Why not just use Winbox? No need for a browser of any type. v3 works fine using wine in Linux and v4 works natively in Linux.
Plus added benefit of MAC access when IP is failing.
I now have made this working with 3 LTE routers (1 “MT hAP ax lite LTE6” and 2 of the said cheap CPE LTE4 routers).
As said, the hAP did cause some speed problems, but if one finds a “sweet spot” in the room then that router becomes usable also w/o extending it with an external LTE antenna…
If anybody interested, I can post my Linux config (entry in /etc/network/interfaces and a bash script gateway-select.sh that acccepts the params R1, R2, R3; this of course can also be called via cron job…)
Each PC can chose itself the (wireless) WAN gateway it wants to use (prioritization via “metric” settings) .
Ie. this is a simple solution for only a few PCs in LAN, not for a company or so.
