Virtual WIFI and VLAN's - driving me crazy
I’ve a network with 2 VLAN’s (apart from the default VLAN 1). The VLAN 101 is for Guest and 102 is for management. For some reason I cannot get my wAP configured to have 2 WIFI’s, one for the guest and the other one for management. To simplify it, I’ve disconnected the wAP from the main network and I’m now trying to configure the wAP isolated on its own device. Hope anybody can help me with this.
I’ve setup to virual wlan’s, vlan101 has not vlan config and with vlan102 I’m trying to configure the VLAN. I’m doing this so that I can compare what is working and not working.
On the vlan102 wlan interface I don’t get an IP address from the DHCP server that I’ve configured on the wAP itself. In the final setup the DHCP server is located somewhere else in the network.
Connecting on the vlan101 interface, I do get an IP address from the correct pool, but getting the IP takes a long time, too long in my view.
What am I doing wrong? Is this approach to simulate it on a single device achievable? And finally if I’ve a working setup I want to migrate this to a CAPSMAN configuration. But one step at the time for now.
# oct/28/2021 20:11:23 by RouterOS 6.48.1
# software id = TMGN-VZVM
# model = RouterBOARD wAP G-5HacT2HnD
# serial number = 69A50578307F
add name=bridge
add name=bridgevlan101 vlan-filtering=yes
add name=bridgevlan102
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
    disabled=no distance=indoors frequency=auto installation=outdoor mode=\
    ap-bridge ssid=MikroTik wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=\
    20/40/80mhz-XXXX distance=indoors frequency=auto installation=outdoor \
    mode=ap-bridge ssid=MikroTik wireless-protocol=802.11
add disabled=no keepalive-frames=disabled mac-address=E6:8D:8C:72:D5:30 \
    master-interface=wlan1 multicast-buffering=disabled name=wlan3 ssid=\
    TestVLAN101 vlan-id=101 vlan-mode=use-tag wds-cost-range=0 \
    wds-default-cost=0 wps-mode=disabled
add disabled=no keepalive-frames=disabled mac-address=E6:8D:8C:72:D5:31 \
    master-interface=wlan1 multicast-buffering=disabled name=wlan4 ssid=\
    TestVLAN102 wds-cost-range=0 wds-default-cost=0 wps-mode=disabled
/interface vlan
add interface=ether1 name=vlan101 vlan-id=101
add interface=ether1 name=vlan102 vlan-id=102
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip hotspot profile
add name=dhcp ranges=192.168.88.10-192.168.88.254
add name=dhcp_pool_vlan101 ranges=172.16.0.100-172.16.0.254
add name=dhcp_pool_vlan102 ranges=172.16.1.100-172.16.1.200
add address-pool=dhcp disabled=no interface=bridge name=defconf
add address-pool=dhcp_pool_vlan101 disabled=no interface=bridgevlan101 name=\
    dhcp1
add address-pool=dhcp_pool_vlan102 disabled=no interface=bridgevlan102 name=\
    dhcp2
add bridge=bridge interface=wlan1
add bridge=bridge interface=wlan2
add bridge=bridgevlan101 interface=wlan3 multicast-router=disabled
add bridge=bridgevlan102 interface=wlan4 multicast-router=disabled
add bridge=bridgevlan101 interface=vlan101 multicast-router=disabled
add bridge=bridgevlan102 interface=vlan102 multicast-router=disabled
/interface bridge vlan
add bridge=bridgevlan101 tagged=wlan3,ether1 vlan-ids=101
/interface detect-internet
set detect-interface-list=all
add interface=bridge list=LAN
add interface=ether1 list=WAN
add interface=bridgevlan101 list=LAN
add interface=bridgevlan102 list=LAN
add address=192.168.88.1/24 interface=bridge network=192.168.88.0
add address=172.16.0.0/24 interface=bridgevlan101 network=172.16.0.0
add address=172.16.1.0/24 interface=bridgevlan102 network=172.16.1.0
/ip dhcp-client
add disabled=no interface=ether1
add address=172.16.0.0/24 gateway=172.16.0.1
add address=172.16.1.0/24 gateway=172.16.1.0
set allow-remote-requests=yes
/ip dns static
    disabled=yes ipsec-policy=in,ipsec
    disabled=yes ipsec-policy=out,ipsec
    connection-state=established,related disabled=yes
    established,related,untracked disabled=yes
    connection-state=invalid disabled=yes
    connection-state=new disabled=yes in-interface-list=WAN
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=bridge type=internal
add interface=ether1 type=external
/system clock
set time-zone-name=Europe/Amsterdam
/system logging
add topics=dhcp
add topics=wireless
Looking forward to some suggestions on how to address this.
You want to create a Bridge and assign all Interfaces to it.
Ether1, WLAN1, WLAN2, WLAN3, WLAN4, VLAN101, VLAN 102
Then everything should work, like you expect !
Ok, thanks for the suggestion, testing it right now.
As I can only set one dhcp server on the bridge, I cannot fully simulate this on one wAP. Because now all the virtual wlans are getting an IP address from the same server.
How do I do the VLAN tagging when using one bridge?
On the wlan config I set “use tag” with vlanid 101 or 102 (depending on which wlan interface).
On the bridge I do not configure any vlan filtering or what soever?
And under the ether1 port I put to VLANs, 101 and 102.
Is this how is should work?
Oh am sorry..
VLAN101, VLAN 102 are not assigned to the bridge.
Then you can assign the DHCP-Server to the VLAN101, VLAN 102-Interfaces
Hhmm, not working. I don’t get an IP address assigned on either one of the two virtual wlans.
both wlan interface use a vlan tag 101 and 102, no vlans on the bridge and the bridge itself doesn’t do vlan filtering.
This is the config:
add name=bridge
/interface wireless
/interface vlan
/ip hotspot profile
dhcp1
dhcp2
/ip dhcp-client
/ip dns static
add action=accept chain=forward comment=“defconf: accept in ipsec policy”
add action=accept chain=forward comment=“defconf: accept out ipsec policy”
add action=fasttrack-connection chain=forward comment=“defconf: fasttrack”
“defconf: accept established,related, untracked” connection-state=
add action=drop chain=forward comment=“defconf: drop invalid”
“defconf: drop all from WAN not DSTNATed” connection-nat-state=!dstnat
add action=masquerade chain=srcnat comment=“defconf: masquerade”
/ip upnp
set enabled=yes
/ip upnp interfaces
/system clock
/system logging
add topics=dhcp
add topics=wireless
Suggestion on what I’m doing wrong?
I still have a CAPac somewhere…
I will configure it and send you the Export.
Give me 20 minutes
Thanks, you support is really appreciated.
Extra info, when I remove the “Use Tag” and put VLAN ID to 1, I do get an IP address on the wlan interface.
This has something to do with the VLAN configuration on the bridge somehow.
some reading: http://forum.mikrotik.com/t/wlan-ssids-attached-to-vlans/149454/1
Start with the “great tutorial” mentioned there , it’s a must read !
Found a big mistake :
This is wrong
This is right!
add address=172.16.0.1/24 interface=bridgevlan101 network=172.16.0.0
add address=172.16.1.1/24 interface=bridgevlan102 network=172.16.1.0
This is how i configured the CAPac in the LAB…
Step 0: Configure WLAN’s
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX disabled=no distance=indoors frequency=auto installation=outdoor mode=ap-bridge ssid=MikroTik wireless-protocol=\
    802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-XXXX disabled=no distance=indoors frequency=auto installation=outdoor mode=ap-bridge ssid=MikroTik \
add disabled=no keepalive-frames=disabled mac-address=E6:8D:8C:72:D5:30 master-interface=wlan1 multicast-buffering=disabled name=wlan3 ssid=TestVLAN101 vlan-id=101 vlan-mode=use-tag \
add disabled=no keepalive-frames=disabled mac-address=E6:8D:8C:72:D5:31 master-interface=wlan1 multicast-buffering=disabled name=wlan4 ssid=TestVLAN102 vlan-id=102 vlan-mode=use-tag \
Step 1: Create Bridge
add name=bridge1
Step 2: Create VLAN-Interfaces
/interface vlan
add interface=bridge1 name=bridge1_vlan101 vlan-id=101
add interface=bridge1 name=bridge1_vlan102 vlan-id=102
Step 3: Assign IP-Addresses
add address=192.168.88.1/24 interface=bridge1 network=192.168.88.0
add address=172.16.0.1/24 interface=bridge1_vlan101 network=172.16.0.0
add address=172.16.1.1/24 interface=bridge1_vlan102 network=172.16.1.0
Step 4: Create DHCP-Server
add name=dhcp_pool0 ranges=192.168.88.100-192.168.88.254
add name=dhcp_pool1 ranges=172.16.0.100-172.16.0.254
add name=dhcp_pool2 ranges=172.16.1.100-172.16.1.254
add address-pool=dhcp_pool0 disabled=no interface=bridge1 name=dhcp1
add address-pool=dhcp_pool1 disabled=no interface=bridge1_vlan101 name=dhcp2
add address-pool=dhcp_pool2 disabled=no interface=bridge1_vlan102 name=dhcp3
Step 5: Assign Interfaces to Bridge
add bridge=bridge1 interface=wlan1
add bridge=bridge1 interface=wlan2
add bridge=bridge1 interface=wlan3
add bridge=bridge1 interface=wlan4
THanks for the catch, good point, That is indeed a mistake. I updated the config, see total overview below, but still the wlan client device doesn’t get an IP address!
oct/28/2021 22:41:53 by RouterOS 6.48.1
add name=bridge
add name=bridgeVLAN101 vlan-filtering=yes
add name=bridgeVLAN102 vlan-filtering=yes
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX disabled=no distance=indoors frequency=auto installation=outdoor mode=ap-bridge ssid=MikroTik wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-XXXX distance=indoors frequency=auto installation=outdoor mode=ap-bridge ssid=MikroTik wireless-protocol=802.11
/interface vlan
add name=dhcp_pool7 ranges=172.16.0.100-172.16.0.254
add name=dhcp_pool8 ranges=172.16.1.100-172.16.1.254
add address-pool=dhcp_pool7 disabled=no interface=bridgeVLAN101 name=dhcp1
add address-pool=dhcp_pool8 disabled=no interface=bridgeVLAN102 name=dhcp2
add bridge=bridge disabled=yes interface=wlan2
add bridge=bridgeVLAN101 interface=wlan3 multicast-router=disabled
add bridge=bridgeVLAN102 interface=wlan4 multicast-router=disabled
add bridge=bridgeVLAN101 tagged=wlan3,ether1 vlan-ids=101
add bridge=bridgeVLAN102 tagged=wlan3 untagged=ether1 vlan-ids=102
add address=> 172.16.0.1/24 > interface=bridgeVLAN101 network=172.16.0.0
add address=> 172.16.1.1/24 > interface=bridgeVLAN102 network=172.16.1.0
/ip dhcp-client
add disabled=no interface=bridgeVLAN101
/ip dns static
add action=accept chain=forward comment=“defconf: accept in ipsec policy” disabled=yes ipsec-policy=in,ipsec
add action=accept chain=forward comment=“defconf: accept out ipsec policy” disabled=yes ipsec-policy=out,ipsec
add action=fasttrack-connection chain=forward comment=“defconf: fasttrack” connection-state=established,related disabled=yes
add action=accept chain=forward comment=“defconf: accept established,related, untracked” connection-state=established,related,untracked disabled=yes
add action=drop chain=forward comment=“defconf: drop invalid” connection-state=invalid disabled=yes
add action=drop chain=forward comment=“defconf: drop all from WAN not DSTNATed” connection-nat-state=!dstnat connection-state=new disabled=yes in-interface-list=WAN
add action=masquerade chain=srcnat comment=“defconf: masquerade” ipsec-policy=out,none out-interface-list=WAN
/ip upnp
set enabled=yes
/ip upnp interfaces
/system clock
/system logging
add topics=dhcp
add topics=wireless
Thanks, started reading already. Always good to do some catch up reading, there is always something new to learn :slight_smile:
This seems to be working, I’ve two virtual wlans and I can connect on both of them getting the correct IP address assigned. This is really good. Surprised to see a complete different configuration as what I was trying to do, but happy there is something working.
There is no internet connection at the moment. But this is probably due to the fact that the switch I’m using at the moment is not configured with VLAN’s. So now I need to move the wAP to real setup and see if it is working. If it is working, I need to move this configuration into a CAPSMAN configuration :slight_smile: Thanks for the support at this moment in time.
This is the full config I’m using which is basically a copy of the config provided by ConnyMercier.
oct/29/2021 09:17:50 by RouterOS 6.48.1
add name=bridge1
/interface wireless
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-XXXX disabled=no distance=indoors frequency=auto installation=outdoor mode=ap-bridge ssid=MikroTik wireless-protocol=802.11
add disabled=no keepalive-frames=disabled mac-address=E6:8D:8C:72:D5:30 master-interface=wlan1 multicast-buffering=disabled name=wlan3 ssid=TestVLAN101 vlan-id=101 vlan-mode=use-tag wds-cost-range=0
add disabled=no keepalive-frames=disabled mac-address=E6:8D:8C:72:D5:31 master-interface=wlan1 multicast-buffering=disabled name=wlan4 ssid=TestVLAN102 vlan-id=102 vlan-mode=use-tag wds-cost-range=0
/interface vlan
/ip hotspot profile
/ip dhcp-client
/system clock
I’m having a working setup right now, this is the config:
# oct/29/2021 12:27:52 by RouterOS 6.48.1
add name=bridge1
/interface wireless
    20/40/80mhz-XXXX disabled=no distance=indoors frequency=auto \
    802.11
    TestVLAN102 vlan-id=102 vlan-mode=use-tag wds-cost-range=0 \
/interface vlan
add name=WAN
add name=VLAN
add name=dhcp_pool1 ranges=172.16.0.100-172.16.0.200
add name=dhcp_pool2 ranges=172.16.1.100-172.16.1.200
add bridge=bridge1 interface=wlan3 pvid=101
add bridge=bridge1 interface=wlan4 pvid=102
add bridge=bridge1 disabled=yes tagged=bridge1_vlan101,ether1,wlan3 vlan-ids=\
    101
add bridge=bridge1 disabled=yes tagged=bridge1_vlan102,ether1,wlan4 vlan-ids=\
    102
add interface=bridge1_vlan101 list=VLAN
add interface=bridge1_vlan102 list=VLAN
/ip dhcp-client
add address=172.16.0.0/24 dns-server=192.168.0.254 gateway=172.16.0.1 \
    netmask=24
add address=172.16.1.0/24 dns-server=192.168.0.254 gateway=172.16.1.1 \
    netmask=24
add action=accept chain=input connection-state=established,related
add action=accept chain=input in-interface-list=VLAN
add action=accept chain=forward connection-state=established,related
add action=accept chain=forward connection-state=new in-interface-list=VLAN \
/system clock
Vlans are not bridge ports.
Ether ports and WLAN port Are bridge interfaces…
Is the WAPAc acting as a router or simply an access point switch?
Personally I would have three vlans and nothing dhcp related to the bridge, its confusing otherwise.
However If this is an Access Point, what is the purpose of the 192.168.88.1 network??? If its nowhere else in your network then you dont need a third subnet on this device.
Furthermore the WAPAC should have a IP address on the management VLAN.
Thanks for your feedback. Regarding your question of the wAP AC is acting as router or access point switch. To my understanding and that is how I’m using it it is an access point switch.
I agree in my test setup the 192.168.88.1 is not really required. I kept in in the test setup so that I can still make a connected to the wAP in case a make mistakes in the configuration, it happend to often that I could access the device due to a misconfiguration.
The DHCP server on my network is running on the device (Cradlepoint) responsible for the internet connection, that is where all the VLANs come together. THis device is responsible for handing out IP addresses on the network. In my test setup, I don’t have a DHCP server, that is why for now it is configured on the Mikrotik itself, but that should removed once in the final setup.
The final solution that I’m trying to build is that each wifi access points as two wlan’s and each one with its own vlan and this configuration needs to be managed from the CAPSMAN. This is what I’m trying to setup and having challenges.
So which config should be done in the CAPSMAN, this seems to be straight forward, but how does the CAPS client needs to be configured from a VLAN point of view, from a bridge point of view, etc. etc.
You have to manually configure the wired part of CAP client before CAPsMAN takes over provisioning the wireless part. CAPsMAN only does what you currently have under /interface wireless …
For testing purposes you can configure wireless part manually and transition it to CAPsMAN later. As to the wired part: did you study (thoroughly) the VLAN bible?
The wireless config shown in post #1 is almost fine (master wireless interfaces lack vlan-id=XX vlan-mode=use-tag and all wireless interfaces should be tagged member ports of bridge … tagged for corresponding VIDs that is).
It keeps driving me crazy, I don’t know what the issue is, I tried so many things. I’ve read the VLAN bible, understand all the VLANs, tagging, native VLAN, etc. etc. But still, something doesn’t make sense in my config.
I’ve connected the wAP device to a switch, that switch supports VLANs and 101 and 103 are configured with DHCP. When I connect the MacBook and configure VLAN on the MacBook I get the corresponding IP addresses assigned.
When connecting with an iPad/iPhone to the Mikrotik wifi I don’t get an IP address at all. I don’t understand why. Any suggestions on the following config:
# nov/03/2021 22:35:16 by RouterOS 6.48.1
add name=bridge1
/interface wireless
# managed by CAPsMAN
# channel: 2447/20-eC/gn(28dBm), SSID: CAPsVLAN101, local forwarding
/interface vlan
add interface=ether1 name=vlan103 vlan-id=103
/caps-man datapath
add arp=enabled bridge=bridge1 local-forwarding=yes name=DataPathVLAN101 \
add bridge=bridge1 local-forwarding=yes name=DatapathVLAN103 vlan-id=103 \
    vlan-mode=use-tag
/caps-man configuration
add datapath=DataPathVLAN101 name=CAPsVLAN101 ssid=CAPsVLAN101
add datapath=DatapathVLAN103 name=CAPsVLAN103 ssid=CAPsVLAN103
add name=WAN
add name=VLAN
add name=BASE
add name=dhcp_pool1_VLAN101 ranges=172.16.0.100-172.16.0.200
add name=dhcp_pool2_VLAN103 ranges=172.16.1.100-172.16.1.200
/caps-man manager
set enabled=yes
/caps-man provisioning
add action=create-dynamic-enabled comment="2.4 Ghz CAPS Config" \
    hw-supported-modes=gn master-configuration=CAPsVLAN101 name-format=\
    prefix-identity name-prefix=CAP- slave-configurations=CAPsVLAN103
add action=create-dynamic-enabled comment="5 Ghz CAPS Config" disabled=yes \
    hw-supported-modes=ac master-configuration=CAPsVLAN101 \
add bridge=bridge1 interface=vlan101 multicast-router=disabled
add bridge=bridge1 interface=vlan103 multicast-router=disabled
add bridge=bridge1 interface=ether1 multicast-router=disabled
add bridge=bridge1 interface=dynamic multicast-router=disabled
set discover-interface-list=all
add interface=vlan101 list=VLAN
add interface=vlan103 list=VLAN
/interface wireless cap
set caps-man-addresses=192.168.0.216 discovery-interfaces=*3E enabled=yes \
    interfaces=wlan1
add address=192.168.88.1/24 disabled=yes interface=bridge1 network=\
    192.168.88.0
add address=172.16.0.1/24 disabled=yes interface=vlan101 network=172.16.0.0
add address=172.16.1.1/24 disabled=yes interface=vlan103 network=172.16.1.0
/ip dhcp-client
add disabled=no interface=bridge1
/system clock
/system identity
set name=WIFI01-Test
