vlan and bridge and trunk question
Hi
I have a CRS328-24P-4S+
some ports I allocated to my wifi - 10.10.10.0/24
some ports I allocated to my lan - 10.10.11.0/24
I create a bridge interface - br_wifi and br_lan and then just allocated the ports to those bridges
Allow works fine.
Now I wanted to put in a switch in my garage and I want to transport the lan network and the wifi network to there.
so I setup a bond - 2 port
then I setup a new vlan 10 for wifi
I attach port vlan to br_wifi and attach vlan10 to the bonding interface
the untagged I attach to br_lan
so on the remote switch default vlan (so vlan id 1) is lan and vlan10 is wifi . and this works.
except I attached the bonding interface to br_lan, which means … that all packets go to br_lan - including vlan 10 packets. this is causing problems for my device on the remote switch on vlan 10 . because it arps back and the arp packet ends up on my bonding interface and turns up on br_lan and not for some reason on br_wifi
so arp response for 10.10.10.x comes into br_lan which is 10.10.11.0
how do i fix this.
Had a thought whilst typing this - can create a new vlan 11 and attach it to the trunk and then attach port vlan11 to br_lan … so basically stop using the default vlanid - I think that should work ..
is this the right way to do it ?
Do it the normal way - instead of your current “port-based VLAN” approach where each VLAN has a bridge of its own, use vlan-filtering=yes on a single common bridge along with the corresponding settings in /interface bridge vlan and /interface bridge port, so you will be able to connect the device in the garage using a trunk port (or a trunk bond of multiple ports)
See this post of mine and the @pcunite’s one it refers to if Mikrotik documentation is not enough to set up the above.
pcunite —> http://forum.mikrotik.com/t/using-routeros-to-vlan-your-network/126489/1
Thanks for the link. But I am a bit lost on the one bridge. on my ros box i have eth1-10 on bridge lan and on 1 bridge and eth 11-20 on bridge wifi and on 1 bridge.
forgetting about my trunk connection how i would i achieve that with just one bridge ?
thanks for that I will have a read
EDIT :
Done some reading think I might have an answer - think of the ros box more as a switch
so that means assign a pvid to all of the interface … so in my example above eth1-10 would have pvid =11 and eth11-20 would have pvid=10
then add them to the bridge with vlan filtering on !!! the careful thing to keep in mind the ip address assigned to the bridge interface might work any more - why - because of vlan filtering … tricky :slight_smile:
then add the interfaces to the bridge
then add vlan port to the bridge this is where you get your vlans so vlan port 11 will see all of eth1-10 because its vlanid 11 via the pvid .
same for pvid10
Bit of a hint for those that follow this . the issue with trump / bonding and vlan ports added to bridges is stp or one of its flavors - seems like it doesn’t breaks thing quick but over time it causes problems - slow and silent killer. More reading and more configuring for me to do !
https://www.youtube.com/watch?v=YLtGQAQ8iS0&t=1394s
Think i have it right now
so i want vlan10 and vlan11
I have bond interface so the ros box to a cisco
interface vlan 10
name wifi
interface vlan 11
name lan
ip address 192.168.11.9 255.255.255.0
interface gigabitethernet25
channel-group 1 mode auto
interface gigabitethernet26
interface Port-channel1
description ros
switchport trunk allowed vlan add 10-11
so on bonding1 I should only get vlan 10 and 11 from the cisco
strange thing is when I look at packets on bonding1 I see the packets come in with vlanid 11:7
/tool/sniffer/quick interface=bonding1 ip-address=192.168.11.9
bonding1 4.614 11 ← F8:4F:57:02:2C:2D C4:AD:34:43:55:0E 11:7 192.168.11.9:49153 192.168.10.7:53 (dns) ip:udp 91 0
bonding1 4.614 12 → C4:AD:34:43:55:0E F8:4F:57:02:2C:2D 11 192.168.10.7:53 (dns) 192.168.11.9:49153 ip:udp 198 0
bonding1 4.619 13 ← F8:4F:57:02:2C:2D C4:AD:34:43:55:0E 11:7 192.168.11.9:49153 192.168.10.3:53 (dns) ip:udp 91 0
bonding1 4.62 14 ← F8:4F:57:02:2C:2D C4:AD:34:43:55:0E 11:7 192.168.11.9:49153 192.168.10.3:53 (dns) ip:udp 91 0
add comment=“New Bridge - one bridge to rule them all - per the doco for vlans and bridges” ingress-filtering=no name=newBridge pvid=8 vlan-filtering=yes
add bridge=newBridge comment=“new bridge link” interface=bonding1
add bridge=newBridge comment="This interface list includes all the ports that are part of the WAN link - NBN " interface=int_list_wan pvid=255
add bridge=newBridge tagged=bonding1 vlan-ids=10
add bridge=newBridge tagged=bonding1 vlan-ids=11
I’m not sure why the incoming packets show up as vlan 11:7 … so it works as long as i turn off ingress filtering … I presume it filters the packets because 11:7 doesn’t match any of the vlans i have attached to the bridge
No, 11:7 is VLAN ID 11 with priority 7.
You are missing the bridge-to-CPU interface in the bridge VLAN membership:
add bridge=newBridge tagged=newBridge,bonding1 vlan-ids=10
add bridge=newBridge tagged=newBridge,bonding1 vlan-ids=11
Okay, great thanks that seems to be working - but I am not 100% sure why i need it - I thought by adding the vlan port off the bridge it makes the bridge process those vlans … I’m guessing in all my reading i just overlooked it
can you explain why you would ever want a bridge with out a cpu bridge port ? and if not why not make it automatic
last extra question why are my native ethX port shown as hardware switched, but my bonding interface isn’t ?
priority - who sets that and where and priority for what ?
An /interface vlan object merely inserts the specfied VLAN tag for packets on ingress and removes them on egress.
When configuring a Mikrotik device as a switch you may have various untagged and tagged VLANs configured on several ports, but only a single VLAN configured to transit the bridge-to-CPU port for management access to the device.
The VLAN management is currently being reworked so in future adding an /interface vlan to a bridge will automatically add the bridge-to-CPU port as a dynamic entry under /interface bridge vlan. In the meantime http://forum.mikrotik.com/t/routeros-bridge-mysteries-explained/147832/1 written by @sindy is a good explanation.
How have you configured your bond? Only 802.3ad and balance-xor bonding modes are hardware offloaded, other modes will use the CPU’s resources. The built-in switch chip will always use Layer2+Layer3+Layer4 for a transmit hash policy, changing the transmit hash policy manually will have no effect. See https://help.mikrotik.com/docs/display/ROS/CRS3xx,+CRS5xx,+CCR2116,+CCR2216+switch+chip+features#CRS3xx,CRS5xx,CCR2116,CCR2216switchchipfeatures-Bonding
/interface bonding
add mode=802.3ad name=bonding1 slaves=ether23,ether24
Thought I had this solved but - still not working - properly, I have an old setup I am trying to move to the proper way to setup and things are break as I move them !
I have a bridge br_wifi - this has all of the ports associated with wifi network and a br_lan all of the ports on the LAN
I am trying to create a single bridge with vlan filter
new_bridge and with 4 vlans configured against it
vlan8
vlan9
vlan10
vlan11
what I have done is added vlan11 interface as a port to bridge br_lan and vlan10 interface as a bridge port to br_wifi
from an ip on br_wifi I can ping a device on other end of my newbridge / bond port.
192.168.10.7 → goes to a switch that connect to the crs on ether12
ether12 is bridge port on br_wifi - no pvid so the default of 1 (this is old)
192.168.10.1 is attached to br_wifi
it gets routed via br_lan 192.168.11.1
br_lan has vlan11 as a bridge port
vlan11 is vlan11 attached to newbridge
bonding (802.3d)
newbridge has its self vlan11 bonding1
packet leaves on bonding1
so the link from 192.168.10.0/24 via crs to 192.168.11.0/24 (not all of 192.168.11.0/24 is on bonding ) is working
packet capture on all interfaces
ether12    8.996   99  <-   2C:CF:67:2C:7F:18  C4:AD:34:43:55:00        192.168.10.7  192.168.11.9  ip:icmp     98    0
br_wifi    8.996  100  <-   2C:CF:67:2C:7F:18  C4:AD:34:43:55:00        192.168.10.7  192.168.11.9  ip:icmp     98    0
br_lan     8.996  101  ->   C4:AD:34:43:55:0E  F8:4F:57:02:2C:2D        192.168.10.7  192.168.11.9  ip:icmp     98    0
vlan11     8.996  102  ->   C4:AD:34:43:55:0E  F8:4F:57:02:2C:2D        192.168.10.7  192.168.11.9  ip:icmp     98    0
newBridge  8.996  103  ->   C4:AD:34:43:55:0E  F8:4F:57:02:2C:2D  11    192.168.10.7  192.168.11.9  ip:icmp    102    0
bonding1   8.996  104  ->   C4:AD:34:43:55:0E  F8:4F:57:02:2C:2D  11    192.168.10.7  192.168.11.9  ip:icmp    102    0
ether24    8.996  105  ->   C4:AD:34:43:55:0E  F8:4F:57:02:2C:2D  11    192.168.10.7  192.168.11.9  ip:icmp    102    0
ether24    8.997  106  <-   F8:4F:57:02:2C:2D  C4:AD:34:43:55:0E  11:7  192.168.11.9  192.168.10.7  ip:icmp    102    0
bonding1   8.997  107  <-   F8:4F:57:02:2C:2D  C4:AD:34:43:55:0E  11:7  192.168.11.9  192.168.10.7  ip:icmp    102    0
newBridge  8.997  108  <-   F8:4F:57:02:2C:2D  C4:AD:34:43:55:0E  11:7  192.168.11.9  192.168.10.7  ip:icmp    102    0
vlan11     8.997  109  <-   F8:4F:57:02:2C:2D  C4:AD:34:43:55:0E        192.168.11.9  192.168.10.7  ip:icmp     98    0
br_lan     8.997  110  <-   F8:4F:57:02:2C:2D  C4:AD:34:43:55:0E        192.168.11.9  192.168.10.7  ip:icmp     98    0
br_wifi    8.997  111  ->   C4:AD:34:43:55:00  2C:CF:67:2C:7F:18        192.168.11.9  192.168.10.7  ip:icmp     98    0
ether12    8.997  112  ->   C4:AD:34:43:55:00  2C:CF:67:2C:7F:18        192.168.11.9  192.168.10.7  ip:icmp     98    0
this is from a device on br_lan but directly connected to crs - so into the crs in br_lan to newbridge then out bonding0
ether21    8.487    1  <-   DC:A6:32:D4:FA:A7  F8:4F:57:02:2C:2D        192.168.11.3  192.168.11.9  ip:icmp     98    0
vlan11     8.487    2  ->   DC:A6:32:D4:FA:A7  F8:4F:57:02:2C:2D        192.168.11.3  192.168.11.9  ip:icmp     98    0
newBridge  8.487    3  ->   DC:A6:32:D4:FA:A7  F8:4F:57:02:2C:2D  11    192.168.11.3  192.168.11.9  ip:icmp    102    0
bonding1   8.487    4  ->   DC:A6:32:D4:FA:A7  F8:4F:57:02:2C:2D  11    192.168.11.3  192.168.11.9  ip:icmp    102    0
ether23    8.487    5  ->   DC:A6:32:D4:FA:A7  F8:4F:57:02:2C:2D  11    192.168.11.3  192.168.11.9  ip:icmp    102    0
ether24    8.489    6  <-   F8:4F:57:02:2C:2D  DC:A6:32:D4:FA:A7  11:7  192.168.11.9  192.168.11.3  ip:icmp    102    0
bonding1   8.489    7  <-   F8:4F:57:02:2C:2D  DC:A6:32:D4:FA:A7  11:7  192.168.11.9  192.168.11.3  ip:icmp    102    0
newBridge  8.489    8  <-   F8:4F:57:02:2C:2D  DC:A6:32:D4:FA:A7  11:7  192.168.11.9  192.168.11.3  ip:icmp    102    0
vlan11     8.489    9  <-   F8:4F:57:02:2C:2D  DC:A6:32:D4:FA:A7        192.168.11.9  192.168.11.3  ip:icmp     98    0
ether21    8.489   10  ->   F8:4F:57:02:2C:2D  DC:A6:32:D4:FA:A7        192.168.11.9  192.168.11.3  ip:icmp     98    0
My problem is that currently I have 192.168.11.1 DGW for br_lan on br_lan, I want to move it to vlan11 interface
add address=192.168.11.1/24 comment=“LAN network DGW” interface=br_lan network=192.168.11.0
when i change the interface onto vlan11 then devices on vlan11 can’t arp it, I can see the arp request coming in vlan11 interface but doesn’t work
it could be the arp cache I presume when i move the ip it gets a new mac …
Seems like it was a firewall issues - fix that it and its working as advertised
