I have the following config:
Eth1 connected to provider with 3 subnets active.
Sub1 - has host ip assigned at MT router, handles some BGP routes, ipsec vpn, etc.
Sub2 - is a /30 with 1 host at the provider, and the other running on an internal switch on vlan 4 of eth2. I have placed a vlan4 virtual interface on eth2, and put it in a bridge with eth1 - this works fine.
Sub3 - is an additional /30 setup with the provider as sub2 is. Internal host is on the same internal switch on vlan5 connected to MT router on the same eth2. When I add the vlan5 virtual interface on eth2 to the same bridge as eth1 and the vlan4 virtual interface handling vlan4..I lose external connectivity to the internal host on vlan4.
I’m hoping someone can explain why this is occuring. I’m considering reconfiguring the switch so both /30 subs run on vlan 4, but that doesn’t seem ideal. I have no control over external config for these subnets.
EDIT: Sorry, I intended to post diagram / config sooner. The relevant config + network topology is below.
Connectivity to “SERVER 1” in the diagram is lost when this bridge port is enabled:
add bridge=bridgeVLAN4-VLAN5 disabled=yes interface=vlan5
Config snippets:
/interface vlan
add interface=eth2 loop-protect=on name=vlan4 vlan-id=4
add interface=eth2 loop-protect=on name=vlan5 vlan-id=5
add address=[sub1.host2IP]/29 disabled=yes interface=eth1 network=[sub1]/29
add name=bridgeVLAN4-VLAN5
add bridge=bridgeVLAN4-VLAN5 hw=no interface=eth1
add bridge=bridgeVLAN4-VLAN5 interface=vlan4
