VLAN no IP via DHCP
I am new to RouterOS and am trying to physically separate two networks with VLANs.
The goal is to later provide separate networks for different apartments (guests), which all use the same internet connection. I have decided to work with VLANs to separate the networks cleanly and securely.
Now I have started to set up a simple test scenario to familiarise myself with the topic of VLANs.
I have read various tutorials and watched YouTube videos, but the configuration options seem to be complex.
I am using an RB2011iL-RM.
APs and clients are to be connected directly to this device.
There are no other switches or similar.
I would like to map the following test scenario:
Port 3, 4 → no VLAN, but a common IP range via DHCP.
Port 5, 6, 7 → VLAN ID 10 (Private) and a shared IP range via DHCP.
Port 8, 9, 10 → VLAN ID 45 (Guest) and a shared IP range via DHCP
In my configuration I have set up bridges for ports 3,4 // 5,6,7 and 8,9,10.
In the Interfaces → VLANs section I have defined VLANs for Private (ID10) and Guest (ID45) and assigned them to the bridge interfaces.
Under IP → Addresses I have configured the corresponding addresses and assigned them to the VLAN interfaces, or for port 3,4 to the bridge.
DHCP with address ranges is configured and assigned to the VLAN interfaces.
The DHCP for port 3,4 is assigned to the bridge.
Now I get an IP from the DHCP with my Windows client when I connect to port 3 or port 4. Very good!
If I connect my Windows client to one of the ports that are assigned to a VLAN, I do not get an IP address from the DHCP.
This is where I need help. What is wrong with my configuration?
I have read that ports to which clients are to be directly connected must be “untaged”.
Then I also created the VLANs in the Bridges → VLAN area and the corresponding ports as “untaged”.
Unfortunately without success. I am grateful for any tips at this point.
Greetings
# sep/30/2022 19:44:36 by RouterOS 7.4.1
# software id = 7V5K-7VZN
# model = RB2011iL
add frame-types=admit-only-untagged-and-priority-tagged ingress-filtering=no \
    name=bridge-Guest pvid=45 vlan-filtering=yes
add admin-mac=18:FD:74:19:40:D1 auto-mac=no name=bridge-Other
    name=bridge-Private pvid=10 vlan-filtering=yes
/interface vlan
add interface=bridge-Private name=vlan-10-Private vlan-id=10
add interface=bridge-Guest name=vlan-45-Guest vlan-id=45
add name=DHCP-Pool-Other ranges=192.168.88.50-192.168.88.200
add name=DHCP-Pool-Private ranges=192.168.10.50-192.168.10.200
add name=DHCP-Pool-Guest ranges=192.168.45.50-192.168.45.200
add address-pool=DHCP-Pool-Other interface=bridge-Other name=DHCP-Other
add address-pool=DHCP-Pool-Private interface=vlan-10-Private name=\
    DHCP-Private
add address-pool=DHCP-Pool-Guest interface=vlan-45-Guest name=DHCP-Guest
add bridge=bridge-Other comment=defconf interface=ether4
add bridge=bridge-Other interface=ether3
add bridge=bridge-Private interface=ether5
add bridge=bridge-Private interface=ether6
add bridge=bridge-Private interface=ether7
add bridge=bridge-Guest interface=ether8
add bridge=bridge-Guest interface=ether9
add bridge=bridge-Guest interface=ether10
set discover-interface-list=LAN-Privat
/interface bridge vlan
add bridge=bridge-Private untagged=ether5,ether6,ether7 vlan-ids=10
add bridge=bridge-Guest untagged=ether8,ether9,ether10 vlan-ids=45
add address=192.168.88.1/24 interface=bridge-Other network=192.168.88.0
add address=192.168.10.1/24 interface=vlan-10-Private network=192.168.10.0
add address=192.168.45.1/24 interface=vlan-45-Guest network=192.168.45.0
/ip dhcp-client
add address=192.168.10.0/24 dns-none=yes gateway=192.168.10.1
add address=192.168.45.0/24 dns-none=yes gateway=192.168.45.1
add address=192.168.88.0/24 dns-none=yes gateway=192.168.88.1
set allow-remote-requests=yes
/ip dns static
/ipv6 firewall address-list
/ipv6 firewall filter
    established,related,untracked
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
    33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN-Privat
    connection-state=invalid
    icmpv6
    500,4500 protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN-Privat
/tool mac-server
set allowed-interface-list=LAN-Privat
/tool mac-server mac-winbox
The Mikrotik VLAN setup does have a steep learning curve, and it isn’t helped by various changes which have been made to RouterOS over the years - historically you had to use a bridge per network/VLAN until VLAN-aware bridges were introduced.
The main issue with your setup is you have configured the bridge-to-CPU interfaces to be untagged by using the bridge pvid= setting, but also attaching a VLANs with the same ID to the bridge interfaces.
In most cases the current recommended method is to use a single VLAN-aware bridge, unfortunately there are many blogs and videos on the internet which use the old method, are incomplete, or just wrong. There is an excellent post http://forum.mikrotik.com/t/using-routeros-to-vlan-your-network/126489/1 and the documentation https://help.mikrotik.com/docs/display/ROS/Bridging+and+Switching#BridgingandSwitching-BridgeVLANFiltering as a starting point, plus http://forum.mikrotik.com/t/routeros-bridge-mysteries-explained/147832/1 explaining the multiple personalities a Mikrotik bridge has.
Hey thanks a lot for your answer,
Today I looked into the topic a bit more and also noticed that the Mikrotik tutorials all just create a bridge and define the VLANs in it.
I looked at the example “Router-Switch-AP (all in one)” and reduced the complexity to an absolute minimum - in my opinion.
No wireless, no firewall, only 2 ports, 2 VLANs, 2 DHCP servers.
But without success :frowning:
I reset the configuration of my router and created the following settings based on the example - just for testing.
I do not get an IP with my Windows client on ports 6 and 7 via the DHCP…
# create one bridge, set VLAN mode off while we configure
/interface bridge add name=BR1 protocol-mode=none vlan-filtering=no
# ingress behavior
# Blue VLAN
add bridge=BR1 interface=ether6 pvid=80
# Green VLAN
add bridge=BR1 interface=ether7 pvid=90
# L3 switching so Bridge must be a tagged member
set bridge=BR1 tagged=BR1 [find vlan-ids=80]
set bridge=BR1 tagged=BR1 [find vlan-ids=90]
# Blue VLAN interface creation, IP assignment, and DHCP service
/interface vlan add interface=BR1 name=BLUE_VLAN vlan-id=80
/ip address add interface=BLUE_VLAN address=10.0.10.1/24
/ip pool add name=BLUE_POOL ranges=10.0.10.2-10.0.10.254
/ip dhcp-server add address-pool=BLUE_POOL interface=BLUE_VLAN name=BLUE_DHCP disabled=no
/ip dhcp-server network add address=10.0.10.0/24 dns-server=192.168.0.1 gateway=10.0.10.1
# Green VLAN interface creation, IP assignment, and DHCP service
/interface vlan add interface=BR1 name=GREEN_VLAN vlan-id=90
/ip address add interface=GREEN_VLAN address=10.0.20.1/24
/ip pool add name=GREEN_POOL ranges=10.0.20.2-10.0.20.254
/ip dhcp-server add address-pool=GREEN_POOL interface=GREEN_VLAN name=GREEN_DHCP disabled=no
/ip dhcp-server network add address=10.0.20.0/24 dns-server=192.168.0.1 gateway=10.0.20.1
# Only allow ingress packets without tags on Access Ports
set bridge=BR1 ingress-filtering=yes frame-types=admit-only-untagged-and-priority-tagged [find interface=ether6]
set bridge=BR1 ingress-filtering=yes frame-types=admit-only-untagged-and-priority-tagged [find interface=ether7]
# Turn on VLAN mode
/interface bridge set BR1 vlan-filtering=yes
# jan/02/1970 00:06:44 by RouterOS 7.4.1
# model = RB2011iL
add name=BR1 protocol-mode=none vlan-filtering=yes
/interface vlan
add bridge=BR1 frame-types=admit-only-untagged-and-priority-tagged interface=\
    ether6 pvid=80
    ether7 pvid=90
add address=10.0.10.1/24 interface=BLUE_VLAN network=10.0.10.0
add address=10.0.20.1/24 interface=GREEN_VLAN network=10.0.20.0
It looks as though when @pcunite reworked the Router-Switch-AP config some errors crept in as
only works if the bridge VLANs already exist. If you add the following to your configuration it should fix it:
add bridge=BR1 tagged=BR1 vlan-ids=80
add bridge=BR1 tagged=BR1 vlan-ids=90
Hey,
Thanks a lot for your help! It works.
Now I get an IP from DHCP on the VLAN ports - perfect!
I will now continue testing and transfer the configuration to my planned network.
Thank you very much and have a nice Saturday!
Yes, many are incomplete or just wrong, INCLUDING THIS ONE. Oh the irony.
I would dispute the use of “most cases” too.
Do not use a single VLAN-aware bridge on a 2011. Performance is crap as everything goes through the CPU.
You need to use the switch chip config. on this device.
If the majority of the traffic will undergo NAT or routing then the additional CPU load of VLAN-aware bridging is minimal. Using the switch chips only has a benefit for traffic between ports in the same VLAN, e.g. between a PC and NAS, other than on the very recent models which support L3 hardware offloading. A 2011 should be able to route/NAT around 200-250Mbps.
Also Mikrotiks with multiple switch ports have other issues if you wish to have a VLAN spanning the two switch chips https://wiki.mikrotik.com/wiki/Manual:Layer2_misconfiguration#VLAN_filtering_with_multiple_switch_chips
It is not an error but uses syntax that is confusing to the beginner is all.
The fact of the matter is that, practically speaking, every vlan pvid has to be tagged to at least one interface on a conf and if not, then has to be tagged to the bridge.
http://forum.mikrotik.com/t/vlans-via-bridge-working-but-still-confused/160676/3
For the @OP, if you post your complete config minus serial number and any public WANIP info, will have a look.
Hey,
thanks for the further input.
I have completed my configuration further.
It is not yet productive, the Mikrotik is currently still behind my FritzBox. I’m still testing.
The performance issue sounds interesting.
Currently I “only” have a 50Mbit connection to which all apartments / residents with a FritzBox guest access are connected.
I hope to have a 500Mbit fibre connection this year. Each apartment will then have its own AccessPoint. In addition, with a limit of 100/20Mbit, so that one resident cannot use the entire bandwidth.
The private VLAN should have full bandwidth available.
No traffic is planned between the individual VLANs. The networks should be cleanly and securely separated from each other.
I only want to be able to access the APs of the guests from the private VLAN for configuration purposes, if necessary.
Here is my current configuration:
# oct/02/2022 22:53:41 by RouterOS 7.4.1
# model = RB2011iL
add admin-mac=18:FD:74:19:40:D1 auto-mac=no comment=defconf name=\
    bridge-Backupzugang
add ingress-filtering=no name=bridge-VLAN vlan-filtering=yes
/interface vlan
add interface=bridge-VLAN name=vlan-10-WG1 vlan-id=10
add interface=bridge-VLAN name=vlan-20-WG2 vlan-id=20
add interface=bridge-VLAN name=vlan-40-WG4a vlan-id=40
add interface=bridge-VLAN name=vlan-45-WG4b vlan-id=45
add interface=bridge-VLAN name=vlan-60-WG6 vlan-id=60
add interface=bridge-VLAN name=vlan-100-Private vlan-id=100
add interface=bridge-VLAN name=vlan-200-Homeatic vlan-id=200
add name=WAN
add name=LAN-Privat
add name=LAN-Mieter
add name=LAN-Internetzugang
add name=DHCP-Pool-Backupzugang ranges=192.168.88.50-192.168.88.200
add name=DHCP-Pool-Private ranges=192.168.100.50-192.168.100.200
add name=DHCP-Pool-WG1 ranges=192.168.10.50-192.168.10.200
add name=DHCP-Pool-WG2 ranges=192.168.20.50-192.168.20.200
add name=DHCP-Pool-WG4a ranges=192.168.40.50-192.168.40.200
add name=DHCP-Pool-WG4b ranges=192.168.45.50-192.168.45.200
add name=DHCP-Pool-WG6 ranges=192.168.60.50-192.168.60.200
add name=DHCP-Pool-Homeatic ranges=192.168.200.50-192.168.200.200
add address-pool=DHCP-Pool-Backupzugang interface=bridge-Backupzugang name=\
    DHCP-Backupzugang
add address-pool=DHCP-Pool-Private interface=vlan-100-Private lease-time=1d \
    name=DHCP-Private
add address-pool=DHCP-Pool-WG1 interface=vlan-10-WG1 name=DHCP-WG1
add address-pool=DHCP-Pool-WG2 interface=vlan-20-WG2 name=DHCP-WG2
add address-pool=DHCP-Pool-WG4a interface=vlan-40-WG4a name=DHCP-WG4a
add address-pool=DHCP-Pool-WG4b interface=vlan-45-WG4b name=DHCP-WG4b
add address-pool=DHCP-Pool-WG6 interface=vlan-60-WG6 name=DHCP-WG6
add address-pool=DHCP-Pool-Homeatic interface=vlan-200-Homeatic name=\
    DHCP-Homeatic
/queue simple
add max-limit=5M/20M name=queue-Limit4b target=vlan-45-WG4b
add max-limit=20M/98M name=queue-Limit4a target=vlan-40-WG4a
add max-limit=20M/98M name=queue-Limit1 target=vlan-10-WG1
add max-limit=20M/98M name=queue-Limit2 target=vlan-20-WG2
add max-limit=20M/98M name=queue-Limit6 target=vlan-60-WG6
add bridge=bridge-Backupzugang comment=defconf interface=ether4
add bridge=bridge-VLAN frame-types=admit-only-untagged-and-priority-tagged \
    interface=ether5 pvid=100
    interface=ether6 pvid=10
    interface=ether7 pvid=20
    interface=ether8 pvid=40
    interface=ether9 pvid=45
    interface=ether10 pvid=60
    interface=ether3 pvid=200
add bridge=bridge-VLAN tagged=bridge-VLAN vlan-ids=10
add bridge=bridge-VLAN tagged=bridge-VLAN vlan-ids=20
add bridge=bridge-VLAN tagged=bridge-VLAN vlan-ids=40
add bridge=bridge-VLAN tagged=bridge-VLAN vlan-ids=45
add bridge=bridge-VLAN tagged=bridge-VLAN vlan-ids=60
add bridge=bridge-VLAN tagged=bridge-VLAN vlan-ids=100
add bridge=bridge-VLAN tagged=bridge-VLAN vlan-ids=200
add independent-learning=no ports=ether5 switch=switch1 vlan-id=100
add interface=bridge-Backupzugang list=LAN-Privat
add interface=ether1 list=WAN
add interface=ether2 list=WAN
add interface=vlan-100-Private list=LAN-Privat
add interface=vlan-10-WG1 list=LAN-Mieter
add interface=vlan-20-WG2 list=LAN-Mieter
add interface=vlan-40-WG4a list=LAN-Mieter
add interface=vlan-45-WG4b list=LAN-Mieter
add interface=vlan-60-WG6 list=LAN-Mieter
add interface=bridge-Backupzugang list=LAN-Internetzugang
add interface=vlan-10-WG1 list=LAN-Internetzugang
add interface=vlan-20-WG2 list=LAN-Internetzugang
add interface=vlan-40-WG4a list=LAN-Internetzugang
add interface=vlan-45-WG4b list=LAN-Internetzugang
add interface=vlan-60-WG6 list=LAN-Internetzugang
add interface=vlan-100-Private list=LAN-Internetzugang
add address=192.168.88.1/24 comment=defconf interface=bridge-Backupzugang \
add address=192.168.100.1/24 interface=vlan-100-Private network=192.168.100.0
add address=192.168.10.1/24 interface=vlan-10-WG1 network=192.168.10.0
add address=192.168.20.1/24 interface=vlan-20-WG2 network=192.168.20.0
add address=192.168.40.1/24 interface=vlan-40-WG4a network=192.168.40.0
add address=192.168.45.1/24 interface=vlan-45-WG4b network=192.168.45.0
add address=192.168.60.1/24 interface=vlan-60-WG6 network=192.168.60.0
add address=192.168.200.1/24 interface=vlan-200-Homeatic network=\
    192.168.200.0
/ip dhcp-client
add address=192.168.10.0/24 dns-server=192.168.10.1 gateway=192.168.10.1
add address=192.168.20.0/24 dns-server=192.168.20.1 gateway=192.168.20.1
add address=192.168.40.0/24 dns-server=192.168.40.1 gateway=192.168.40.1
add address=192.168.45.0/24 dns-server=192.168.45.1 gateway=192.168.45.1
add address=192.168.60.0/24 dns-server=192.168.60.1 gateway=192.168.60.1
add address=192.168.88.0/24 dns-server=192.168.88.1 gateway=192.168.88.1
add address=192.168.100.0/24 dns-server=192.168.100.1 gateway=192.168.100.1 \
    netmask=24
add address=192.168.200.0/24 dns-server=192.168.200.1 gateway=192.168.200.1
/ip dns static
/ip firewall address-list
add address=192.168.10.0/24 list=Router_IPs
add address=192.168.20.0/24 list=Router_IPs
add address=192.168.40.0/24 list=Router_IPs
add address=192.168.45.0/24 list=Router_IPs
add address=192.168.60.0/24 list=Router_IPs
add address=192.168.100.0/24 list=Router_IPs
add address=192.168.200.0/24 list=Router_IPs
add address=192.168.88.0/24 list=Router_IPs
add address=192.168.10.0/24 list=GastAP_IPs
add address=192.168.20.0/24 list=GastAP_IPs
add address=192.168.40.0/24 list=GastAP_IPs
add address=192.168.45.0/24 list=GastAP_IPs
add address=192.168.60.0/24 list=GastAP_IPs
add action=drop chain=input comment="WAN -> Router | Ping verbieten" \
    in-interface-list=WAN protocol=icmp
    "Allg. | aufgebaute Verbindung erlauben" connection-state=\
    established,related
add action=accept chain=input comment="Allg. | DNS erlauben" \
    dst-address-list=Router_IPs dst-port=53 protocol=udp
    dst-address-list=Router_IPs dst-port=53 protocol=tcp
    "LAN-Privat -> Router | Zugriff auf Router erlauben" in-interface-list=\
    LAN-Privat
    "Allg. | Verbindung ohne Verbindungsstatus verbieten"
    "Allg. | Aufgebaute Verbindung erlauben"
    "LAN Privat -> LAN-Mieter | Zugriff auf APs erlauben" dst-address-list=\
    GastAP_IPs in-interface-list=LAN-Privat
    "LAN -> WAN | Internetzugang erlauben" in-interface-list=\
    LAN-Internetzugang out-interface-list=WAN
add action=drop chain=forward comment="Allg. | Alles verbieten"
    in-interface-list=WAN protocol=icmpv6
    established,related
add action=accept chain=input comment="WAN -> Router | DHCP f\FCr Router" \
    dst-port=546 in-interface-list=WAN protocol=udp src-port=547
add action=drop chain=input comment="Allg. | ung\FCltige Pakete verwerfen" \
    "WAN -> Router | externen Verbindungsaufbau verwerfen" connection-state=\
    new in-interface-list=WAN
    "Allg. | aufgebaute PING Verbindungen erlauben" protocol=icmpv6
    established,related
add action=accept chain=forward comment="Allg. | Neue Verbindbung erlauben" \
    connection-state=new in-interface-list=LAN-Internetzugang
add action=drop chain=forward comment="Allg. | ung\FCltige Pakete verwerfen" \
add action=drop chain=forward comment="WAN -> Router | neue Pakete verwerfen" \
/system clock
/tool mac-server
(1) Recommend one bridge, thus take your backupzugang access on ether4, OFF any bridge. Remove it, the dhcp server, the IP pool etc.., all not needed.
Simply have the IP address only. Then you can plug in your latpop at any time to access the router using an IPV4 address on the pc network, ethernet card settings.
Just use 192.168.88.x to access the router, I typically use .5.
This will simplify your config as it gets confusing with extra noise and what looks like a second management vlan or bridge, which it is NOT.
One also removes ether4 from the bridge, so that you have off bridge access that will not be affected by the bridge if it stops working!
(2) Your iP neighbours discovery is for all smart devices that you need to configure beyond the router, so any other devices like smart switches or smart APs…
Therefore the rule you have is the right one!! (privat in your case means trusted subnet aka your management vlan)
(3) All the /interface bridge vlan settings are fine, I just prefer to manually insert the untagging so I can confirm with my /interface bridge port settings. incorrect.
(4) What is the purpose of this, its in conflict with your /interface bridge port settings for ether5 ???
Remove it!!!
(5) YOur interface list membership is BLOATED… Lets cut the fat.
add interface=bridge-Backupzugang list=LAN-Internetzugang NOT REQUIRED>
Instead just put ether4 on the Private LAN as a member.
There is no difference between your two lists now. The groups are identical for lan and internet and therefore we will get rid of the internet one…
It appears you have vlan200 going on ether3, but its not part of any interface, so we will see how that works out.
Also add private vlan to lan-metier, so it can be included in like rules. ( for internet etc.)
(5) Its actually better to allow ICMP, who told you to block it??
From: add action=drop chain=input comment=“WAN → Router | Ping verbieten”
TO:
add action=accept chain=input comment=“allow ping of router” protocol=icmp
(6) The first rule in your forward chain makes no sense. REMOVE IT… It allows all access from anywhere to anywhere.
“Allg. | Aufgebaute Verbindung erlauben”
(7) Instead put these as your first three rules in the forward chain!
add action=fasttrack-connection chain=forward comment=“defconf: fasttrack” connection-state=established,related
add action=accept chain=forward comment=“defconf: accept established,related, untracked” connection-state=established,related,untracked
add action=drop chain=forward comment=“defconf: drop invalid” connection-state=invalid
(8) The next two rules concern allowing the private lan access to all vlans except v200, and all vlans access to internet except v200
“LAN Privat → all guest vlans except 200” dst-address-list=
"LAN → WAN | all vlans except 200 " in-interface-list=
LAN-Mieter out-interface-list=WAN
You could uses LAN-metier for the first one (out interface list) as there is no harm if v100 is on the same list) and that way you could get rid of the firewall address list gast-aps.
(9) Set to NONE, mac by itself is not encrypted at all.
/tool mac-server
A fixed config is provided…
# model = RB2011iL
/interface vlan
add name=WAN
add name=LAN-Privat
add name=LAN-Mieter
    name=DHCP-Private
    DHCP-Homeatic
/queue simple
add bridge=bridge-VLAN tagged=bridge-VLAN untagged=ether5 vlan-ids=100
add bridge=bridge-VLAN tagged=bridge-VLAN untagged=ether6 vlan-ids=10
add bridge=bridge-VLAN tagged=bridge-VLAN untagged=ether7 vlan-ids=20
add bridge=bridge-VLAN tagged=bridge-VLAN untagged=ether8 vlan-ids=40
add bridge=bridge-VLAN tagged=bridge-VLAN untagged=ether9 vlan-ids=45
add bridge=bridge-VLAN tagged=bridge-VLAN untagged=ether10 vlan-ids=60
add bridge=bridge-VLAN tagged=bridge-VLAN untagged=ether3 vlan-ids=200
add interface=ether4 list=LAN-Privat
add interface=vlan-100-Private list=LAN-Private
add interface=vlan-100-Private list=LAN-Mieter
    192.168.200.0
/ip dhcp-client
    netmask=24
/ip dns static
add action=accept chain=input comment="allow ping" protocol=icmp
    LAN-Privat
    "LAN Privat -> all guest vlans except 200" out-interface-list=\
    LAN-Metier in-interface-list=LAN-Privat
    "LAN -> WAN | all vlans except 200" in-interface-list=\
    LAN-Metier out-interface-list=WAN
/system clock
/tool mac-server
set allowed-interface-list=NONE
Hey,
thanks for your input.
Yes indeed, some things can still be simplified.
It’s always good to have someone else take a look at the configuration.
I will take a look at your input this evening and implement it.
Since there was already talk of performance problems here, I did some googling last night.
We will get a 500MBit connection in the course of the year. Do I understand correctly that the RB2011 with NAT and firewall will not be able to use this bandwidth? I read something that a maximum of 250 - 300 MBit would be possible?
Haha, asking me that is funny question…It depends who you talk to. Recently some folks were espousing its capabilities if not using filters or queues or anything just fastpath alone. That describes maybe 1% of people, then throw in the fact that your asking people to throw money at an old 1 core CPU…makes one scratch their head, probably down to .01%. They clearly have a tenuous grip on reality :slight_smile: and they whine a lot.
For your normal and practical concerns, the clear answer is no. A hex would do the job but you are used to many ports on the router.
An RB4011 would be a good starting place but that is getting a bit old and for the same price, the RB5009 is a better product. Depends upon availability more than anything else.
Check in your area with distributors on lead times…
This help me A LOT!!
Finally it’s working.
Big Thank You!!! :smiley:
