I have a VRF where WAN 1 is the primary connection and LTE is the backup.
I need both connections to be in the VRF. The issue is that the gateway check does not seem to work correctly in this setup.
When WAN 1 goes down, the router does not automatically switch to LTE. I have to manually change the route.
I know the same setup works fine in the main routing table, but it does not work properly when the routes are in a VRF.
[CPE1] > interface/ethernet/pr
;;; LAN
0 R ether1 1500 enabled switch1
;;; WAN-1
2 ether3 1500 enabled switch1
[CPE01] > ip route/pr de where routing-table=vrf1
0 s dst-address=0.0.0.0/0 routing-table=vrf1 gateway=1.1.1.1 immediate-gw=1.1.1.1%lte1 check-gateway=ping distance=2 scope=30 target-scope=46
1 As dst-address=0.0.0.0/0 routing-table=vrf1 gateway=8.8.8.8 immediate-gw=8.8.8.8%lte1 check-gateway=ping distance=20 scope=30 target-scope=41
2 As dst-address=1.1.1.1/32 routing-table=vrf1 gateway=lte1 immediate-gw=lte1 distance=1 scope=30 target-scope=10
3 Is dst-address=8.8.8.8/32 routing-table=vrf1 gateway=1.2.3.4 immediate-gw="" distance=1 scope=30 target-scope=10
You should also post the print output of the main routing table. My guess is that currently in the main table, you have some route that can be used for 8.8.8.8 that actively resolves to lte1 as gateway. Even when that route has a high scope (default is 30), it will be picked up by this route entry:
for looking up the gateway 8.8.8.8, because you did not specify 8.8.8.8@vrf1, and because target-scope=41. As a result, you can see immediate-gw=8.8.8.8%lte1 attached to that route.
[CPE01] > ip route/pr detail where dst-address=0.0.0.0/0
DAm dst-address=0.0.0.0/0 routing-table=main gateway=lte1 immediate-gw=lte1
distance=2 scope=30 target-scope=10
The main WAN interface is currently down, and everything has been switched over to LTE.
I think this is only happening with LTE. I’m pretty sure the WAN was working fine, as I have several setups where this works without any issues. Something seems to be related to the LTE, but I can’t figure out what the issue is.
ip route/pr detail where routing-table=vrf1
Flags: A - ACTIVE; s - STATIC
0 As dst-address=0.0.0.0/0 routing-table=vrf1 gateway=8.8.8.8 immediate-gw=10.0.1.1%e3vl99 distance=1 scope=10 target-scope=30
1 As dst-address=8.8.8.8/32 routing-table=vrf1 gateway=10.0.1.1 immediate-gw=10.0.1.1%e3vl99 distance=1 scope=10 target-scope=11strong text
The 2nd route with dst-address=8.8.8.8/32 should have the default target-scope=10, which then will cause scope to be at least 11. scope must be greater than target-scope, internally, RouterOS will fix that for you so even if you write scope=5 it will silently increase it to 11, which is one more than the value of target-scope=10.
But it's better if you know about this and explicitly set scope=11 on this route. We choose 11 because it's the strict minimum possible if you've already set target-scope=10.
So, for this 2nd route it's better (and more correct) to set scope=11 target-scope=10. What you currently wrote:
Actually means scope=12 target-scope=11, not what you wrote.
As for the route with dst-address=0.0.0.0/0, you should give it the default value of scope=30. As for target-scope, if you want to use the 2nd route (the dst-address=8.8.8.8/32 one) to look up the gateway, then target-scope must be at least 11 (which is the real scope value of the 2nd route). This target-scope=11 also satisfy the condition that it is smaller than scope (which we set to 30).
Of course, you can also pick any value >=11 for target-scope for this route, but we should keep the value as small as possible. If you specify target-scope=30 for example, then the gateway look up might be performed using some other routes, for example one that has dst-address=0.0.0.0/0 scope=30.
So, for this dst-address=0.0.0.0/0 route, specify scope=30 target-scope=11.
However, as I wrote above, we are in the routing-table=vrf1, but if you wrote
Then the lookup for the nexthop for the gateway will not use the 2nd route! It will instead look up in the main table (will use the best active route in main that can satisfy the destination 8.8.8.8 and has scope small enough). The 2nd route you posted will not be consulted. If you are fine with that then remove that 2nd useless route. If you however really want to force the nexthop lookup to use that 2nd route, then the first route must have gateway=8.8.8.8@vrf1!
My guess for why you currently have target-scope=30 on that 1st route: The best route in main that can resolve 8.8.8.8 is probably some dst-address=0.0.0.0/0 scope=30 route, that's why this route can only work if you put target-scope=30 and not with lower value.
If you correct it to gateway=8.8.8.8@vrf1, then the lookup can use the second route, and you can use target-scope=11 without issue.
