wAP LTE kit connecting problem
My SXTR & r11e-LTE6 in 56s uptime do a at+reset by himself, and other person give confirmation that is done by ROS itself.
This is like a “build-in feature”.
Hello together !
I have a RBWAPR-2ND&R11E-LTE and the LTE connection goes away after a few days for some reasons. Is there any other script to use in netwatch besides complete reboot ? I also tried the LTE DISABLE and LTE ENABLE script, but this let me run into another problem as i used auto reboot after 12h and netwatch together. It seems that unfortunatly disable script executes same time as reboot so LTE was DISABLED next reboot.
Thank you
It’s sound as other case who should own post/thread at forum.
Of coure they are becasue ROS have got scripting ! :).
Examle:
Simple watchdog: http://forum.mikrotik.com/t/sxt-lte-4g-cat6/134468/1
Advance watchdog: http://forum.mikrotik.com/t/tx-rx-fp-rx-dropped-pppoe-account/132656/1
Watch LTE parameters: http://forum.mikrotik.com/t/sxt-lte-4g-cat6/134468/1
at+reset is is sent if you have chosen specific bands as the module needs to be reset to allo to use only specific LTE band.
did you do an firmware update on built in modem?
https://wiki.mikrotik.com/wiki/Manual:Interface/LTE#Modem_firmware_upgrade
derwulz
My List of official latest version
  • R11e-lte6 v025 (31.03.2020)
  • R11e-lte MikroTik_CP_2.160.000_v015
  • R11e-lte-4g v9
  • R11e-lte-us v16.02.183961
  • SXT LTE 3-7 |-> chip:2.0 fw:0.1.2.4
Hello again !
Problem solved so far as my SIM Card had an error. It seems that SIM cards where updated from time to time trough carrier. I use a script to restart LTE1 when connection lost etc and it seems that sim card (maybe first generation) locked up while doing a reboot … today i will update my R11e to latest firmware, maybe this helps to ?!
EDIT: One thing left - because of this SIM error, my routerboard seems to locked up completely. Had to netinstall the firmware (which tooked me several tries). Now i use 7.x beta which worked so far.
