Hi, after playing around with FlowSphera ( Another Free Netflow app ), is see there an "if 0" interface with multiple IP-subnets (who change from time to time). I assume this is derived from SNMP, in ROS under Interfcaes or IP-Addresses, I cant find this this interface. What does it?
I think you got burned by the new forum UI... since I suspect you meant to post in the FlowSphera topic.
But your router's /ip/address likely tell the story. If those IP blocks are associated with an invalid interface, it might be showing the .id like *0. But this be a question for the FlowSphera guy. Or at least include the /ip/address/print detail here which like sort out why if 0 is shown since I think that's FlowSphera handing non-normalized data.
I assume this is a fallback for something otherwise unnamed.
True, but SNMP is reading interface= here, or at least without context was my guess.
