when to use the bridge interface in Firewall, Queue, etc.? (bridge vs VLAN interface)
how the bridge interface behaves is well said in http://forum.mikrotik.com/t/routeros-bridge-mysteries-explained/147832/53
but where to use the Bridge Interface?
Can I use it somewhere else, e.g. Firewall, Queue, etc. to e.g. simplify things like instead listing all VLAN interfaces or their IP Ranges, I select the bridge which includes all underlying elements.
Bridge as an interface in firewall refers only to the untagged traffic for the bridge interface (typically VLAN 1, but what ever PVID/vlan-id= is set on the bridge interface itself). It is NOT the collection of tagged VLANs on the bridge.
For queues, same should be generally true, but that more complex.
If you set the bridge to accept only tagged packets and use unused vlan-id= on the bridge interface (e.g. one that is NOT an /interface/vlan)…you can avoid thinking too much about the bridge interface mysteries.
Thx for sharing, got it
my bridge is tagged, so I won’t think that much about it anymore :grin:
