WifiWave2 wireless repeater setup
Hi all,
I apologize if I use the wrong terms or mix them up. I am a decent software engineer, but a noob in networking.
After reading many posts here and other forums and watching almost all YouTube videos, I still don’t know how to connect a cAP ax with a hAP ax3 wireless to act as wireless repeater for my wifi networks.
So where did that get me?
Back to you guys.
My current (small) network looks like that:
ISP - Modem -(cable)- hAP ax3
How I want it to look like
ISP - Modem -(cable)- hAP ax3 -(wireless)- cAP ax
I managed to set up the hAP ax3 as a wireless AP, and it works fine for all my wireless devices.
Unfortunately, I need a stronger wifi signal in our living room and I can’t run a cable there. So I decided to buy a cAP ax and use it as a wireless repeater to extend my wifi network.
The problem is that after I bought the cAP ax, I read that the wifiwave2 package in ROS still lacks support for four address frames, so it’s not possible to simply set it up as a repeater as is possible in the legacy wifi package for the ac models (at least that’s how I understand it).
And I also can’t downgrade to the legacy package because the chips in the newer ax models don’t support the legacy wifi package.
So I am asking for your advice.
I read a post by Amm0 where he seems to have accomplished exactly what I needed. But I lack the skills and knowledge to adapt his solution for my network configuration on the hAP ax3:
Thread: http://forum.mikrotik.com/t/using-wifiwave2-to-bridge-two-audience-wirelessly-thoughts-4-address-mode/153357/1
Solution: http://forum.mikrotik.com/t/using-wifiwave2-to-bridge-two-audience-wirelessly-thoughts-4-address-mode/153357/1
Maybe one of you experts can help me to make my cAP ax work as a wireless repeater to extend the WiFi networks provided by the hAP ax3.
hAP ax3 configuration:
Simple:
  • PPPOE-Client via Modem to ISP on ether1
  • VLAN needed by PPOE
  • Network 192.168.1.0/24 on bridge
  • DHCP Server
  • DNS
  • NAT
  • Wifi1 & Wifi2
  • Simple queue
Detail:
# may/18/2023 17:30:07 by RouterOS 7.9
# software id = AEQQ-3H22
# model = C53UiG+5HPaxD2HPaxD
# serial number = HE708XKQ0A3
add name=bridge1
set [ find default-name=ether1 ] name=ether1-WAN
/interface vlan
add interface=ether1-WAN mtu=1492 name=vlan-pppoe vlan-id=7
/interface pppoe-client
add add-default-route=yes disabled=no interface=vlan-pppoe max-mru=1492 max-mtu=1492 name=pppoe-telekom use-peer-dns=yes user=1234567890@t-online.de
/interface wifiwave2 channel
add band=2ghz-ax frequency=2417,2442,2467 name=2.4ghz-channels width=20mhz
add band=5ghz-ax frequency=5270-5290,5290-5310,5310-5330 name=5ghz-channels width=20/40/80mhz
/interface wifiwave2 security
add authentication-types=wpa2-psk name=2.4ghz-sec
add authentication-types=wpa2-psk,wpa3-psk name=5ghz-sec
/interface wifiwave2 configuration
add channel=2.4ghz-channels country=Germany mode=ap name=cfg-2.4ghz security=2.4ghz-sec ssid="Pretty Fly For A Wifi"
add channel=5ghz-channels country=Germany mode=ap name=cfg-5ghz security=5ghz-sec ssid="99 Problems Wifi Aint One"
set [ find default-name=wifi2 ] channel=2.4ghz-channels configuration=cfg-2.4ghz configuration.mode=ap disabled=no name=Wifi-2.4Ghz security=2.4ghz-sec
set [ find default-name=wifi1 ] configuration=cfg-5ghz configuration.mode=ap disabled=no name=Wifi-5Ghz security.authentication-types=wpa2-psk,wpa3-psk .encryption=""
add name=dhcp_pool0 ranges=192.168.1.2-192.168.1.254
add address-pool=dhcp_pool0 interface=bridge1 lease-time=10m name=dhcp1
/port
set 0 name=serial0
/queue type
add cake-diffserv=besteffort cake-nat=yes kind=cake name=cake
add fq-codel-memlimit=64.0MiB kind=fq-codel name=fq-codel
add cake-autorate-ingress=yes cake-diffserv=besteffort cake-flowmode=dual-dsthost cake-rtt-scheme=internet kind=cake name=cake_down
add cake-autorate-ingress=yes cake-diffserv=besteffort cake-flowmode=dual-srchost cake-rtt-scheme=internet kind=cake name=cake_up
/queue simple
add disabled=yes max-limit=100M/40M name=queue-cake priority=1/1 queue=cake/cake target=pppoe-telekom
add max-limit=100M/40M name=queue-fq-codel queue=fq-codel/fq-codel target=pppoe-telekom
add disabled=yes max-limit=80M/40M name=queue-cake2 queue=cake_up/cake_down target=pppoe-telekom
add bridge=bridge1 interface=Wifi-5Ghz
add bridge=bridge1 interface=Wifi-2.4Ghz
add address=192.168.1.1/24 interface=bridge1 network=192.168.1.0
add address=192.168.1.0/24 gateway=192.168.1.1
add action=masquerade chain=srcnat out-interface=pppoe-telekom src-address=192.168.1.0/24
/ip service
set telnet disabled=yes
set ftp disabled=yes
set ssh disabled=yes
set www-ssl disabled=no
set api disabled=yes
set api-ssl disabled=yes
/system clock
/system note
set show-at-login=no
The cAP ax is completely nacked.
Many thanks,
sw00sh
