WinBox 4.2 is released!
What's new in 4.2 (2026-Jul-08 10:31):
  • app: auto decrypt Saved address file in new window if parent window already provided it;
  • form: add option to open linked objects for some read-only optional fields;
  • form: add support for dynamic column re-layout when resizing window;
  • form: allow mouse select a warning text;
  • form: calculate window width of query panel by also considering table width;
  • form: do not show table duplicates in enum shortcut/extras popup;
  • form: fix autostart of some opened action windows;
  • form: fix file picker field state update (changed/error);
  • form: fix query panel getting data immediately if there is no start command;
  • form: fix slow user interface when combobox has huge amount of dynamic data;
  • form: fix some combobox sorting as requested by RouterOS;
  • form: improve load performance if data contains large amount of multi-array rows;
  • form: separate combobox visually and sort items separately from different enum sources;
  • login,romon: fix connect in new window;
  • login,romon: fix visual bug showing "Error: Object doesn't exist" while connecting to slow device;
  • login,romon: show a clearer error when username/password wrong;
  • login: download RouterOS index files sequentially to make login process more stable;
  • login: select all text in "Connect To" field when opening WinBox;
  • login: try to ignore all RouterOS WinBox file parsing errors and connect to RouterOS anyway;
  • settings: change default row padding value from 4 to 3 (affects only new winbox installs);
  • skins: fix crash when field references other fields from hidden table;
  • table: add Ctrl(CMD)+E to enable and Ctrl(CMD)+Shift+E shortcuts to disable selected rows;
  • table: add Insert and Ctrl(CMD)+N shortcuts to add new item;
  • table: add support for cells with colored text by condition;
  • table: add support to configure comment column/header type in each table;
  • table: allow up/down keyboard navigation when there is no current row focus;
  • table: correctly calculate default flags column width if there are combined flags;
  • table: fix column sorting in rare cases;
  • table: fix some buttons to be correctly under Actions group;
  • table: hide live/pause button in Torch type windows (e.g. Profile/Ping) and Saved routers table;
  • table: improve performance of table's quick filter with many records;
  • table: improve performance when scrolling;
  • table: remove selection/checkbox column;
  • table: show field postfix in column header if available;
  • terminal: add support for mouse scroll in script editor;
  • terminal: fix Enter key located on Numpad for macOS;
  • ui: add progress bar support for number based fields in form and table;
  • ui: add settings info that table has end/home/pageup/pagedown shortcuts;
  • ui: fix "Wireless Snooper" table cell values;
  • ui: fix to show only 1 confirmation dialog if action performed on multiple items;
  • ui: make form background a little lighter in light mode;
  • ui: make popup background same as form in darkmode;
  • ui: make workspace Name field read only after it is added;
  • ui: scale context menu width according to zoom;
  • ui: show info that RouterOS update is available;
  • windows: update certificate for Windows executable signing;
  • add new field type support used by future RouterOS version;
  • update Documentation link in About window;
WinBox files for Windows, Linux and macOS are available here:
https://download.mikrotik.com/routeros/winbox/4.2/WinBox_Windows.zip
https://download.mikrotik.com/routeros/winbox/4.2/WinBox_Linux.zip
https://download.mikrotik.com/routeros/winbox/4.2/WinBox.dmg
thanks!
This (auto decrypt for a new window) is probably the best fix in long time
I wish the person who approved the design had the same gaps between the teeth as in Winbox 4, in rows and columns. Is it really that hard to recreate the old design in a new engine without these ugly, unnecessary tools and ugly, awkward design?
You've received so many complaints about 4.1, and in all this time you've done nothing. No comment. Remove this customization and return it to the way it was in v3. If Apple users like this pathetic design, then keep this disgrace specifically for them.
What exactly do you mean? I, for one, think the new design is very well done. You can customize the GUI (including the spacing) – have you tried that?
Usage: WinBox [options] connect-to username password workspace
Please enhance that so password and workspace are optional args and WinBox can be auto-connecting to a saved entry without presenting the "Connect to" screen.
Maybe as WinBox [options] connect-to or maybe with a specific --connect option.
Can Tik remove the "assets" folder? I have the .exe on my desktops and with each update that "assets"-folder with only the WinBox-logo is created. Never asked for this, but get it everytime... o_O
Make it stop!
grafik
Just push the executable file anywhere else, then create a link on the desktop...
Open the zip and extract only WinBox.exe and skip the assets folder...
That does not help for automatic updates from within Winbox.
Ok those do not work here anyway because the user running WinBox has no permission to overwrite the executable. So I download new versions myself and unpack them.
This would work, but I seen no reason for the logo?
If I want the logo, I would search it on the website... https://mikrotik.com/logo
Probably no one at MikroTik uses Windows on their PCs anymore and have no idea that the Microsoft PE executable format, since decades, have standard sections for embedded resources, such as the icon. The assets folder with the separate PNG logo file is there only to address the shortcoming of Linux's ELF file format and should really be removed from the Windows version.
It is good they provide a logo, I used it to make a nice shortcut to the program, but it would probably be better to provide it as a separate download instead of putting it in the zip file. And indeed, for Windows it is useless.
I
Don't know if it's a bug of WinBox 4.2 but on ROS 7.21.5 LTS on AX2 the latest rules are not shown with the inline comment, even if it is present when opening them individually and they appear regularly from Winbox3
What is the purpose of this customization in the settings tool? v3 was minimalist; it had convenient “colored menus,” a normal scrollbar, the ability to hide windows “to the left,” “single-column” settings, and additional menus and tools located at the top of each window rather than on the right, among other features. It weighed in at 2 MB and was way more pleasant to use than this piece of junk. I honestly don’t understand how they didn’t fire the person after the first v4 presentation.
I just don't get it—was it really that hard to simply replicate the v3 design on the new “engine” and add new tools, instead of completely reworking the design?
You can keep whining forever about companies following the "modern trend of GUI" but that will not help. Releasing a program with "old windows look" at some time will backfire on them (you will see "the config tool looks archaic" in all reviews), and also they (at least now) use standard a toolkit for the GUI which will move on as well.
:wink:
I'm glad they heard some of ours and mine complains.
I haven't used extensively, but so far this version is faster, not that sluggish behavior which made winbox practically useless.
Romon still has issues when you check "open in new window" and trying to connect to a romon neighbor. It fires wrong username or password. When unchecking "open in new window", it opens correctly.
Old Winbox: looks and feels like old SCADA systems. Readable, Reliable, Inanbiguous.
New Winbox: looks "cool", on the UI side.. on the UX side, is less readable, less reliable, and ultimately less useful than old winbox.
BUT BUT BUT, the guys at servethehome / reddit can say that it "feels modern", meh.
