WinBox 4.5 released!
did you enabled open in new window?
Good catch !
Then the issue indeed presents itself...
To be honest: I never use that option, that's why I didn't notice before.
The reason is simple. When it is displayed at login, it is shown with fixed font. So when it is being edited, it should be fixed font as well.
It works OK here...
try open in new window
I have to say ... I just tried this again. And now it does work.
But I am certain it didn't the first time.
Zero issues or artifacts on Linux as well . . . (or at least I can't find 'em). Tried a bunch of fonts in 45 after loading it yesterday - all rendered fine.
That's because you probably have a high DPI screen (higher than 96 DPI) and / or you did not lower the scalling setting in WinBox 4 to achieve the same information density as WinBox 3 (which normally means 92% zoom).
Look at the screenshot that @Caci99 posted above:
Look at all the B, F, E, 4,... characters and see how they are unable to snap to the pixel boundary like Segoe UI at the same size and as a result become blurry.
That's acknowledged by the author of Inter, as I posted above:
Microsoft's fonts are all manually hinted for the small sizes and look much sharper.
Again, you probably won't notice problem if you are ok with big text wasting space or have high DPI monitor. For people with 96 DPI screen that need to change the zoom to 92% or lower to be able to see enough information, plenty of issues appear with the Inter font.
Here is WinBox under Linux with FreeType having all features turned on, at 100% scaling and 92% scaling with the default Inter:
Look how all the digits suddenly no longer have the same width at 92% scaling and the timestamp column becomes wavy. Good UI fonts normally should make sure that the digits all have the same width, especially when they have tables that display numbers. I know you hate "Winduh" but at least MS has always known to do that with their default UI fonts (MS Sans Serif with Win9x, Tahoma with 2000/XP, and Segoe UI from Vista).
You can see it on the 100% screenshot: subpixel hinting. It is differently (=more notable) on WB4 than in other applications. At least I have the impression. It honors my xft settings but something is with the rendering engine. But regardless, I have now set xft.rgba:none for WB4 and it improves it.
it has to do with romon agents
when a new window is fired, it very probably loses the romon agent to use via which it can connect
2011 laptop with a pretty basic GPU. 720p native, but I do run two 1024 screens on it for work. I hate large type . . . not sure my scaling, though . . . likely still at default. Hardly a high end system . . . I do use kde, so pretty much a QT environment. I note that the Winbox binary does not dynamically link system QT, though, so not sure what it is using (it does link freetype, though . . . and I have different font choices than I hear folks discuss on Win*).
(24 inch screens, iirc, and most WinBox windows are 3x6 inch or so, with most things displayed.)
@ CGGXANNX
Only throwing this on the table (and quickly hiding my hand behind my back) as I don't have handy PC's with Windows 10 or 11 I can fiddle with, but maybe - just maybe - an attempt with a narrow monospaced font might remove the need for the 92%.
Input (the font) has a preview page where it is possible to play with the font proportions:
https://input.djr.com/preview/?size=14&language=python&theme=solarized-dark&family=InputSans&width=300&weight=300&line-height=1.2&a=0&g=0&i=0&l=0&zero=0&asterisk=0&braces=0&preset=default&customize=please
Input Mono
Size:15px Width: Normal
has approximately the same density (number of characters in the same window width) as:
Size:18px Width:Compressed
Scaled to 67% (as low as it will go) - so small that I can barely read it. Seems like things are still fine here . . . (92% is the same)
Not claiming that others don't have a problem, just that I don't see it here . . . Screen res on this display is 94x94, fwiw.
We have vastly different definition of "fine".
Not visible looking at the screen . . . . IE, not relevant to me (AKA "whining" about nothing . . . .)
Might even be a screenshot artifact. Looking at my posted image looks like crap compared to the screen . . .
Could you please elaborate? Did you mean 92% of "Global zoom" or "UI size"?
By the what the hell is wrong with person that decided that moving "Exit" and "Safe Mode" buttons to the far end of the screen was a good idea? Who hurt them?
That's because you've changed to another font than Inter. If you keep Inter and reduce the Zoom to 92% for example, you'll see that the digits don't have the same width anymore. Here is a comparison, left is Windows, right is Linux (Arch) at 92% and the default Inter font setting from WinBox:
As you can see between log lines #26 and #27, the timestamps are not aligned because they contains different digits.
Somehow the same Inter at the same 92% scaling on Windows does not have this problem (white WinBox in the screenshot). Dates and times are correctly aligned.
The issue is even more pronounced on Linux if I reduce the Scaling to 67%:
As you can see, due to the different widths, some timestamps are truncated and display ellipsis while other don't.
Not all the usual fonts under Linux have the issue, for example Roboto, Open Sans, and Liberation Sans are ok. But Adwaita Sans has the same problem as Inter at 92%:
Bottom line is that Inter is not good for low DPI screen when we want high data density.
The setting that affects the font size is UI size but changing Global zoom by default also sets UI size to the same value.
