WinBox 4.5 released!
Yes, there are many "Narrow" font that can be selected under Windows too, and some "Variable" fonts also allow you to change the width by dragging the 3 weight and spacing sliders in WinBox (under the font selection). However, they don't change the height. And setting the zoom level to 92% or lower is needed to be able to display the almost the same number of lines in the tables as WinBox 3 while keeping "Table row height" at 1px:
If I increase the scaling to 100%, then to have the same number of visible lines, I would need to reduce "Table row height" to 0px. And the combination of larger text while having almost no spacing between the lines make it less readable.
While I have tried other fonts, pretty sure that was still Inter . . . . at 67 and 92 percent.
I still think it's not Inter because that font is normally "rounder" and has a bit more spacing between letters than in your screenshot. Here is an Arch screenshot next to yours with UI size 67% and Spacing 100% like what you've set:
Here are my Linux font settings:
I did some further "research" and it does look like MikroTik replaced the number glyphs of Inter by the ones from some other font. If we go to this page:
Inter - Google Fonts
and use the playground text box to enter 10 1 and 10 2 at any font size:
We can see that by default Inter does not have same-width numeric characters. And also the 1 does not have the horizontal base like what we see in WinBox when we select Inter as the UI font.
In the WinBox 4 beta thread number character width was one of the complaints early on, and there was actually this update to address that:
But I can't remember whether WinBox still used Manrope at that time or has already switched to Inter. Anyway, the current digit characters in the Inter font shipped with WinBox 4 are not from Inter, and on Linux while they have the same width at 100% scaling and up, whatever tweak MikroTik made does not apply to the lower sizes of the font.
On Windows it's ok though.
I can't tell you if there is a substitution or not, but other than changing back to 100%, these are my settings - definitely set to inter.
Yes, I did some tests and I think the difference that we observed are due to the FreeType hinting setting. If that is set to Medium or Full then Winbox's Inter font has the number width issue. But if set to None or Slight (like what you have) then the widths are the same.
The problem with reduced hinting levels is that, at least with other fonts in the UI, it produces inconsistent results for letters like l or i.
Notice that "Anti-Aliasing:", "Sub-pixel rendering:", and "Hinting:" are all right-aligned and all ends in "ing:", so in theory the three i should be identically rendered, but in your screenshot they are not. Even the : a that are all at the same vertical position (right-aligned) look different.
So, they might be blurry or not, depending on the position of the characters (with same foreground and background color and size).
It looks like the WinBox's Inter font does not have good hinting information for smaller sizes (the original Inter also does not have as admitted by the author, see my previous post). Anyway, I change the font to Roboto and that does not have the problem (at 92%) and that's what I use with WinBox under Linux.
Current (shipped with Winbox) digit characters in the Inter font are FROM Inter with number of OpenType features switched On.
https://rsms.me/inter/#features
Thanks, it does look like the glyphs of "Tabular numbers".
In Linux I use the generic font "Sans Serif" and zoom level 83% and I do not observe the issues that plague so many users above. But I have seen it in the past, especially with the fonts suggested by MikroTik.
(i.e. the default font when you install WinBox, which has changed several times. it became worse and worse and worse)
Yep, I understand that, but all in all isn't it better a few less lines but clearly readable than the blurry mess we have seen ?
As always I may be wrong, but in practice which items do actually "fill" the screen with lines?
  1. checking the log
  2. reading an /export
  3. ...?
Contrack
Firewall Rule
Firewall RAW
Firewall NAT
ARP Table
MAC Table
PPPoE Sessions
VPN Sessions
Interface General / Vlans / Some Other Types Table
Bridge Vlan
And many, many others...
I'm happy with the custom settings under Windows (Segoe UI) and Linux (Roboto) at 92%, which are not blurry, it's Inter that has problems :slight_smile:
As for the needs to see more lines, what @fischerdouglas listed, also DHCP leases/bindings, and especially the Logs window, that has 1000 lines with dense amount of text.
I don't know.
1000 lines at 38 lines per screen imply 26 screens/full page scrolls.
You are getting 34 lines that imply 29 screens.
If we reduce the 38 by 20% and get 30 lines, that will be 33 screens, as I see it nothing compared to have to squint your eyes to read.
I was asking about views that normally fit in 34 lines (no scroll) but that don't in 30 lines.
Windows 11 Pro,
Font: Inter
Full screen Log window: 69 1/2 lines.
But I don't want to scroll. For the log window, of course most of the time it will be kept at the view that has 999 at the bottom with the most recent items. If the view has all the new items since the last time I took at look at it then it's perfect. But if it misses lines then I've to scroll.
Also, for the other window, even if I don't have 30 interfaces, it's good to increase the number of possible lines while still having good readability, because most of the windows will not be maximized, but usually resized to see all the required content and placed next to each other, to have everything at a glance. It could make the difference between being able to place two windows above each other instead of having to switch window all the time.
For 96 DPI screen, at FHD or 2K, a 92% scaling in WinBox is the sweet spot for me (and is similar to WinBox 3).
The last screenshot in your post is 2002px high. Try to fit that on a FHD (1920x1080) or 2K (2560x1440) screen. Don't forget the title bar and taskbar!
Your Inter font is rendered at 22px. We have been talking about sub 12px here. Where Inter has no hinting.
My system settings - 4k (3840x2160)
Winbox screen size: appr. 2380x1950
Ordinary my Winbox application window is devided into 3 horizontal parts:
  • Interfaces
  • Firewall
  • Log
In lower resolution modes, the "image quality" of WInbox is almost the same as in the rest of the system.
2K (2560x1440) (WInbox window: 65 lines max)
Winbox
Chrome: MT Forum :wink:
As i wrote above:
Please provide an option to revert to the WinBox 3 interface. The best visual layout I can achieve with the new version still falls far behind what the older interface offered
In your example 2K screen the text is blurry!
That's what we want to avoid. With Segoe UI at 92% and WinBox maximized, 70 log lines are visible on my 1440p screen:
(the log window is 1319px high, the rest are Windows taskbar, Window title bar, and WinBox Workspace menu bar)
And it's not blurry like Inter.
Well for Windows Segoe UI looks great and sharp at different DPI scaling options and font sizes. That's what WinBox 4 should have set as default for the Windows build.
Check GitHub - mark99i/WinboxPatch: WinBox 3.43 for RouterOS 7.25+ · GitHub
I made it so that it works correctly in 7.24 (MT managed to break some fields), 7.25, and even CMR 7.26beta in CHR.
